Demo例程
- int main(void)
- /*!< At this stage the microcontroller clock setting is already configured,
- this is done through SystemInit() function which is called from startup
- file (KEIL_startup_hk32f030m.s) before to branch to application main.
- To reconfigure the default setting of SystemInit() function, refer to
- system_hk32f030m.c file
- uint16_t i;
- /* Inser delay time for debug purpose */
- Delay(0xFFFFF);
- HK_EVAL_LEDInit(LED1);
- HK_EVAL_LEDToggle(LED1);
- for(i=0; i<512; i++)
- Write_Data[i] = 0xAB;
- Write_Data_To_Flash(FLASH_USER_START_ADDR, Write_Data, 512);
- Read_Data_From_Flash(FLASH_USER_START_ADDR, Read_Data, 512);
- /* Infinite Loop */
- while (1)
- Delay(0xFFFFF);
- //從指定地址寫入數據
- void Write_Data_To_Flash(uint32_t address, uint8_t* data, uint16_t size)
- uint8_t Temp;
- /* Unlock the Flash to enable the flash control register access *************/
- FLASH_Unlock();
- /* Erase the user Flash area
- (area defined by FLASH_USER_START_ADDR and FLASH_USER_END_ADDR) *********/
- /* Clear pending flags (if any) */
- FLASH_ClearFlag(FLASH_FLAG_EOP | FLASH_FLAG_WRPERR);
- /* Define the number of page to be erased */
- NbrOfPage = size / FLASH_PAGE_SIZE;
- /* Erase the FLASH pages */
- for(EraseCounter = 0; (EraseCounter <= NbrOfPage) && (FLASHStatus == FLASH_COMPLETE); EraseCounter++)
- if(FLASH_ErasePage(FLASH_USER_START_ADDR + (FLASH_PAGE_SIZE * EraseCounter)) != FLASH_COMPLETE)
- /* Error occurred while sector erase.
- User can add here some code to deal with this error */
- while(1)
- /* Program the user Flash area half-word by half-word
- (area defined by FLASH_USER_START_ADDR and FLASH_USER_END_ADDR) ***********/
- uint16_t i=0;
- FLASH_USER_END_ADDR = address + size;
- while (address < FLASH_USER_END_ADDR)
- Temp = data[i];
- if (FLASH_ProgramByte(address, Temp) == FLASH_COMPLETE)
- address = address + 1;
- else
- /* Error occurred while writing data in Flash memory.
- while (1)
- i++;
- /* Lock the Flash to disable the flash control register access (recommended
- to protect the FLASH memory against possible unwanted operation) *********/
- FLASH_Lock();
- //從指定地址讀取數據
- void Read_Data_From_Flash(uint32_t address, uint8_t* data, uint16_t size)
- uint16_t i=0;
- data[i] = *(uint32_t*)address;
- i++;
- if( Write_Data[i] != Read_Data[i] )
- //讀取錯誤處理
- MemoryProgramStatus = FAILED;
- while(1);
原理圖: 無
仿真: 無
代碼:
HK32F030M-FLASH.7z
(1.03 MB, 下載次數: 4)
2024-3-4 21:46 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
