查看: 1632|回復: 11
有沒有大佬幫忙看看這個單片機程序我寫的是用tcs230然后用數碼管顯示
ID:1121149 發表于 2024-5-17 13:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我現在為了測試我上面的tcs傳感器的程序簡便使用數碼管檢驗我的顏色傳感器是否可以識別,我結果無論是什么顏色都顯示1,但是我的數碼管直接不亮,有大佬可以幫我看一下是單片機程序的問題還是我傳感器的問題?
#include <reg52.h>
#include<math.h>       //Keil library
#include<stdio.h>      //Keil library
#include<INTRINS.H>
#define uchar unsigned char
sbit S2 = P0^0;
sbit S3 = P0^1;
sbit OUT = P0^2;
sbit S0 = P0^3;
sbit S1 = P0^4;
sbit P2_0 = P2^0;
sbit P2_1 = P2^1;
sbit P2_2 = P2^2;
sbit P2_3 = P2^3;
int white_balance_red,white_balance_green,white_balance_blue;
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,
                        0xf8,0x80,0x90};
void delay(unsigned int t) {
    unsigned int i, j;
    for (i = 0; i < t; i++)
        for (j = 0; j < 125; j++);
unsigned int read_pulse() {
          return 100;
void perform_white_balance() {
    S2 = 0;
    S3 = 0;
    delay(100);
    white_balance_red = read_pulse();
    S2 = 1;
    S3 = 1;
    delay(100);
    white_balance_green = read_pulse();
    S2 = 0;
    S3 = 1;
    delay(100);
    white_balance_blue = read_pulse();
unsigned char recognize_color() {
    unsigned int red_pulse, green_pulse, blue_pulse;
    red_pulse = read_pulse();
    green_pulse = read_pulse();
    blue_pulse = read_pulse();
    red_pulse -= white_balance_red;
    green_pulse -= white_balance_green;
    blue_pulse -= white_balance_blue;
    if (red_pulse > 200 && green_pulse > 200 && blue_pulse > 200) {
        return 'W';
    } else if (red_pulse > green_pulse && red_pulse > blue_pulse) {
        return 'R';
    } else if (green_pulse > red_pulse && green_pulse > blue_pulse) {
        return 'G';
    } else if (blue_pulse > red_pulse && blue_pulse > green_pulse) {
        return 'B';
    } else if (red_pulse > 150 && green_pulse > 100 && blue_pulse < 100) {
        return 'Y';
    } else if (red_pulse < 50 && green_pulse < 50 && blue_pulse < 50) {
        return 'K';
    } else {
        return 'U';
void main() {
    unsigned char color;
    perform_white_balance();
    while (1) {
        color = recognize_color_with_white_balance();
        switch (color) {
            case 'W':
        P0=table[0];
        P2_0 = 0;
        delay(5);
        P2_0 = 1;
                break;
            case 'R':   P0=table[0];
                        P2_0 = 0;
                        delay(5);
                        P2_0 = 1;
                break;
            case 'G':   P0=table[0];
        P2_0 = 0;
        delay(5);
        P2_0 = 1;
                break;
            case 'B':   P0=table[0];
        P2_0 = 0;
        delay(5);
        P2_0 = 1;
               break;
            case 'Y':   P0=table[0];
        P2_0 = 0;
        delay(5);
        P2_0 = 1;
                                OLED_Clear();
                break;
            case 'K':   P0=table[0];
   P2_0 = 0;
   delay(5);
   P2_0 = 1;
                break;
ID:879809 發表于 2024-5-17 14:30 | 只看該作者
white_balance_red這幾個變量名字太長了吧,標準c語言支持31字符長度變量,這么寫沒問題。但是C51他不標準啊!查下最多支持幾個字符?
ID:384109 發表于 2024-5-17 15:33 | 只看該作者
編譯沒報錯嗎
ID:161164 發表于 2024-5-17 17:57 | 只看該作者
你這代碼只會顯示0,絕不會顯示1
看不到哪里有讀取tcs230的代碼
ID:1121149 發表于 2024-5-17 19:08 | 只看該作者
發表于 2024-5-17 14:30
white_balance_red這幾個變量名字太長了吧,標準c語言支持31字符長度變量,這么寫沒問題。但是C51他不標準 ...
他可以支持255個但是前32個有效,但是我在keil上可以編譯但燒入到單片機上我的顏色傳感器沒反應
ID:1121149 發表于 2024-5-17 19:29 | 只看該作者
發表于 2024-5-17 14:30
我現在把變量名改短了但是我的數碼管還是不會顯示
ID:1121149 發表于 2024-5-17 21:14 | 只看該作者
lkc8210 發表于 2024-5-17 17:57
你這代碼只會顯示0,絕不會顯示1
看不到哪里有讀取tcs230的代碼
打錯了是0,我的目的就是為了檢驗我的tcs230能不能用
ID:1121149 發表于 2024-5-17 21:22 | 只看該作者
沒有報錯就是用不了
ID:1121149 發表于 2024-5-17 21:57 | 只看該作者
你這代碼只會顯示0,絕不會顯示1
看不到哪里有讀取tcs230的代碼
怎么提取呀我不太會
ID:384109 發表于 2024-5-17 22:15 | 只看該作者
recognize_color_with_white_balance();這個代碼在哪里
ID:1121149 發表于 2024-5-17 23:30 | 只看該作者
人中狼 發表于 2024-5-17 22:15
好像沒有那是用recognize_color就好了嘛
ID:384109 發表于 2024-5-18 19:03 | 只看該作者
forky 發表于 2024-5-17 23:30
while (1) {
        switch (color) {
感覺你的問題很隨意,答復的也很隨意
主站蜘蛛池模板: 日韩av免费 | 超碰在线国产 | 成人三级视频在线观看 | 中文字幕一区二区三区乱码 | 欧美激情xxxx | 日韩综合一区 | 欧美视频在线观看免费 | 日韩精品在线观看视频 | 日韩精品一级 | 亚洲福利视频一区 | 成人aa | 国产日韩在线视频 | 蜜桃视频一区二区 | 91福利视频导航 | 91亚洲精选| 成人做爰www看视频软件 | 一区二区三区视频在线 | 黄色小视频免费看 | 亚洲精品福利 | 国产天堂网 | 国产精品久久免费 | 国产欧美日韩在线观看 | www.婷婷.com | 亚洲精品久久 | 欧美日韩少妇 | 在线播放亚洲 | 国产精品高潮呻吟av | 久久合 | www.伊人网| 亚欧洲精品在线视频免费观看 | 黄色大片视频 | 午夜免费福利 | 欧美日韩综合在线 | a一级黄色片 | 青娱乐99 | 国产黄a三级 | 久久精品中文 | 久久久精品网 | 国产一区二区观看 | 国产又粗又猛又黄又爽无遮挡 | 欧美黄视频 |
