查看: 1927|回復: 8
實物的LCD12864顯示屏與仿真不一致?
rt。算是從新手到焊板子一路沖過來了。這回板子也焊好了,也下載成功了。最后...顯示屏顯示的和仿真的不一致,這肯定是實物和仿真的器件不一致的問題了,估計的改代碼之類的。但我現在毫無頭緒。求教。 仿真圖
實物圖 附帶上次提問后折磨了很久以后才弄得原理圖
收藏收藏2 分享淘帖 頂 踩
ID:1107719 發表于 2024-4-13 21:05 | 只看該作者
用的是hs12864-15c差點忘了帶實物得編號了
ID:1107719 發表于 2024-4-14 00:05 | 只看該作者
這個是怎么處理?是我換顯示屏還是改代碼?還是我焊接得有問題???
ID:1107719 發表于 2024-4-14 15:15 | 只看該作者
自頂一下。有沒有人有頭緒QAQ
ID:69038 發表于 2024-4-14 15:21 | 只看該作者
實物屏帶字庫,仿真屏無字庫,兩者時序指令不能通用,就是這么回事。。
要與仿真一致,就要換成無字屏。
要實物為主,就要改寫代碼。
ID:1107719 發表于 2024-4-14 15:21 | 只看該作者
#include<reg52.h>
#include<intrins.h>
#include <math.h> //Keil library
#include <stdio.h> //Keil library
#define LCD_databus P0 //LCD12864的8位數據口
#define uint unsigned int
#define uchar unsigned char
int heat=000,spurs=000;
uint c=1;
sbit EN=P2^2; //低電平寫入高電平讀取
sbit RS=P2^0; //高電平數據輸入命令輸入
sbit RW=P2^1; //高電平讀取低電平寫入
sbit CS2=P2^3; //
sbit CS1=P2^4;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit key5=P1^4;
sbit key6=P1^5;
sbit key7=P1^6;
sbit key8=P1^7;
sbit BEEP=P3^0;
char xiaoshu=0;
uchar f2;
uchar m2;
uchar x2;
uchar D,M;
uchar count;
char fen=0;
char miao=0;
unsigned char code time[][16]=
        0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//"0",
        0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//"1",
        0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//"2",
        0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//"3",
        0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//"4",
        0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//"5",
        0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//"6",
        0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//"7",
        0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//"8",
        0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//"9",
        0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//"V",10
        0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//"S",11
        0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//":",12
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//".",13
        0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//"T"14
        0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//"N"15
        0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//"D"16
        0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//"R"17
        0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//"H"18
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"空格"19
uchar code HZ[][32]=
        0x00,0x08,0x08,0x08,0x08,0x08,0x09,0xFE,
        0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
        0x40,0x40,0x41,0x41,0x41,0x41,0x41,0x7F,
        0x41,0x41,0x41,0x41,0x41,0x40,0x40,0x00,//"主"         0
        0x00,0xFE,0x02,0x22,0xDA,0x06,0x00,0x00,
        0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
        0x00,0xFF,0x08,0x10,0x88,0x47,0x20,0x18,
        0x07,0x00,0x07,0x18,0x20,0x40,0x80,0x00,// "隊",         1
        0x10,0x0C,0x84,0x44,0x3C,0x54,0x95,0x96,
        0x94,0x54,0x34,0x14,0x04,0x14,0x0C,0x00,
        0x04,0x04,0x02,0x02,0xFD,0x45,0x44,0x44,
        0x44,0x45,0xFD,0x02,0x02,0x06,0x02,0x00,//“客”        2
        0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"一", 3
        0x00,0x10,0x18,0x16,0x10,0x90,0xF0,0x9F,
        0x90,0x90,0x92,0x94,0x10,0x18,0x10,0x00,
        0x40,0x20,0x90,0x88,0x46,0x41,0x23,0x14,
        0x08,0x14,0x22,0x21,0x40,0xC0,0x40,0x00,//"發"          4
        0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"空白"   5
        0xFF,0xF7,0xF7,0xF7,0xF7,0xF7,0xF6,0x01,
    0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xFF,0xFF,
    0xBF,0xBF,0xBE,0xBE,0xBE,0xBE,0xBE,0x80,
    0xBE,0xBE,0xBE,0xBE,0xBE,0xBF,0xBF,0xFF,//"主"反色         6
        0xEF,0xF3,0x7B,0xBB,0xC3,0xAB,0x6A,0x69,
    0x6B,0xAB,0xCB,0xEB,0xFB,0xEB,0xF3,0xFF,
    0xFB,0xFB,0xFD,0xFD,0x02,0xBA,0xBB,0xBB,
    0xBB,0xBA,0x02,0xFD,0xFD,0xFD,0xFD,0xFF,//“客”反色   7
        0x08,0x08,0x08,0x08,0x88,0x78,0x0F,0x08,
    0x20,0x50,0x48,0x46,0x41,0x41,0x41,0x41,
    0x7F,0x41,0x41,0x41,0x41,0x40,0x40,0x00,//"左"           8
        0x08,0x08,0x08,0x08,0xC8,0x38,0x0F,0x08,
    0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,
    0x08,0x04,0x02,0x01,0xFF,0x41,0x41,0x41,
    0x41,0x41,0x41,0x41,0xFF,0x00,0x00,0x00,//“右”          9
void delay_10us(uint n) //延時n個10us@12M晶振
        uint i;
        for(i=n;i>0;i--)
        _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void delay_50us(uint z)
        uint x,y; for(x=z;x>0;x--)
        for(y=19;y>0;y--);
void delay_ms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void delay(uint i)
while(--i);
} /**?延時函數?**/
void delay_1ms(uint x)
uint i,j;
for(j=0;j<x;j++)
for(i=0;i<110;i++);
void Read_busy()//讀“忙”函數-----數據線的最高位DB71則busy
        P0=0x00;
        RS=0;
        RW=1;
        EN=1;
        while(P0 & 0x80);
        EN=0;
void write_LCD_command(uchar value) //寫命令函數
        Read_busy(); //對LCD的每次讀寫都要讀忙
        RS=0; //選擇命令
        RW=0; //讀操作
        LCD_databus=value;
        EN=1; //EN由1----0鎖存有效數據
        _nop_();
        _nop_();
        EN=0;
void write_LCD_data(uchar value)//寫數據函數
        Read_busy();
        RS=1; //選擇數據
        RW=0;
        LCD_databus=value;
        _nop_();
        _nop_();
        EN=0;
void Set_page(uchar page) //設置“頁”LCD12864共8頁,一頁是8行點陣點
        page=0xb8|page; //頁的首地址為0xB8
        write_LCD_command(page);
void Set_line(uchar startline) //設置顯示的起始行
        startline=0xC0|startline; //起始行地址為0xC0
        write_LCD_command(startline); //設置從哪行開始:共0--63;一般從0 行開始顯示
void Set_column(uchar column) //設置顯示的列
        column=column &0x3f; //列的最大值為64
        column= 0x40|column; //列的首地址為0x40
        write_LCD_command(column); //規定顯示的列的位置
void SetOnOff(uchar onoff) //顯示開關函數:0x3E是關顯示,0x3F是開顯示
        onoff=0x3e|onoff; //onoff:1---開顯示;0---關顯示
        write_LCD_command(onoff);
void SelectScreen(uchar screen) //選擇屏幕
        switch(screen)
                case 0: CS1=0;CS2=0;break; //全屏
                case 1: CS1=0;CS2=1;break;//左半屏
                case 2: CS1=1;CS2=0;break;//右半屏
                default:break;
void ClearScreen(uchar screen) //清屏函數
        uchar i,j;
        SelectScreen(screen); //0--全屏;1---左半屏;2---右半屏
        for(i=0;i<8;i++) //控制頁數0-7,共8頁
                Set_page(i);
                Set_column(0);
                for(j=0;j<64;j++) //控制列數0-63,共64列
                        write_LCD_data(0x00); //寫入0,地址指針自加1
void init_LCD() //LCD的初始化
        SetOnOff(1); //開顯示
        SelectScreen(0);//
        ClearScreen(0); //清屏
        Set_line(0); //開始行:0
void Display_ASCII(uchar screen,uchar page,uchar column,uchar a[][16],uchar h) //屏幕,頁面,列(起始位置),二維數組,索引
        uchar i;
        Set_page(page);
        Set_column(column*8); //因為LCD屏幕上的每個字通常是8*8像素,所以需要乘以8以得到正確像素位置
        for(i=0;i<8;i++) //顯示字符上半部分:8*8
                write_LCD_data(*(a[h]+i));
        Set_page(page+1); //顯示字符下半部分:8*8
        for(i=0;i<8;i++)
        write_LCD_data
        (*(a[h]+i+8));
void Display_HZ(uchar screen,uchar page,uchar column,uchar a[][32],uchar h)
        uchar i;
        Set_page(page); //寫上半頁:16*8
        Set_column(column*16); //控制列
        for(i=0;i<16;i++) //控制16列的數據輸出
                write_LCD_data(*(a[h]+i)); //漢字的上半部分
        Set_page(page+1); //寫下半頁:16*8
        { write_LCD_data(*(a[h]+16+i)); //漢字的下半部分
void dingshiqi()
        TMOD=0X01; //T1 jishu T0 jishi
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=0;
void Key1()//改變發球
        if(key1==0)
                delay_ms(10);
                if(key1==0)
                        while(!key1) //
                                while(!key1)
                                 c=c^1;//異或算法,改變c從而改變主客場發球
void Key2() //持續檢查按鈕增加heat
        if(key2==0)
                delay_ms(10);
                if(key2==0)
                        while(!key2)
                        { while(!key2)
                        heat++;
void Key3() //持續檢查減少heat
        if(key3==0)
                delay_ms(10);
                if(key3==0)
                        while(!key3)
                                while(!key3)
                                if (heat==0)
                                heat--;
                                D=heat;
void Key4() //增加spurs
        if(key4==0)
                delay_ms(10);
                if(key4==0)
                        while(!key4)
                                while(!key4)
                                spurs++;
void Key5()  //減少spurs
        if(key5==0)
                delay_ms(10);
                if(key5==0)
                        while(!key5)
                                while(!key5){ }
                                if (spurs==0)
                                        spurs--;
                                        M=spurs;
void Key6()//中斷計時
        if(key6==0)
                delay_ms(10);
                if(key6==0)
                        while(!key6)
                                while(!key6)
                                        TR0=0;
void Key7()  //開始計時
        if(key7==0)
        delay_ms(10);
        if(key7==0)
                        while(!key7)
                                while(!key7)
                                TR0=1;
void Key8()         //重置
   if(key8==0)
        delay_ms(10);
        if(key8==0)
                        while(!key8)
                                while(!key8)
                                fen=0;miao=0;xiaoshu=0;
void main(void)
        uchar A,B,C,E,F;
        uchar G,H,I,J;
        A=1;
        init_LCD();
        dingshiqi();
        D=heat;
        M=spurs;
                Key1();
                Key2();
                Key3();
                Key4();
                Key5();
                Key6();
                Key7();
                Key8();
                B=heat/10%10;
                C=heat%10;
                E=spurs/10%10;
                F=spurs%10;
                G=fen/10;
                H=fen%10;
                I=miao/10;
                J=miao%10;
                if(heat>D)        //發球
                        if(heat!=D)
                                   if(heat%2==0)
                                         Display_HZ(1,0,1,HZ,9);//"右"
                                         Display_HZ(1,2,1,HZ,5);//"空白"
                                if(spurs%2==1)
                                         Display_HZ(1,0,1,HZ,8);//"左"
                        c=1;
                        D=heat;
                        M=spurs;
                if(spurs>M)
                        if(spurs!=M)
                                   if(spurs%2==0)
                                         Display_HZ(1,0,1,HZ,5);//"空白"
                                         Display_HZ(1,2,1,HZ,9);//"右"
                                if(spurs%2==1)
                                         Display_HZ(1,2,1,HZ,8);//"左"
                        c=0;
                        D=heat;
                        M=spurs;
                if(c==1)
                                 if(heat%2==0)
                                if(heat%2==1)
                        Display_HZ(1,0,0,HZ,6);//“主”反色
                        Display_HZ(1,2,0,HZ,2);//“客”
                if(c==0)
                                   if(spurs%2==0)
                                if(spurs%2==1)
                                         Display_HZ(1,2,1,HZ,8);//"右"
                        Display_HZ(1,0,0,HZ,0);//“主”
                        Display_HZ(1,2,0,HZ,7);//“客”反色
                if((heat==0)&&(spurs==0))
                        D=heat;
                        M=spurs;
                if(A==1)         //比分
                        Display_ASCII(1,0,4,time,B);
                        Display_ASCII(1,0,5,time,C);//bifen
                        Display_ASCII(1,2,4,time,E);
                        Display_ASCII(1,2,5,time,F);
                        if(((heat>=21)&&(heat-spurs>1))||((spurs>=21)&&(spurs-heat>1))||((spurs==29)&&(heat==30))||((heat==29)&&(spurs==30)))
                                A=2;
                                heat=0;spurs=0;
                                B=0;C=0;E=0;F=0;
                if(A==2)
                        Display_ASCII(1,0,7,time,B);
                        Display_ASCII(2,0,0,time,C);//bifen
                        Display_ASCII(1,2,7,time,E);
                        Display_ASCII(2,2,0,time,F);
                                A=3;
                                heat=0;spurs=0;
                                B=0;C=0;E=0;F=0;
                if(A==3)
                                Display_ASCII(2,0,2,time,B);
                                Display_ASCII(2,0,3,time,C);//bifen
                                Display_ASCII(2,2,2,time,E);
                                Display_ASCII(2,2,3,time,F);
                                A=4;
                                heat=0;spurs=0;
                                B=0;C=0;E=0;F=0;
                } //三局分數展示,追分機制 。
                Display_ASCII(1,4,4,time,G); //時間
                Display_ASCII(1,4,5,time,H);
                Display_ASCII(1,4,6,time,12);
                Display_ASCII(1,4,7,time,I);
                Display_ASCII(2,4,0,time,J);
                Display_ASCII(2,4,1,time,13);
                Display_ASCII(2,4,2,time,xiaoshu);
void timer0() interrupt 1 //3定時器1的中斷號1定時器0的中斷號0外部中斷1 2外部中 斷2 4串口中斷
        count++;
        if(count==2)
                count=0;
                xiaoshu++;
                if(xiaoshu==10)
                { xiaoshu=1; miao++; } //計時時間小數
                if(miao==10)
                                miao=0;
                                fen++;
                        } //分鐘
以上是源代碼
ID:1107719 發表于 2024-4-14 16:10 | 只看該作者
zhuls 發表于 2024-4-14 15:21
要與仿真一致,就要換成無字屏。
嘶...如果要改的話,具體要怎么改?買個無字屏的話要買怎樣的?如果要改時許的話又要怎樣??也算是第一次從代碼到仿真再到實物了。這個我還真沒留意。
ID:69038 發表于 2024-4-14 16:29 | 只看該作者
12864LCD常用的無字庫屏是KS0108驅動,常用的有字庫屏是ST7290驅動。
相應代碼本壇都能搜到。
ID:619259 發表于 2024-4-14 22:49 | 只看該作者
仿真屏為左半屏和右半屏驅動,工程屏不是呵。結論:此屏非彼屏。
主站蜘蛛池模板: 精品国产一区二区在线观看 | 国产美女一区二区 | 欧美精品在线播放 | 日韩一区二区三区四区 | 亚洲伦理在线观看 | 午夜国产福利 | 国产区av| 国产精品一区二区在线播放 | 欧美亚洲一区二区三区 | 日本在线观看 | 亚洲第一视频网站 | 免费中文字幕 | 深夜福利网站 | 日韩精品观看 | 久久久久久久国产精品 | www.婷婷| 亚洲综合视频在线观看 | 久久久久国产精品视频 | 成人深夜视频 | 深夜福利视频在线观看 | 国产免费一区二区 | 欧美视频一二三区 | 欧美日在线 | 国产天堂网 | 免费黄色片网站 | 91小视频在线观看 | 一级片黄色片 | 天天干女人 | 2025国产精品 | 国产最新av | 99视频在线精品免费观看2 | 午夜视频一区二区 | 日韩免费看片 | 国产精品一区二区久久 | 国产免费小视频 | 欧美一级久久 | av在线免费观看网站 | 成人三级晚上看 | 黑丝一区 | 成人福利在线 | 欧美三级欧美一级 |
