查看: 967|回復: 0
溫濕度藍牙煙霧光照
ID:918728 發表于 2024-4-2 17:03 | 顯示全部樓層 |閱讀模式
#include "reg51.h"
#include "ADC0832.h"
#include "DHT11.h"
#include "lcd1602.h"
#define uchar unsigned char
#define uint unsigned int
sbit REN_P     = P1^0;    // 人體
sbit beep=P1^5;//蜂鳴器
sbit shuibeng=P1^7;//shuibeng
sbit fengshan=P2^0;//fengshan
sbit Led_P     = P1^6;                //  LED燈
sbit k1=P2^1;//按鈕
sbit k2=P2^2;
sbit k3=P2^3;
sbit k4=P2^4;
sbit k5=P3^7;
uchar time=0,sec=0;//系統定時
uchar YAN=0;//煙霧
uchar guangzhao=0;                                        // 保存光照
uchar down[]={1,15,30};//下限
uchar up[]={20,40,80};//上限
uchar disp1[]="00 ";
uchar disp2[]="00% ";
uchar mode=0;//模式
//主函數
uchar gCount=0;        // 全局計數變量
uchar gIndex;        // 亮度變量,0是最暗,9是最亮,一共10檔
uint  gTime=0;        // 計時變量,用于計時多久沒檢測到有人
unsigned char Tx_Buf[24];
unsigned char Tx_RENTI_Buf[12];
unsigned char Tx_YANWU_Buf[7];
unsigned char Tx_WENDU_Buf[7];
unsigned char Rx_buf[1];
unsigned char cmd, tx_flag = 0, cnt = 0;
// 定時器初始化
void TimerInit()
    TMOD = 0x21;
    SCON = 0x50;
    TL0 = 0xb0;
    TH0 = 0x3c;                        //賦初值50ms
    TH1 = 0xFD;
    TL1 = TH1;
    PCON = 0x00;
    EA = 1;
    ES = 1;
    TR1 = 1;
    ET0 = 1;                                //打開定時器0中斷允許開關
    TR0 = 1;                                //打開定時器0定時開關
**函數名稱 :uart1_send(unsigned char buf)
**函數描述 :uart發送函數
**輸    入 :buf
**輸    出 :None
void uartx_send(unsigned char buf[])
   unsigned char i=0;
   while(  buf[i] != '\0')
       SBUF = buf[i];
             delay1ms(10);
             TI = 0;
             i++;
void number(void)
    Tx_Buf[0] = 'Y';                                                //幀頭
    Tx_Buf[1] = 'W';                                                //將庫存數據送往發送數組,送給藍牙模塊讓手機APP顯示
    Tx_Buf[2] = ':';                                                //
    Tx_Buf[3] = YAN / 10 + 0x30;                //
    Tx_Buf[4] = YAN%10 + 0x30;
    Tx_Buf[5] = '%';
    Tx_Buf[6] = 'G';                                                //幀頭
    Tx_Buf[7] = 'Z';                                                //將庫存數據送往發送數組,送給藍牙模塊讓手機APP顯示
    Tx_Buf[8] = ':';                                                //
    Tx_Buf[9] = guangzhao / 10 + 0x30;                //
    Tx_Buf[10] = guangzhao%10 + 0x30;
    Tx_Buf[11] = '%';
    Tx_Buf[12] = 'W';                                                //幀頭
    Tx_Buf[13] = 'D';                                                //將庫存數據送往發送數組,送給藍牙模塊讓手機APP顯示
    Tx_Buf[14] = ':';                                                //
    Tx_Buf[15] = dht11_dat[2]/10 + 0x30;                //
    Tx_Buf[16] = dht11_dat[2]%10 + 0x30;
    Tx_Buf[17] = 'C';
    Tx_Buf[18] = 'S';                                                //幀頭
    Tx_Buf[19] = 'D';                                                //將庫存數據送往發送數組,送給藍牙模塊讓手機APP顯示
    Tx_Buf[20] = ':';                                                //
    Tx_Buf[21] = dht11_dat[0] / 10 + 0x30;                //
    Tx_Buf[22] = dht11_dat[0]%10 + 0x30;
    Tx_Buf[23] = '%';
void number2(void)
        Tx_RENTI_Buf[0] ='Y';
        Tx_RENTI_Buf[1] ='O';
        Tx_RENTI_Buf[2] ='U';
        Tx_RENTI_Buf[3] ='R';
        Tx_RENTI_Buf[4] ='E';
        Tx_RENTI_Buf[5] ='N';
        Tx_RENTI_Buf[6] ='J';
        Tx_RENTI_Buf[7] ='I';
        Tx_RENTI_Buf[8] ='N';
        Tx_RENTI_Buf[9] ='R';
        Tx_RENTI_Buf[10] ='U';
        Tx_RENTI_Buf[11] ='!';
void number3(void)
        Tx_YANWU_Buf[0] ='Y';
        Tx_YANWU_Buf[1] ='A';
        Tx_YANWU_Buf[2] ='N';
        Tx_YANWU_Buf[3] ='W';
        Tx_YANWU_Buf[4] ='U';
        Tx_YANWU_Buf[5] ='!';
        Tx_YANWU_Buf[6] ='!';
        Tx_YANWU_Buf[7] ='!';
void number4(void)
        Tx_WENDU_Buf[0] ='W';
        Tx_WENDU_Buf[1] ='E';
        Tx_WENDU_Buf[2] ='N';
        Tx_WENDU_Buf[3] ='D';
        Tx_WENDU_Buf[4] ='U';
        Tx_WENDU_Buf[5] ='!';
        Tx_WENDU_Buf[6] ='!';
        Tx_WENDU_Buf[7] ='!';
// 是否需要報警判斷
void AlarmJudge(void)
                //判斷
                if(YAN>up[0])//煙霧
                 tx_flag = 1;
                 number3();
                 uartx_send(Tx_YANWU_Buf);
                        fengshan=0;
                  tx_flag = 0;
                        fengshan=1;
                if(dht11_dat[2]>up[1])//溫度
                 tx_flag = 1;
                 number4();
                 uartx_send(Tx_WENDU_Buf);
                        shuibeng=0;
                  tx_flag = 0;
                        shuibeng=1;
                //報警
                if((YAN<down[0])||(YAN>up[0]))
                        sec=10;
                if((dht11_dat[2]<down[1])||(dht11_dat[2]>up[1]))
                        sec=10;
                if((dht11_dat[0]<down[2])||(dht11_dat[0]>up[2]))
                        sec=10;
// 按鍵掃描,用于設置報警范圍
void keyscan()
        if(!k1)                 //設置
                        if(mode<3)
                                mode++;
                                mode=0;
                        while(!k1);
                if(mode>0)//上下限設置
                        if(!k2)
                                if(up[mode-1]<99)
                                        up[mode-1]++;
                                while(!k2);
                        if(!k3)
                                if(up[mode-1]>0)
                                        up[mode-1]--;
                                while(!k3);
                        if(!k4)
                                if(down[mode-1]<99)
                                        down[mode-1]++;
                                while(!k4);
                        if(!k5)
                                if(down[mode-1]>0)
                                        down[mode-1]--;
                                while(!k5);
// 自動控制
void AutoControl(uchar num)
if(num<54)        // 最亮
Led_P=0;
else if((num>55)&&(num<65))                                        // 第三亮
gIndex=3;
else if((num>70)&&(num<75))
gIndex=5;
else if((num>80)&&(num<85))
gIndex=7;
else if((num>90)&&(num<95))
gIndex=9;
else if(num>100)        // 最暗
Led_P=1;
// 主函數
        unsigned char i;
        disp1[2]=0xdf;
        init_1602();
  TimerInit();
                for(i=0;i<20;i++)
                        number();
                        keyscan();
                        AlarmJudge();
                        AutoControl(guangzhao);                        // 進行自動控制
                        if(REN_P==0)
                     beep=0;
                                 tx_flag = 1;
         number2();
                                 uartx_send(Tx_RENTI_Buf);
                                tx_flag = 0;
                                 beep=1;
                if(tx_flag == 1)
                                tx_flag = 0;
                                uartx_send(Tx_Buf);
//定時器中斷
void Timer0() interrupt 1
        uint i,j;
        if(sec>0)  //蜂鳴器驅動
                sec--;
                beep=0;
                beep=1;
        gCount++;                                                        // 每1毫秒,gCount變量加1
        if(gCount>=10)                                // 如果gCount加到10了
                gCount=0;                                                // 則將gCount清零,進入新一輪的計數
                if(gIndex!=0)                                // 如果說臺燈不是最暗的(熄滅)
                        Led_P=0;                                                // 則把臺燈點亮
        if(gCount==gIndex)                // 如果gCount計數到和gIndex一樣了
                if(gIndex!=9)                                // 如果說臺燈不是最亮的
                        Led_P=1;                                                // 則把臺燈熄滅
        if(time<19)//0.5s
                time++;
                time=0;
                YAN=ADC(2);//測量煙霧
                i=YAN;
                YAN=i*99/127;
                guangzhao=ADC(1);//測量煙霧
                j=guangzhao;
                guangzhao=j*99/127;
                dht11_recive();//測量溫濕度
                //顯示
                if(mode==0)
                        write_string(1,0,"YAN:");//煙霧
                        disp2[0]=YAN/10+0x30;
                        disp2[1]=YAN%10+0x30;
                        write_string(1,4,disp2);
                        write_string(1,8,"GUA:");//光照
                        disp2[0]=guangzhao/10+0x30;
                        disp2[1]=guangzhao%10+0x30;
                        write_string(1,12,disp2);
                        write_string(2,0,"tem:");//溫度
                        disp1[0]=dht11_dat[2]/10+0x30;
                        disp1[1]=dht11_dat[2]%10+0x30;
                        write_string(2,4,disp1);
                        write_string(2,8,"hum:");//濕度
                        disp2[0]=dht11_dat[0]/10+0x30;
                        disp2[1]=dht11_dat[0]%10+0x30;
                        write_string(2,12,disp2);
                if(mode==1)//煙霧
                        write_string(1,0,"YAN:   ");
                        write_string(2,0,"  H:");
                        write_string(1,8,"       ");//光照
                        disp2[0]=up[0]/10+0x30;
                        disp2[1]=up[0]%10+0x30;
                        write_string(2,4,disp2);
                        write_string(2,8,"  L:");
                        disp2[0]=down[0]/10+0x30;
                        disp2[1]=down[0]%10+0x30;
                if(mode==2)//溫度
                        write_string(1,0,"temp:  ");
                        disp1[0]=up[1]/10+0x30;
                        disp1[1]=up[1]%10+0x30;
                        disp1[0]=down[1]/10+0x30;
                        disp1[1]=down[1]%10+0x30;
                        write_string(2,12,disp1);
                if(mode==3)//濕度
                        write_string(1,0,"humi:  ");
                        disp2[0]=up[2]/10+0x30;
                        disp2[1]=up[2]%10+0x30;
                        disp2[0]=down[2]/10+0x30;
                        disp2[1]=down[2]%10+0x30;
        TH0=0X3C;
        TL0=0XB0;
void UART1_irq() interrupt 4 //處理接收的串口數據
   static unsigned char tmp;
    ES=0;
    if(RI)                                      //接收到字節
        tmp = SBUF;
        if(tmp == 0x01)
            tx_flag = 1;
        RI = 0;                                 //手動清零接收中斷標志位
    ES=1;
主站蜘蛛池模板: 日韩一级片视频 | 色婷婷香蕉在线一区二区 | 免费看黄色av | 在线免费观看黄色片 | 在线视频成人 | 日本丰满肉感bbwbbwbbw | 国产精品国产精品国产专区不片 | 饥渴放荡受np公车奶牛 | 99re久久| 中文字幕第一区 | 视频一区中文字幕 | 精品国产99久久久久久宅男i | 瑟瑟视频在线观看 | 精品欧美在线 | 国产精品成人一区二区三区 | 亚洲午夜在线 | 黄色av免费在线观看 | 成人免费视频国产免费 | 第一福利视频导航 | www久久| 手机av在线免费观看 | 久久久久精 | cao在线 | 国产精品一区二区视频 | 亚洲一区日韩 | 精品一二三区 | 国产寡妇亲子伦一区二区三区四区 | 91性高潮久久久久久久久 | 日韩欧美中文字幕在线观看 | 中文字幕日韩视频 | 国产中文字幕在线观看 | 在线播放h| 超碰成人福利 | 密乳av| 黄色日批视频 | 九九九精品视频 | 福利小视频 | 天天干天天曰 | 中文字幕一区在线观看 | 成人免费视屏 | 五月色丁香 |
