這是學(xué)單片機(jī)以來(lái)做的第二個(gè)實(shí)驗(yàn)內(nèi)容 ,文件含proteus仿真工程以及keil源文件,功能(如下)都已經(jīng)實(shí)現(xiàn)。新人第一次發(fā)分享的帖子,請(qǐng)大家多多指教。
單片機(jī)功能;在二個(gè)單片機(jī)之間編程實(shí)現(xiàn)串行口通訊,發(fā)送方以流水燈字節(jié)碼作為發(fā)送數(shù)據(jù)定時(shí)發(fā)送,并在接收方的 P0 口上顯示接收到的字節(jié),在數(shù)碼屏上以十六進(jìn)制顯示,中間有按鈕可以啟動(dòng)和暫停。
發(fā)送方源碼- #include<reg51.h>
- #define uchar unsigned char
- uchar code Tab[16]={0xC0,/*0*/
- 0xF9,/*1*/
- 0xA4,/*2*/
- 0xB0,/*3*/
- 0x99,/*4*/
- 0x92,/*5*/
- 0x82,/*6*/
- 0xF8,/*7*/
- 0x80,/*8*/
- 0x90,/*9*/
- 0x88,/*A*/
- 0x83,/*B*/
- 0xC6,/*C*/
- 0xA1,/*D*/
- 0x86,/*E*/
- 0x8E /*F*/};
- uchar Counter=0;Second_1=0,Second_0=0;
- sbit Key = P3^2;
- void Display(void);
- void Delay(void);
- void UARTInit(void);
- void UARTSend(uchar data1);
- void timer0Init(void);
- void main()
- P1=0xff;//給流水燈初始化值
- UARTInit();//串口初始化
- timer0Init();//定時(shí)器初始化
- while(1)
- if(Key == 0)
- EA = 1; //打開(kāi)總中斷
- if(Key == 1)
- EA = 0; //關(guān)閉總中斷
- Display();//數(shù)碼管顯示函數(shù)
- switch (P1)//根據(jù)P1的值給數(shù)碼管賦值
- case 0xFE:{Second_1 = 15, Second_0 = 14; break;}
- case 0xFD:{Second_1 = 15, Second_0 = 13; break;}
- case 0xFB:{Second_1 = 15, Second_0 = 11; break;}
- case 0xF7:{Second_1 = 15, Second_0 = 7 ; break;}
- case 0xEF:{Second_1 = 14, Second_0 = 15; break;}
- case 0xDF:{Second_1 = 13, Second_0 = 15; break;}
- case 0xBF:{Second_1 = 11, Second_0 = 15; break;}
- case 0x7F:{Second_1 = 7 , Second_0 = 15; break;}
- default: break;
- P0=Tab[Second_1];
- P2=0x01;
- Delay();
- P2=0x00;
- P0=Tab[Second_0];
- P2=0x02;
- Delay();
- P2=0x00;
- void timer0Init()
- ET0 = 1;//打開(kāi)定時(shí)器0中斷
- TR0 = 1; //啟動(dòng)定時(shí)器0
- REN = 1;//允許串口接收
- TMOD |= 0X01; //定時(shí)器工作模式1,16位定時(shí)模式
- TH0=0x3c;
- TL0=0xb0;
- //串口初始化
- void UARTInit()
- ES = 1; //打開(kāi)串口中斷
- SM0 = 0; SM1 = 1;//串口工作方式1,8位UART波特率可變
- REN = 1;//串口允許接收
- TR1 = 1;//啟動(dòng)定時(shí)器1
- TMOD |= 0x20;//定時(shí)器1,工作模式2 8位自動(dòng)重裝
- TH1 = 0xfd;
- TL1 = 0xfd;//設(shè)置比特率9600
- void Timer0() interrupt 1
- ET0=0;
- TH0=0x3c;
- TL0=0xb0;
- Counter++;
- if(Counter==20)
- Counter=0;
- P1<<=1;//左移一位
- P1|=0x01;//最后一位補(bǔ)1
- if(P1==0xff)//檢測(cè)是否移到最左端
- P1=0xfe;
- UARTSend(P1);//串口發(fā)送流水燈的值
- ET0=1;
- // 串口發(fā)送函數(shù)
- SBUF = data1;
- while(!TI);
- TI = 0;
- void Delay(void)
- uchar data i;
- for(i=500;i>0;i--);
復(fù)制代碼 接收方源碼- #include <reg51.h>
- 0xF9,/*1*/
- 0xA4,/*2*/
- 0xB0,/*3*/
- 0x99,/*4*/
- 0x92,/*5*/
- 0x82,/*6*/
- 0xF8,/*7*/
- 0x80,/*8*/
- 0x90,/*9*/
- 0x88,/*A*/
- 0x83,/*B*/
- 0xC6,/*C*/
- 0xA1,/*D*/
- 0x86,/*E*/
- 0x8E /*F*/};
- uchar receivedData = 0;//串口接收數(shù)據(jù)
- void Delay(void);
- void main()
- P1=0xff;//給初始化值
- UARTInit(); // 初始化串口
- while (1)
- switch (P1)
- default: break;
- P0=Tab[Second_1];
- P2=0x01;
- Delay();
- P2=0x00;
- P0=Tab[Second_0];
- P2=0x02;
- Delay();
- P2=0x00;
- //串口初始化
- void UARTInit()
- REN = 1;//串口允許接收
- TH1 = 0xfd;
- // 串口接收函數(shù)
- void UART() interrupt 4
- if(RI)
- RI = 0;
- receivedData = SBUF;
- P1 = receivedData;
- else
- TI = 0;
- void Delay(void)
- uchar data i;
Proteus8.10 仿真程序:
基于單片機(jī)的雙機(jī)通信電路設(shè)計(jì).7z
(66.14 KB, 下載次數(shù): 2)
2024-6-26 14:21 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
