查看: 2298|回復: 3
STC8單片機之EV1527無線433M解碼程序
ID:105206 發表于 2024-3-9 22:28 | 顯示全部樓層 |閱讀模式
MCU:STC8單片機
解碼協議:EV1527
顯示:LCD1602
  1. #include "time.h"
  2. #include "uart.h"
  3. #include "delay.h"
  4. #include "task.h"
  5. ////////////////////////////////
  6. unsigned char decode_ok;
  7. unsigned int  hh_w,ll_w;
  8. unsigned char  ma_x;
  9. unsigned char  bma1,bma2,bma3,bma4;
  10. unsigned char  mma1,mma2,mma3,mma4;
  11. unsigned char mmb1,mmb2,mmb3,mmb4;
  12. //extern uint8_t mmb1,mmb2,mmb3,mmb4;
  13. unsigned char rf_ok1,rf_ok2,rf_ok;
  14. unsigned char old_rc5;
  15. unsigned char tb_ok;
  16. unsigned char D0,D1,D2,D3 ;
  17. unsigned int s ,s1;
  18. unsigned char bt_auto;
  19. unsigned char rf_data[4];
  20. void rexode_433M(void);
  21. //bit open_led_flag=0;
  22. unsigned char count_5ms=0;
  23.
  24. extern unsigned char code out[];//LED數組
  25. extern u8 add1,spacing,mode;//地址,間隔時間,模式
  26. //////////////////////////////////////////
  27. void Timer0Init(void)
  28. {
  29.         TMOD|=0x00;
  30.         TL0=65536-10;                                                //定時10ms
  31.         TH0=(65536-10)>>8;
  32. /////////////////////以下STC12/////////////////////
  33. //                TL0=65536-46;                                                //定時10ms,系統時鐘12分頻后,定時1的時鐘為2.25M,
  34. //                TH0=(65536-46)>>8;
  35.         TR0=1;ET0=1;        //定時器0 ,定時16位模式
  36.         EA=1;
  37. }
  38. //////////////////////////////////////////
  39. void timer0_interrupt(void) interrupt 1
  40. {
  41.         TL0=(65535-50)%256;                                                //定時50us,
  42.         TH0=(65535-50)/256;
  43.         count_5ms++;
  44.         TX_433M_pin=~TX_433M_pin;
  45.         rexode_433M();
  46. }
  47. //////////////////////////////////////////////
  48. void rexode_433M(void)
  49. {
  50.         if (!RF)
  51.         {
  52.                 ll_w++;
  53.                 old_rc5=0;
  54.         }
  55.         else
  56.         {
  57.         hh_w++;
  58.         if (!old_rc5)
  59.         {   // 2/5 100/130
  60.                 if (((hh_w>=2)&&(hh_w<=15))&&((ll_w>=160)&&(ll_w<=320)))
  61.                 {
  62.                         tb_ok = 1 ;
  63.                         ma_x = 0;
  64.                         bma1=0; bma2=0; bma3=0; bma4=0;
  65.                 }
  66.                 else if ((tb_ok)&&((ll_w>=19)&&(ll_w<=33))) //8/13
  67.                 {
  68.                         ma_x++;
  69.                         if(ma_x>23)
  70.                         {
  71.                                 if(!rf_ok1)
  72.                                 {
  73.                                         mma1=bma1;
  74.                                         mma2=bma2;
  75.                                         mma3=bma3;
  76.                                         mma4=bma4;
  77.
  78.                                         rf_ok1=1;
  79.                                         tb_ok=0;
  80.                                         s=10000;
  81.                                         }
  82.                                         else
  83.                                         {
  84.                                                 mmb1=bma1;
  85.                                                 mmb2=bma2;
  86.                                                 mmb3=bma3;
  87.                                                 mmb4=bma4;
  88.
  89.                                                 rf_ok2=1;
  90.                                                 tb_ok=0;
  91.                                         }
  92.                                 }
  93.                          }
  94.                          else if ((tb_ok)&&((ll_w>=2)&&(ll_w<=14)))   // 2/7
  95.                          {
  96.                                  switch (ma_x)
  97.                                  {
  98.                                  case 0 : { bma1=bma1 | 0x01; break; }
  99.                                  case 1 : { bma1=bma1 | 0x02; break; }
  100.                                  case 2 : { bma1=bma1 | 0x04; break; }
  101.                                  case 3 : { bma1=bma1 | 0x08; break; }
  102.                                  case 4 : { bma1=bma1 | 0x10; break; }
  103.                                  case 5 : { bma1=bma1 | 0x20; break; }
  104.                                  case 6 : { bma1=bma1 | 0x40; break; }
  105.                                  case 7 : { bma1=bma1 | 0x80; break; }
  106.                                  case 8 : { bma2=bma2 | 0x01; break; }
  107.                                  case 9 : { bma2=bma2 | 0x02; break; }
  108.                                  case 10: { bma2=bma2 | 0x04; break; }
  109.                                  case 11: { bma2=bma2 | 0x08; break; }
  110.                                  case 12: { bma2=bma2 | 0x10; break; }
  111.                                  case 13: { bma2=bma2 | 0x20; break; }
  112.                                  case 14: { bma2=bma2 | 0x40; break; }
  113.                                  case 15: { bma2=bma2 | 0x80; break; }
  114.                                  case 16: { bma3=bma3 | 0x01; break; }
  115.                                  case 17: { bma3=bma3 | 0x02; break; }
  116.                                  case 18: { bma3=bma3 | 0x04; break; }
  117.                                  case 19: { bma3=bma3 | 0x08; break; }
  118.                                  case 20: { bma3=bma3 | 0x10; break; }// ?????1?
  119.                                  case 21: { bma3=bma3 | 0x20; break; }
  120.                                  case 22: { bma3=bma3 | 0x40; break; }
  121.                                  case 23: { bma3=bma3 | 0x80;
  122.                                                           if(!rf_ok1)
  123.                                                           {
  124.        mma1=bma1;
  125.        mma2=bma2;
  126.        mma3=bma3;
  127.                                                            // mma4=bma4;
  128.        rf_ok1=1;
  129.        tb_ok=0;
  130. //                                   bt_auto=0;
  131.        s=10000;
  132.        break;
  133.                                                           }
  134.                                                           else
  135.                                                           {
  136.        mmb1=bma1;
  137.        mmb2=bma2;
  138.        mmb3=bma3;
  139.        //mmb4=bma4;
  140.        rf_ok2=1;
  141.        tb_ok=0;
  142.        break;
  143.                                                          }
  144.                                                 }
  145.                     }
  146.                     ma_x++;
  147.                  }
  148.                  else
  149.                  {ma_x=0; tb_ok=0;bt_auto=0;bma1=0;bma2=0; bma3=0; hh_w=1;ll_w=0;}
  150.                  ll_w=0;hh_w=1;
  151.              }
  152.              old_rc5=1;
  153.        }
  154.        if(rf_ok1)
  155.         {
  156.             s--;
  157.             if(!s) rf_ok1=0;
  158.             if(rf_ok2)
  159.             {
  160.             if((mma1==mmb1)&&(mma2==mmb2)&&(mma3==mmb3))
  161.             {
  162.                 rf_ok=1;
  163.                 rf_ok1=0;
  164.                 rf_ok2=0;
  165.             }
  166.             else
  167.             {
  168.                 rf_ok=0;
  169.                 rf_ok1=0;
  170.                 rf_ok2=0;
  171.              }
  172.         }
  173.     }
  174.     if((rf_ok))
  175.     {
  176.         TR0=0;
  177.         rf_ok=0;
  178.         rf_data[0]=mma1;
  179.         rf_data[1]=mma2;
  180.         rf_data[2]=mma3;
  181.                 SendOneByte(rf_data[0]);
  182.                 SendOneByte(rf_data[1]);
  183.                 SendOneByte(rf_data[2]);
  184.         decode_ok=1;
  185.         TR0=1;
  186.     }
  187. }
  188. ////////////////////////////////////////////
  189. void EV1527_decoding()
  190. {
  191.         char i=0;
  192.         /////////////////解碼值////////////////////////////////
  193.                 if(decode_ok)
  194.                 {
  195.                          decode_ok=0;
  196.                         switch(rf_data[2])
  197.                         {
  198.                                 case  0x19: OUT1=~OUT1;rf_data[2]=0;break;//1號鍵
  199.                                 case  0x29: OUT2=~OUT2;rf_data[2]=0;break;
  200.                                 case  0x49: OUT3=~OUT3;rf_data[2]=0;break;
  201.                                 case  0x89: OUT4=~OUT4;rf_data[2]=0;break;
  202.                                 case  0x39: OUT5=~OUT5;rf_data[2]=0;break;
  203.                                 case  0x59: OUT6=~OUT6;rf_data[2]=0;break;
  204.                                 case  0xa9: OUT7=~OUT7;rf_data[2]=0;break;
  205.                                 case  0x69: OUT8=~OUT8;rf_data[2]=0;break;
  206.                                 case  0x79: OUT9=~OUT9;rf_data[2]=0;break;
  207.                                 case  0xe9: OUT10=~OUT10;rf_data[2]=0;break;//10號鍵
  208. /////////////11鍵亮(流水)/////////12鍵滅(流水)////////////////////////////////////////////
  209.                                 case 0X99:   //解碼                遙控器11鍵
  210.                                 {
  211.                                         delay_ms(1);
  212.                                         led=out[i];//led燈開始往后面亮delay_ms(2);//led燈開始往后面亮
  213.                                         i++;
  214.                                         delay_ms(spacing*100);
  215.                                         if(i>8)//如果led燈亮完了
  216.                                         {
  217.
  218.                                                 i=8;
  219.                                                 led=0xff;rf_data[2]=0;
  220.                                         }
  221.                                 }break;
  222.                                 case 0Xd9:   //解碼                遙控器12鍵
  223.                                 {
  224.                                         delay_ms(1);
  225.                                         led=out[i];//滅-》滅
  226.                                         i--;
  227.                                         delay_ms(spacing*100);
  228.                                         if(i<0)
  229.                                         {
  230.
  231.                                                 i=0;led=0x00; //p35=1;
  232.                                                 rf_data[2]=0;
  233.                                         }
  234.                                 }break;
  235.                         }
  236.
  237.                 }
  238.
  239.
  240. }
#include "time.h"
#include "uart.h"
#include "LCD1602.h"
#include "delay.h"
#include "key.h"
#include "task.h"
extern u8         xdata U1RxBuf[];
extern u8 add;
extern bit flag;
extern unsigned char Uartflag ;                          //UART判斷標志位
extern char Recive_state ;   //接收完成標志
                            主函數
        InitUART();
        Timer0Init();
///////////////配置端口為雙向口////////////////////////
        P1M0=0X00;
        P1M1=0X00;
        P2M0=0X00;
        P2M1=0X00;
        P3M0=0X00;
        P3M1=0X00;
        Init_LCD1602();;//lcd初始化
        delay_ms(10);
        LCD_Clear();          //清屏
//////////////////////LOGO///////////////////////////
        LCD1602_write_com(0x80);                //指針指向第1行第0個位置
        LCD1602_write_word("       BLD      ");//寶蕾德電子產品
        LCD1602_write_com(0x80+0x40);        //指針指向第2行第0個位置
        LCD1602_write_word("0~10s APPLE:S118");
        delay_ms(100);
        LCD_Clear();//清屏
        LCD1602_write_word("                 ");
        LCD1602_write_word("spacing:    s~   ");        //
//        spacing=IapRead(0x0000);         //EEPROM  讀0x0000到hc[0]
//        add1=IapRead(0x0002);         //EEPROM  讀0x0002到hc[1]
//        mode=IapRead(0x0004);         //EEPROM  讀0x0002到hc[2]
        delay_ms(2);
        spacing_data();
        P2=0x00;
        while(1)   //無限循環
                EV1527_decoding();//解碼
                display_zhu();
原理圖: 無
仿真: 無
代碼: STC8-解碼433M EV1527 串口發送OK版.rar (84.37 KB, 下載次數: 69)
參與人數 1黑幣 +70 收起 理由
admin + 70 共享資料的黑幣獎勵!
ID:672792 發表于 2024-3-10 16:59 | 顯示全部樓層
好資料必須支持,
ID:491875 發表于 2024-3-11 08:42 | 顯示全部樓層
如果能夠增加掉電喚醒功能就可以方便控制接受芯片進入節電模式方便單火線取電功能的實現那就完美了,現在市面上有這個芯片
ID:465279 發表于 2024-6-7 23:45 來自觸屏版 | 顯示全部樓層
學習了?留著下次再看
主站蜘蛛池模板: 欧美一级黄色大片 | 亚洲成人一区二区三区 | 免费黄色大片 | 久久久久蜜桃 | 国产成人在线播放 | 人人爱人人草 | 欧美精品一区二区三区四区 | 国产精品羞羞答答 | www.国产一区| 成年人免费在线视频 | 久久久在线 | 天天躁狠狠躁 | 日本成人网址 | 91免费看视频 | 欧美不卡一区二区三区 | 欧美在线日韩 | 欧美性猛交一区二区三区精品 | 久久一区二区三区四区 | 国产一区中文字幕 | 天天视频国产 | 亚洲人高潮女人毛茸茸 | 手机在线看片1024 | 国产又黄又猛 | 国产精品久久久久久99 | 一区二区三区四区av | 黄色a一级 | 久久久精品国产sm调教网站 | av不卡一区 | 精品无人国产偷自产在线 | 日本不卡视频在线观看 | 五月婷婷色综合 | 欧美精品一区二区在线观看 | 日本久久久久久久久 | 亚洲h网站 | 欧美一区二区三区在线视频 | 狼人色 | 老司机午夜免费精品视频 | 韩日一区二区 | 日韩欧美大片 | 亚洲精品色 | 在线免费观看av网站 |
