查看: 1881|回復(fù): 13
51單片機(jī)用串口向6位數(shù)碼管發(fā)送文本18.46.23,數(shù)碼管顯示不了,求大佬們指點(diǎn)
#include <REGX52.H>
unsigned char Nixie_Buffer[9];
unsigned char count, count1;
void UART_Init(void)                //4800bps@11.0592MHz
        PCON &= 0x7F;                //波特率不倍速
        SCON = 0x50;                //8位數(shù)據(jù),可變波特率,與串口發(fā)送的區(qū)別是這里打開了接收控制位REN
        TMOD &= 0x0F;                //清除定時(shí)器1模式位
        TMOD |= 0x20;                //設(shè)定定時(shí)器1為8位自動(dòng)重裝方式
        TL1 = 0xFA;                //設(shè)定定時(shí)初值
        TH1 = 0xFA;                //設(shè)定定時(shí)器重裝值
        ET1 = 0;                //禁止定時(shí)器1中斷
        TR1 = 1;                //啟動(dòng)定時(shí)器1
        EA = 1;
        ES = 1;
unsigned char NixieTable[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0x7f};//0~F,還有小數(shù)點(diǎn)
sbit DP1 = P0^0;
sbit DP2 = P0^1;
sbit DP3 = P0^2;
sbit DP4 = P0^3;
sbit DP5 = P0^4;
sbit DP6 = P0^5;
void Delay(unsigned int xms)
        unsigned char i, j;
        while(xms)
                i = 2;
                j = 199;
                do
                while (--j);
                } while (--i);
                xms--;
void Nixie(unsigned char Location,Number)
        switch(Location)
                case 1:DP1 = 0;break;
                case 2:DP2 = 0;break;
                case 3:DP3 = 0;break;
                case 4:DP4 = 0;break;
                case 5:DP5 = 0;break;
                case 6:DP6 = 0;break;
        P1 = NixieTable[Number];
        Delay(1);//先延時(shí)1毫米,為避免過早清零讓數(shù)碼管太暗
        //P1 = 0x00;//將上一位段選清零,避免上一位段選的數(shù)據(jù)進(jìn)入下一位的位選,且讓清零的數(shù)據(jù)進(jìn)入位選,就沒影響,不過這里好像沒啥用
        //計(jì)算機(jī)進(jìn)行:位選 段選 位選 段選.......
        P0 = 0xff;
void Nixie_showentitle(unsigned char *str)
        while(*str != '\0')
                        if (*str >= '0' && *str <= '9')
                                Nixie(count1, *str++ - 48);//顯示數(shù)字
                                count1++;
                        else if(*str == '.')
                                Nixie(count1 - 1, 16);//顯示小數(shù)點(diǎn)
                                *str++;
}//數(shù)碼管為6位共陽極
        UART_Init();
                Nixie_showentitle(Nixie_Buffer);
void UART_Routine() interrupt 4
        if(RI)
                Nixie_Buffer[count] = SBUF;//從發(fā)送緩沖區(qū)發(fā)送文本,例如18.46.23
                RI = 0;
                count++;
                count %= 9;
                TI = 0;
ID:883242 發(fā)表于 2024-4-15 11:50 | 只看該作者
那么請(qǐng)問發(fā)送什么可以顯示呢?
ID:1116661 發(fā)表于 2024-4-15 12:52 | 只看該作者
Hephaestus 發(fā)表于 2024-4-15 11:50
發(fā)送什么都不能顯示(捂臉)
ID:161164 發(fā)表于 2024-4-15 13:18 | 只看該作者
  1. void Nixie(unsigned char Location,Number)
  2. {
  3.         P1 = NixieTable[Number];
  4.         switch(Location)
  5.         {
  6.                 case 1:DP1 = 0;break;
  7.                 case 2:DP2 = 0;break;
  8.                 case 3:DP3 = 0;break;
  9.                 case 4:DP4 = 0;break;
  10.                 case 5:DP5 = 0;break;
  11.                 case 6:DP6 = 0;break;
  12.         }
  13.         Delay(1);//先延時(shí)1毫米,為避免過早清零讓數(shù)碼管太暗
  14.         P0 = 0xff;
  15. }
ID:1109793 發(fā)表于 2024-4-15 13:20 | 只看該作者
不懂,用電腦的串口嗎?接收的電路啥樣?
ID:1057978 發(fā)表于 2024-4-15 17:22 | 只看該作者
你先固定顯示個(gè)“123456”,正常顯示的話說明顯示程序沒問題,再檢查串口收發(fā)
ID:213173 發(fā)表于 2024-4-15 17:41 | 只看該作者
b1325583446 發(fā)表于 2024-4-15 12:52
發(fā)送什么都不能顯示(捂臉)
串口驅(qū)動(dòng)數(shù)碼管?你這個(gè)數(shù)碼管應(yīng)該是個(gè)模塊,這個(gè)模塊的硬件電路你不提供,大家怎么幫你?
ID:1116661 發(fā)表于 2024-4-15 19:23 | 只看該作者
不好意思大家,這是開發(fā)板,是電腦向單片機(jī)發(fā)送:
屏幕截圖 2024-04-15 192119.png (94.65 KB, 下載次數(shù): 63)
燒錄界面
燒錄界面
通信工程學(xué)院2023級(jí)開發(fā)板.pdf
1.33 MB, 下載次數(shù): 2
ID:1116661 發(fā)表于 2024-4-15 19:29 | 只看該作者
ID:1116661 發(fā)表于 2024-4-15 19:30 | 只看該作者
wangxiangtan 發(fā)表于 2024-4-15 17:22
謝謝,我去試試
ID:1116661 發(fā)表于 2024-4-15 19:45 | 只看該作者
pdf文件沒發(fā)起
屏幕截圖 2024-04-15 194248.png (519.01 KB, 下載次數(shù): 63)
ID:213173 發(fā)表于 2024-4-15 21:47 | 只看該作者
串口收到的文本數(shù)字字符需要減0x30轉(zhuǎn)換成十進(jìn)制數(shù),文本小數(shù)點(diǎn)也是一個(gè)字節(jié),需要轉(zhuǎn)換成0并插入數(shù)碼管段碼的最高位才能在共陽數(shù)碼管上顯示正確數(shù)字。
ID:213173 發(fā)表于 2024-4-15 22:14 | 只看該作者
uchar data dis_buf[8];
uchar data dis_buf1[6];
串口收到的8個(gè)字節(jié)文本保存在緩存
dis_buf[0]='1';
dis_buf[1]='8';
dis_buf[2]='.';
dis_buf[3]='4';
dis_buf[4]='6';
dis_buf[5]='.';
dis_buf[6]='2';
dis_buf[7]='3';
轉(zhuǎn)換成6位數(shù)碼管段碼
dis_buf1[0]=NixieTable[dis_buf[0]-0x30];
dis_buf1[1]=NixieTable[(dis_buf[1]-0x30)]&0x7f;//加小數(shù)點(diǎn)
dis_buf1[2]=NixieTable[dis_buf[3]-0x30];
dis_buf1[3]=NixieTable[(dis_buf[4]-0x30)]&0x7f;//加小數(shù)點(diǎn)
dis_buf1[4]=NixieTable[dis_buf[6]-0x30];
dis_buf1[5]=NixieTable[dis_buf[7]-0x30];
ID:883242 發(fā)表于 2024-4-16 10:31 | 只看該作者
發(fā)送什么都不能顯示(捂臉)
那么顯示部分做到什么程度了?能顯示什么?
主站蜘蛛池模板: 亚洲美女网站 | 国产在线h| 国产成人在线观看免费网站 | 密乳av | 色八区 | 蜜桃av一区二区三区 | 伊人av影院 | 久久一二三区 | 亚洲成人av| 一区二区三区久久 | 国产这里只有精品 | 一区二区三区在线看 | 国产一级黄色大片 | 在线黄网| 精品无人国产偷自产在线 | 国产黄在线观看 | 久久久精品一区二区三区 | 亚洲小视频在线观看 | 欧美性猛交xxxx黑人猛交 | 中文字幕在线网站 | 羞羞的视频网站 | 欧美日韩国产在线 | 成人在线免费网站 | 国产一区2区| 国产a一级| 他揉捏她两乳不停呻吟动态图 | 午夜免费福利 | 韩国精品一区二区 | 久艹视频在线观看 | 日本中文字幕在线观看 | 麻豆中文字幕 | 国产精品爽爽爽 | 亚洲成人一区二区三区 | 成人精品在线 | 日韩精品免费看 | 日韩av在线免费播放 | 欧美三级a做爰在线观看 | 一级片免费 | 黄网站免费观看 | 成人在线网址 | www.亚洲天堂 |
