查看: 1337|回復(fù): 8
計(jì)時(shí)器程序增加控制應(yīng)該怎么寫
ID:72649 發(fā)表于 2024-5-21 06:58 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
//99分計(jì)時(shí)器,需要用按鍵開關(guān)P3.2控制計(jì)時(shí)器啟動(dòng),按下按鍵啟動(dòng),松開按鍵停止倒計(jì)時(shí),2秒后熄滅數(shù)碼管,重新按下按鍵,從0開始重新計(jì)時(shí),需要怎么增加?給點(diǎn)思路。
#include"stc8.h"
#include "intrins.h"
#define  uint unsigned int
#define  uchar unsigned char
sbit ge = P3^7;
sbit shi = P3^6;
sbit KEY = P3^2;
uchar count;
char sec,min;
bit flag;
uchar code table[]={0x12,0x3F,0x94,0x1C,0x39,0x58,0x50,0x1F,0x10,0x18,0x11,0x70,0xD2,0x34,0xD0,0xD1};
//uchar code table[]={
//0x03,0x9F,0x25,0x0D,0x99,0x49,0x41,0x1F,0x01,0x09,
//0x11,0xC1,0x63,0x85,0x61,0x71};    //0-9,a-f
sbit c = P1^7;
sbit b = P1^6;
sbit a = P1^5;
sbit h = P1^4;
sbit e = P1^3;
sbit f = P1^2;
sbit g = P1^1;
sbit d = P1^0;
void IO_init();
void delay(uchar n);
void T0_init();
void display();
void IO_init()
    P3M0 = 0xc0; P3M1 = 0x00;
    P1M0 = 0xff; P1M1 = 0x00;
void delay(uchar n)
        uchar j,k;
        for(j=n;j>0;j--)
                for(k=125;k>0;k--);
void T0_init()                                //5毫秒@11.0592MHz
        AUXR &= 0x7F;                        //定時(shí)器時(shí)鐘12T模式
        TMOD &= 0xF0;                        //設(shè)置定時(shí)器模式
        TMOD |= 0x01;                        //設(shè)置定時(shí)器模式
        TL0 = 0x00;                                //設(shè)置定時(shí)初始值
        TH0 = 0xEE;                                //設(shè)置定時(shí)初始值
        TF0 = 0;                                //清除TF0標(biāo)志
//        TR0 = 1;                                //定時(shí)器0開始計(jì)時(shí)
        ET0 = 1;                                //使能定時(shí)器0中斷
        EA = 1;
void display()
        static bit i=0;
        static uchar temp=0;
        P1=0;
        i=~i;
        if(++temp>=200)temp=0;
        if(i==1)
                ge  = 1;
                shi = 0;
                P1=table[sec/10];
                ge  = 0;
                shi = 1;
//                if(temp<100)
                 P1=table[sec%10] ;  //&0xcf;//閃秒   1110  1111
//                else P1=table[min%10];
        IO_init();
        T0_init();
        { if(!KEY)
                   TR0=1;
                                        if(flag)
                        flag=0;
                        if(++count >= 200)
                                count = 0;
                                sec++;
                                if(sec >99)
                                        sec = 0;
                        display();
void TM0_Isr() interrupt 1 //5毫秒
//         if(!KEY)
//                                                 delay(20);
//          if(!KEY)
//            while(!KEY);
        flag=1;
ID:72649 發(fā)表于 2024-5-21 15:08 | 只看該作者
//99s倒計(jì)時(shí)
#include"stc8.h"
sbit ge = P3^7;
sbit shi = P3^6;
sbit KEY = P3^2;
uchar count;
char sec,min;
bit flag;
sbit c = P1^7;
sbit b = P1^6;
sbit a = P1^5;
sbit h = P1^4;
sbit e = P1^3;
sbit f = P1^2;
sbit g = P1^1;
sbit d = P1^0;
void IO_init();
void T0_init();
void display();
void IO_init()
    P3M0 = 0x00; P3M1 = 0x00;
    P1M0 = 0x00; P1M1 = 0x00;
void delay(uint n)
        uchar j,k;
        for(j=n;j>0;j--)
                for(k=125;k>0;k--);
        EA = 1;
void display()
        static bit i=0;
        P1=0;
        i=~i;
        if(i==1)
                ge  = 1;
                shi = 0;
                P1=table[sec/10];
                ge  = 0;
                shi = 1;
//                if(temp<100)
        IO_init();
        T0_init();
                                                 if(!KEY)
                                                        TR0=1;
                                           if(flag)
                        flag=0;
                        if(++count >= 200)
                                count = 0;
                                sec++;
                                if(sec >99)
                                  sec = 0;
                        display();
        flag=1;
}這樣按鍵按下計(jì)數(shù)開始,現(xiàn)在我要求按下計(jì)數(shù),松開停止并熄滅,下次按下從0開始計(jì)數(shù)。
ID:624769 發(fā)表于 2024-5-21 18:49 | 只看該作者
把              if(!KEY)       TR0=1;
改成    TR0 =!KEY;
ID:161164 發(fā)表于 2024-5-22 10:19 | 只看該作者
ID:72649 發(fā)表于 2024-5-22 20:58 來自觸屏版 | 只看該作者
188610329 發(fā)表于 2024-5-21 18:49
把              if(!KEY)       TR0=1;
改成    TR0 =!KEY;
TR0關(guān)閉了,顯示要延時(shí)10秒熄滅怎么修改?
ID:72649 發(fā)表于 2024-5-22 21:31 | 只看該作者
把              if(!KEY)       TR0=1;
改成    TR0 =!KEY;
要求:
1持續(xù)觸發(fā)計(jì)時(shí)開始,觸發(fā)發(fā)斷開計(jì)時(shí)停止,保持計(jì)時(shí)停止的數(shù)值10秒。然后數(shù)碼管熄滅。
2,在數(shù)碼管保持上一次計(jì)時(shí)的10秒鐘內(nèi),重新觸發(fā),計(jì)時(shí)馬上重新開始,觸發(fā)結(jié)束計(jì)時(shí)保持10秒,然后熄滅
3,數(shù)碼管熄滅后.重新觸發(fā)計(jì)時(shí),馬上點(diǎn)亮數(shù)碼從0開始計(jì)時(shí)同上。
ID:72649 發(fā)表于 2024-5-22 21:32 | 只看該作者
按照你的修改不能計(jì)時(shí)了。
要求:
ID:74687 發(fā)表于 2024-5-23 06:47 | 只看該作者
你現(xiàn)在按下應(yīng)該能正常計(jì)時(shí)了,就是松開再按下,不能從0開始?
在if(!key)后面加個(gè)
else{
   if(flag){
              flag =0;
              if(count >200){
                  count = 0;
                  clear_sec++;
                 if(clear_sec > 2){
                       sec =0;
                      TR0 = 0;
大體就是這個(gè)思路,把括號(hào)補(bǔ)齊。
ID:161164 發(fā)表于 2024-5-23 11:38 | 只看該作者
hjx5548 發(fā)表于 2024-5-22 21:32
要求:
1持續(xù)觸發(fā)計(jì)時(shí)開始,觸發(fā)發(fā)斷開計(jì)時(shí)停止,保持計(jì)時(shí)停止的數(shù)值10秒。 ...
把改好的代碼發(fā)出來啊
主站蜘蛛池模板: 一区二区三区四区在线视频 | 激情av网| 日韩不卡在线观看 | 三级福利视频 | 亚洲在线免费观看 | 欧美一区二区三区在线视频 | 99精品网站 | 亚洲一二区 | 91av精品 | 日韩一区二区中文字幕 | 毛片在线观看网站 | 天堂va蜜桃一区二区三区 | 九九综合网 | 二区三区在线观看 | 国产欧美成人 | 午夜精品一区二区三区在线播放 | 欧美一级黄色录像 | 高清无码| 欧美视频精品 | 五月天丁香 | 精品视频久久 | 视频一区二区三区在线观看 | 亚洲精品免费在线 | 国产成人在线播放 | 一级毛片久久久 | 免费在线观看黄色片 | 亚洲毛片网| 中文字幕在线一区 | a级片免费观看 | 午夜伦理视频 | 亚洲成人av在线播放 | 欧美日韩激情视频 | 成人在线视频免费 | 中文字幕日韩高清 | 国产自偷自拍 | 一级大片| 老女人丨91丨九色 | 伊人黄色 | 亚洲欧美综合网 | 欧美视频在线观看 | 中文字幕亚洲一区 |
