查看: 1461|回復: 5
求一個純硬件呼吸燈的思路?
ID:1088099 發(fā)表于 2024-5-30 10:31 | 顯示全部樓層 |閱讀模式
想做點小玩意玩玩,突然就想到了呼吸燈,又想到了能不能純硬件實現呼吸燈。各位大佬有沒有思路?555定時器之類的
ID:123289 發(fā)表于 2024-5-30 13:54 | 顯示全部樓層
不復雜:雙穩(wěn),周期斜坡電流,驅動LED。
ID:401564 發(fā)表于 2024-5-30 14:30 | 顯示全部樓層
運放輸出三角波,后面加一個電壓跟隨器,輸出加個電阻串聯(lián)就可以了
不管是理論上還是實際上,這都是一個相對簡單的電路的,我實際上也做過這個小電路
但是,意義何在?
ID:69038 發(fā)表于 2024-5-30 15:10 | 顯示全部樓層
百度一下關鍵字:“LM358呼吸燈電路”,有你想要的。
ID:961114 發(fā)表于 2024-5-30 16:23 | 顯示全部樓層
#include "reg51.h"
#include "intrins.h"
#define CYCLE       0x1000
sfr     P_SW2   =   0xba;
sfr     PWMSET      =   0xF1;
sfr     PWMCFG01    =   0xF6;
sfr     PWMCFG23    =   0xF7;
sfr     PWMCFG45    =   0xFE;
#define PWM0C       (*(unsigned int  volatile xdata *)0xFF00)
#define PWM0CH      (*(unsigned char volatile xdata *)0xFF00)
#define PWM0CL      (*(unsigned char volatile xdata *)0xFF01)
#define PWM0CKS     (*(unsigned char volatile xdata *)0xFF02)
#define PWM0TADC    (*(unsigned int  volatile xdata *)0xFF03)
#define PWM0TADCH   (*(unsigned char volatile xdata *)0xFF03)
#define PWM0TADCL   (*(unsigned char volatile xdata *)0xFF04)
#define PWM0IF      (*(unsigned char volatile xdata *)0xFF05)
#define PWM0FDCR    (*(unsigned char volatile xdata *)0xFF06)
#define PWM00T1     (*(unsigned int  volatile xdata *)0xFF10)
#define PWM00T1H    (*(unsigned char volatile xdata *)0xFF10)
#define PWM00T1L    (*(unsigned char volatile xdata *)0xFF11)
#define PWM00T2H    (*(unsigned char volatile xdata *)0xFF12)
#define PWM00T2     (*(unsigned int  volatile xdata *)0xFF12)
#define PWM00T2L    (*(unsigned char volatile xdata *)0xFF13)
#define PWM00CR     (*(unsigned char volatile xdata *)0xFF14)
#define PWM00HLD    (*(unsigned char volatile xdata *)0xFF15)
sfr     P0M1    =   0x93;
sfr     P0M0    =   0x94;
sfr     P1M1    =   0x91;
sfr     P1M0    =   0x92;
sfr     P2M1    =   0x95;
sfr     P2M0    =   0x96;
sfr     P3M1    =   0xb1;
sfr     P3M0    =   0xb2;
sfr     P4M1    =   0xb3;
sfr     P4M0    =   0xb4;
sfr     P5M1    =   0xc9;
sfr     P5M0    =   0xca;
void PWM0_Isr() interrupt 22
    static bit dir = 1;
    static int val = 0;
    if (PWMCFG01 & 0x08)
        PWMCFG01 &= ~0x08;                      //清中斷標志
        if (dir)
            val++;
            if (val >= CYCLE) dir = 0;
            val--;
            if (val <= 1) dir = 1;
        _push_(P_SW2);
        P_SW2 |= 0x80;
        PWM00T2 = val;
        _pop_(P_SW2);
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    PWMSET = 0x01;                              //使能PWM0模塊(必須先使能模塊后面的設置才有效)
    P_SW2 = 0x80;
    PWM0CKS = 0x00;                             // PWM0時鐘為系統(tǒng)時鐘
    PWM0C = CYCLE;                              //設置PWM0周期
    PWM00T1= 0x0000;
    PWM00T2= 0x0001;
    PWM00CR= 0x80;                              //使能PWM00輸出
    P_SW2 = 0x00;
    PWMCFG01 = 0x05;                            //啟動PWM0模塊并使能PWM0中斷
    EA = 1;
    while (1);
ID:996773 發(fā)表于 2024-5-31 14:58 | 顯示全部樓層
樓主的想法無意義,這本來是在軟件系統(tǒng)中比較優(yōu)越的設計,例如,菜單設定欄可以用呼吸燈
效果表示當前選定,編程時鐘調整分鐘的時候,讓分鐘字體產生呼吸效果,其他字體常亮。樓主
僅僅讓一盞燈實現硬件呼吸效果,怎么用,如何用,顯擺都沒技術含量
主站蜘蛛池模板: 电家庭影院午夜 | 999毛片| 五月激情综合网 | 国产精品久久久久久久久久久久久 | 国产探花视频在线观看 | 国产一级一片免费播放放a 免费国产视频 | 闷骚老干部cao个爽 欧美区一区二 | 欧美三根一起进三p | 国产美女自拍视频 | 日韩欧美在线视频观看 | 国产成人免费视频 | 国精产品99永久一区一区 | 欧美日韩成人在线 | 日韩免费观看 | av免费看网站 | 亚洲精品欧美 | 视频在线一区 | 性做久久久久久 | 国产精品一区二区在线播放 | 激情视频网 | 精品视频免费观看 | 国产欧美在线 | 成人精品一区二区三区 | www.国产精品 | 一区二区三区中文字幕 | 日韩精品网 | 国产一区二区不卡 | 日韩视频免费 | 五月婷婷网站 | 精品欧美在线 | 久久久精品国产sm调教 | 久草福利在线视频 | 老司机午夜免费精品视频 | 欧美一区二区在线 | 性爱视频日本 | 色妞网 | 精品欧美日韩 | 在线成人小视频 | 久久久精品在线观看 | 四虎黄色网址 | 欧美一级淫片免费视频魅影视频 |
