查看: 1669|回復: 5
聽說C語言共用體位域操作比位移操作快
ID:857072 發表于 2024-4-11 21:13 | 顯示全部樓層 |閱讀模式
如題聽說共用體位域操作比位移操作快。下面這個是我現在用的位操作函數
  1. //*******************************************************************/
  2. //功能:二進制數位寫入
  3. //形參:shu:待操作的數。wei:要寫入第幾位(從右到左是0——7位)weiC:為0時寫入0. 為1時寫入1
  4. //返回:無
  5. //詳解:
  6. //*******************************************************************/
  7. uint16 uintwei_xie(uint16 shu,unsigned char wei,bit weiC)//功能:二進制數位寫入
  8. {
  9.         if(weiC == 0)
  10.         {
  11.                 return shu & (~(0x0001<<wei));
  12.         }
  13.         else
  14.         {
  15.                 return shu | (0x0001<<wei);
  16.         }
  17. }
  18. #endif
換成共用體不用函數直接讀寫其實快,但是不能用變量來指定操作哪一位了,下面是寫出函數的調用。
因為要調用函數還要switch ()一次,很懷疑還有必要搞嘛。
  1. #include <REG51.H>
  2. // 定義一個通用的共用體
  3. typedef union {
  4.     uint16_t value16;
  5.     struct {
  6.         bit bit0;
  7.         bit bit1;
  8.         bit bit2;
  9.         bit bit3;
  10.         bit bit4;
  11.         bit bit5;
  12.         bit bit6;
  13.         bit bit7;
  14.         bit bit8;
  15.         bit bit9;
  16.         bit bit10;
  17.         bit bit11;
  18.         bit bit12;
  19.         bit bit13;
  20.         bit bit14;
  21.         bit bit15;
  22.     } bits16;
  23. } BitField;
  24. // 設置指定位的值
  25. void setBit(uint16_t *data, int index, bit value) {
  26.     BitField *bf = (BitField *)data;
  27.     switch (index) {
  28.         case 0: bf->bits16.bit0 = value; break;
  29.         case 1: bf->bits16.bit1 = value; break;
  30.         case 2: bf->bits16.bit2 = value; break;
  31.         case 3: bf->bits16.bit3 = value; break;
  32.         case 4: bf->bits16.bit4 = value; break;
  33.         case 5: bf->bits16.bit5 = value; break;
  34.         case 6: bf->bits16.bit6 = value; break;
  35.         case 7: bf->bits16.bit7 = value; break;
  36.         case 8:  bf->bits16.bit8 = value; break;
  37.         case 9:  bf->bits16.bit9 = value; break;
  38.         case 10: bf->bits16.bit10 = value; break;
  39.         case 11: bf->bits16.bit11 = value; break;
  40.         case 12: bf->bits16.bit12 = value; break;
  41.         case 13: bf->bits16.bit13 = value; break;
  42.         case 14: bf->bits16.bit14 = value; break;
  43.         case 15: bf->bits16.bit15 = value; break;
  44.     }
  45. }
  46. // 獲取指定位的值
  47. bit getBit(uint16_t *data, int index) {
  48.     BitField *bf = (BitField *)data;
  49.     switch (index) {
  50.         case 0: return bf->bits16.bit0;
  51.         case 1: return bf->bits16.bit1;
  52.         case 2: return bf->bits16.bit2;
  53.         case 3: return bf->bits16.bit3;
  54.         case 4: return bf->bits16.bit4;
  55.         case 5: return bf->bits16.bit5;
  56.         case 6: return bf->bits16.bit6;
  57.         case 7: return bf->bits16.bit7;
  58.         case 8:  return bf->bits16.bit8;
  59.         case 9:  return bf->bits16.bit9;
  60.         case 10: return bf->bits16.bit10;
  61.         case 11: return bf->bits16.bit11;
  62.         case 12: return bf->bits16.bit12;
  63.         case 13: return bf->bits16.bit13;
  64.         case 14: return bf->bits16.bit14;
  65.         case 15: return bf->bits16.bit15;
  66.     }
  67.     // 默認返回0,這里可以根據需要修改
  68.     return 0;
  69. }
  70. int main() {
  71.     uint16_t data = 0xFFFF;
  72.     // 讀取并打印每一位的值
  73.     for (int i = 0; i < 16; i++) {
  74.         printf("Bit %d: %d\n", i, getBit(&data, i));
  75.     }
  76.     // 將奇數位設置為0
  77.     for (int i = 0; i < 16; i++) {
  78.         if (i % 2 == 1) {
  79.             setBit(&data, i, 0);
  80.         }
  81.     }
  82.     // 打印修改后的值
  83.     printf("Modified value: %04X\n", data);
  84.     return 0;
  85. }
ID:526108 發表于 2024-4-12 07:27 | 顯示全部樓層
使用位域比使用bit變量慢,還有位域是這樣用的嗎
ID:68520 發表于 2024-4-12 16:03 | 顯示全部樓層
現在單片機的資源都不是很緊缺了,位域操作還有必要不?
ID:883242 發表于 2024-4-14 14:07 | 顯示全部樓層
如果你的單片機體系不支持位操作,移位最快。
如果你的單片機體系支持位操作,請查閱編譯器手冊,比如C51用bdata、bit這些擴展關鍵字,最快。
ID:1088185 發表于 2024-4-15 15:32 | 顯示全部樓層
這要看你用的是什么核, 51就位操作快, arm就移位快一丁點
ID:890708 發表于 2024-9-13 10:53 | 顯示全部樓層
longdeng84 發表于 2024-4-12 16:03
我用數碼管顯示的時候就是用位域的,很節省空間,讓哪個數碼管亮,就用一個bit位
主站蜘蛛池模板: 成人一区在线观看 | 午夜久久久久久久 | 欧美成人xxx | 久久久久久九九九九 | 久久久一 | 国产又粗又黄又爽又硬的视频 | 成年视频在线观看 | 秋霞国产 | 国产精品国产三级国产专区53 | 亚洲精品免费在线 | 国产精品二区一区二区aⅴ污介绍 | 一区二区三区成人 | 99这里只有精品 | 岛国av噜噜噜久久久狠狠av | 久久久久亚洲 | 国产精品2区 | 在线看片a | 免费精品视频 | 4hu在线| 亚洲视频精品 | 在线观看中文字幕 | 久久久www成人免费精品 | 中文字幕理论片 | 三级黄色在线观看 | 在线免费看a | 亚洲精品乱码 | 东方成人av| 国产成人精品一区二区三区福利 | 欧美国产在线视频 | 亚洲一级黄色 | 日本国产在线观看 | 日韩资源 | 国产成人综合视频 | 亚洲a视频 | 涩久久| 色综合一区 | 日韩欧美自拍 | 国产午夜三级 | 911精品国产一区二区在线 | 久久免费观看视频 | 伊人操|
