查看: 732|回復: 2
能找一下程序哪有問題嗎?
ID:1128696 發表于 2024-7-10 20:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#include <intrins.h>
#define TM1638_STB P1_2
#define TM1638_DIO P1_0
#define TM1638_CLK P1_1
#define TM1638_CMD_DATA 0x40
#define TM1638_CMD_ADDRESS 0xC0
#define TM1638_CMD_DISPLAY 0x80
#define TM1638_DISPLAY_ON 0x08
#define TM1638_DISPLAY_OFF 0x00
static unsigned char code SEG_PATTERN[] = {
    0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F
void TM1638_Init() {
    TM1638_STB = 1;
    TM1638_SendCommand(TM1638_CMD_DISPLAY | TM1638_DISPLAY_ON);
void TM1638_SendByte(unsigned char data) {
    unsigned char i;
    for (i = 0; i < 8; i++) {
        TM1638_CLK = 0;
        _nop_();
        TM1638_DIO = data & 0x01;
        data >>= 1;
        _nop_();
        TM1638_CLK = 1;
        _nop_();
void TM1638_SendCommand(unsigned char cmd) {
    TM1638_STB = 0;
    _nop_();
    TM1638_SendByte(cmd);
    TM1638_STB = 1;
    _nop_();
void TM1638_DisplayDigit(unsigned char digit, unsigned char num) {
    TM1638_SendCommand(TM1638_CMD_ADDRESS | (digit << 1));
    TM1638_STB = 0;
    _nop_();
    TM1638_SendByte(TM1638_CMD_DATA);
    TM1638_SendByte(SEG_PATTERN[num % 10]);
    TM1638_STB = 1;
void Delay50ms() {
    unsigned char i, j;
    for (i = 0; i < 90; i++) {
        for (j = 0; j < 163; j++);
void main() {
    unsigned int count = 0;
    unsigned char btn_status = 0;
    TM1638_Init();
    while (1) {
        TM1638_DisplayDigit(0, count % 10);
        TM1638_DisplayDigit(1, (count / 10) % 10);
        TM1638_DisplayDigit(2, (count / 100) % 10);
        TM1638_DisplayDigit(3, (count / 1000) % 10);
        btn_status = TM1638_ReadButtons();
        if (btn_status & 0x01) {
            Delay50ms();
            while (btn_status & 0x01);
            Delay50ms();
            count++;
        if (btn_status & 0x02) {
            Delay50ms();
            while (btn_status & 0x02);
            Delay50ms();
            count--;
        Delay50ms();
unsigned char TM1638_ReadButtons() {
    unsigned char i, btns = 0;
    TM1638_SendCommand(TM1638_CMD_ADDRESS | 0x02);
    TM1638_STB = 0;
    _nop_();
    TM1638_SendByte(0x42);
    _nop_();
    for (i = 0; i < 4; i++) {
        btns |= TM1638_DIO << i;
        TM1638_CLK = 0;
        _nop_();
        TM1638_CLK = 1;
        _nop_();
    TM1638_STB = 1;
    return btns;
ID:161164 發表于 2024-7-10 21:04 | 只看該作者
P1_2/P1_0/P1_1沒有定義
ID:1109793 發表于 2024-7-11 07:15 | 只看該作者
編譯時顯示什么內容?不過那三個IO是不是應該用sbit,而不是define
主站蜘蛛池模板: 久久久精品在线观看 | 日韩欧美综合 | 午夜亚洲精品 | 就要干就要操 | 亚洲天堂v | 亚洲第一在线 | 久久精品导航 | 日韩欧美黄色 | 丰满岳乱妇一区二区 | 九九国产精品视频 | 亚洲精品999 | 日本精品国产 | 精品福利在线 | 日韩国产在线播放 | 日韩视频在线观看免费 | 午夜综合网 | 欧美日韩小视频 | 免费黄色小视频 | 国产午夜精品一区二区三区嫩草 | 97免费在线视频 | 成人在线视频观看 | 日韩精品国产精品 | 久久合| 亚洲成人国产 | 狠狠的日 | 国产精品人人做人人爽人人添 | 亚洲免费看片 | 三级免费网站 | 性色av一区二区 | 丁香六月激情 | 国产精品福利在线 | 一区二区三区免费看 | 在线看日韩 | 黄色国产视频 | 日韩精品在线免费观看 | 黄色免费毛片 | 免费av不卡 | 日韩视频在线播放 | 欧美精品福利 | 日本不卡视频 | 日韩欧美国产高清91 |
