查看: 1687|回復: 6
stc8h8k64u內部12位ad加lcd1602做得電壓表為啥運行不了?
回帖獎勵 100 黑幣 回復本帖可獲得 20 黑幣獎勵! 每人限 1 次
ID:1108299 發表于 2024-3-5 13:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <STC8h.H>
#include <stdio.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
//        uint Get_ADC12bitResult(uchar channel);
//void iO();
sbit RS = P2^4;   //定義端口
sbit RW = P2^5;
sbit EN = P2^6;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
void delay(unsigned int ms)        //@11.0592MHz
        unsigned char data i, j;
   while(ms--)
        i = 15;
        j = 90;
        do
                while (--j);
        } while (--i);
              判忙函數
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
delay(1);
EN_SET;
         delay(1);
return (bit)(DataPort & 0x80);
              寫入命令函數
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙則等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
delay(1);
EN_CLR;
         delay(1);
              寫入數據函數
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
delay(1);
EN_CLR;
         delay(1);
                清屏函數
void LCD_Clear(void)
LCD_Write_Com(0x01);
delay(5);
              寫入字符串函數
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
         LCD_Write_Com(0x80 + x);     //表示第一行
        LCD_Write_Com(0xC0 + x);      //表示第二行
while ((*s)!='\0')
LCD_Write_Data( *s);
s ++;
              寫入字符函數
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
              初始化函數
void LCD_Init(void)
   LCD_Write_Com(0x38);    /*顯示模式設置*/
   delay(5);
   delay(5);
   delay(5);
   LCD_Write_Com(0x08);    /*顯示關閉*/
   LCD_Write_Com(0x01);    /*顯示清屏*/
   LCD_Write_Com(0x06);    /*顯示光標移動設置*/
   delay(5);
   LCD_Write_Com(0x0C);    /*顯示開及光標設置*/
void adc_init() {
    ADCCFG =ADCCFG|0x20;  // 將P1.0設置為ADC功能
    ADC_RES = 0;
        ADC_RESL = 0;
    ADC_CONTR = 0x80;
unsigned int adc_read()
    ADC_CONTR |= 0x40;
                delay(3);
    while ((ADC_CONTR&0x20)==0);
    ADC_CONTR &= ~0x20;
    return (ADC_RES << 8) + ADC_RESL;
void main() {
    unsigned int voltage;
        unsigned char i;
    char str[16];
    LCD_Init();
    adc_init();
    while (1) {
        voltage = adc_read();
        sprintf(str, "Voltage: %.2fV", voltage * 5.0 / 4096);
        LCD_Write_Com(0x80);  // 設置光標位置為第一行第一列
        for ( i = 0; i < 16; i++) {
            LCD_Write_Data(str[i]);
        delay(1000);  // 延時1秒鐘
有沒有大佬回答!這個顯示沒有報錯,但是運行不了,是哪個原因?
收藏收藏3 分享淘帖 頂 踩
ID:226055 發表于 2024-3-5 14:06 | 只看該作者
    你好,你這里只給了程序,看不到原理圖和硬件不好分析,下面從典型的幾點給下參考:
    1、先分開測試,比如先點亮屏,屏需要硬件調節對比度的。不知道你的硬件,我把我手上有的艾克姆的STC8H8K64U的程序附件發上。
    2、如果屏可以顯示(注意參考時把IO口都注意到,修改到),然后可以測下ADC,程序見附件。注意ADC選擇的通道。例程用的P0.4口。
ADC.rar
42.32 KB, 下載次數: 11
LCD1602.rar
40.56 KB, 下載次數: 9
ID:41656 發表于 2024-3-5 15:48 | 只看該作者
你說的運行不了是具體只什么,顯示也顯示不了還是能顯示ADC轉換不正常。程序中沒有看到你初始化IO模式,STC8H的IO看看手冊上面P3.0、P3.1是默認準雙向,其余IO是默認高阻模式,初始化驅動LCD的GPIO模式為準雙向或者推挽模式,不熟悉的情況下設置為準雙向
ID:213173 發表于 2024-3-5 16:40 | 只看該作者
給你一個STC8H測量電壓,數碼管顯示并串口上傳數據的示例,只要把對應端口和數碼管改1602顯示就行。
STC8H測量電源電壓計算輸入電壓串口上傳數據.rar (22.1 KB, 下載次數: 26)
ID:883242 發表于 2024-3-5 17:40 | 只看該作者
是沒有顯示還是顯示的數值不對?
ID:1108299 發表于 2024-3-5 19:58 | 只看該作者
沒有顯示
ID:62223 發表于 2024-3-9 10:29 | 只看該作者
單片機的P0數據口得配置推挽輸出,
如果是自己做的板子注意需要把顯示屏的VL引腳接一個1K電阻到地,調高對比度
主站蜘蛛池模板: 国产精品aaa| 黄色1级视频| 亚洲精品黄 | 伊人在线视频 | 中文字幕精品在线观看 | 涩涩在线| 成人免费毛片aaaaaa片 | 日韩在线视频观看 | 成人一区二区三区 | 夜夜操夜夜 | 成人福利网站 | 中文字幕一区二区三区四区 | 精品久久国产 | 欧美日韩毛片 | 中文字幕国产 | 久草网在线 | 性做久久久久久久免费看 | 男女啪啪免费 | 国产精品麻豆免费版 | 91精品国产成人www | 成人精品在线观看 | 免费视频一区二区 | 黄色小视频在线观看 | 欧美在线视频一区二区 | 免费一级a毛片 | 欧美激情专区 | 毛片毛片毛片毛片毛片 | www.国产精品.com | 欧美亚洲一区二区三区 | 午夜不卡视频 | 日本特级黄色片 | 久久久久久亚洲 | 精品久久久久久久久久久久久久久久 | 一级黄色免费 | 天天天干 | 亚洲成人黄色 | 黄色一级免费 | 国产一区二区精品在线 | 四虎影视最新网址 | 在线视频成人 | 久久精品国产亚洲 |
