查看: 1299|回復: 2
Failed to connect command socket to port 127.0.0.1:8000GLE=0000274D
ID:1117057 發表于 2024-4-17 19:47 來自觸屏版 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
求助大佬們,這個問題怎么解決
ID:883242 發表于 2024-4-17 20:24 | 只看該作者
At the moment i am configuring Proteus VSM to work with the Keil IDE.
I have completed the following steps successfully but "Proteus VSM Monitor-51 Driver" option is not appearing in the combo-box of the (Project --> Target ' Target 1' -->Debug tab-->Use:)
Copy the VDM51.dll file from the MODELS directory of Proteus VSM Installation to the BIN directory of Keil Istallation.
Using NOTEPAD, edited the TOOLS.INI file that is located in the C:\Keil\Tools.ini.
Towards the bottom of this file under the section [C51] found the line
TDRV0=BIN\MON51.DLL ("Keil Monitor-51 Driver")
Immediately below this I add a line that specifies the location of the copied VDM51.DLL .
By default this will be
TDRV1=BIN\VDM51.DLL ("Proteus VSM Monitor-51 Driver").
Started up ISIS and loaded the Design.
Selected the "Remote Debug Monitor" option from the Debug menu. A message to the effect that the "Virtual Debug Monitor is enabled" appeared on the status line (at the bottom of the application window).
Didn't got error messages it is most likely that there is a no problem my your TCP/IP
configuration.
Started up the Keil environment and load in the project which.
Then i Invoked the Options for Target ' Target 1' command from the Project Menu.
Selected the Debug tab of this dialogue form and changed the selection from the Use Simulator option to the Use Keil Monitor-51 Driver option on the right hand side of the dialogue form.
Change the combo-box to select the Proteus VSM Monitor-51 Driver option.
what i am missing or possiable be my problem.
ID:1130439 發表于 2024-9-22 19:32 | 只看該作者
本帖最后由 samuelni 于 2024-9-26 21:02 編輯
Proteus和 Keil IDE必須通過本地的socket( 地址:127.0.0.1 )做進程之間的通信才能實現聯合調試,為此,Proteus(ISIS)端需打開Debug菜單,選擇【Use Remote Debug Monitor】 并啟動【Start/Restart Debugging】 ....... hope this tip helps
主站蜘蛛池模板: 成人午夜在线视频 | 国产黄a三级三级看三级 | 久久91| 一级黄色片视频 | 欧美综合激情 | 日韩专区在线 | 小日子的在线观看免费第8集 | 美日韩一区二区三区 | 在线国产小视频 | 欧美大片黄 | 黄色三级网站 | 狼人色| 黄色国产片 | 精品一区二区三 | 黄色大片免费观看 | 日韩激情网站 | 五月网站 | 亚洲精品在线看 | 长河落日| 成人国产精品久久久网站 | 美女操操操 | 欧美一级片 | 视频一二区 | 深夜视频在线观看 | 糖心vlog精品一区二区 | 天堂av影院 | 日韩国产在线播放 | 一区二区免费在线观看 | 国产乱人伦 | 成人影片在线 | 看黄网站在线观看 | 中文字幕丰满人伦在线 | 成人午夜精品 | av免费播放 | 天天做天天爽 | 看真人一级毛片 | 一级黄色小视频 | 在线播放中文字幕 | 北岛玲av | 欧美精品亚洲精品 | 国产天堂av |
