查看: 967|回復(fù): 0
MSP430單片機(jī)多通道ADC采集,串口無(wú)法打印ADC值
ID:1128884 發(fā)表于 2024-7-13 10:20 | 顯示全部樓層 |閱讀模式
static void ConfigADCInit(void)
    // 復(fù)位GPIO
    GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN0);
    GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN1);
    GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN2);
    GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN5);
    GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN6);
    // 配置ADC參數(shù)
    ADC12_A_init(ADC12_A_BASE,ADC12_A_SAMPLEHOLDSOURCE_SC, ADC12_A_CLOCKSOURCE_ADC12OSC, ADC12_A_CLOCKDIVIDER_1);
    // 啟用ADC12_A模塊
    ADC12_A_enable(ADC12_A_BASE);
    // 配置ADC12_A模塊的采樣計(jì)時(shí)器,以控制采樣/保持信號(hào)的持續(xù)時(shí)間以及采樣過(guò)程中的時(shí)鐘周期數(shù)
    ADC12_A_setupSamplingTimer(ADC12_A_BASE,ADC12_A_CYCLEHOLD_128_CYCLES,ADC12_A_CYCLEHOLD_4_CYCLES,ADC12_A_MULTIPLESAMPLESENABLE);
    // 配置ADC P6.0
    ADC12_A_configureMemoryParam  ADCA0_InitStructure = {
    .inputSourceSelect = ADC12_A_INPUT_A0,                  // A0作為輸入通道
    .endOfSequence = ADC12_A_NOTENDOFSEQUENCE,              // 不是序列結(jié)束
    .memoryBufferControlIndex = ADC12_A_MEMORY_0,           // 內(nèi)存0
    .negativeRefVoltageSourceSelect = ADC12_A_VREFPOS_AVCC, // 參考電壓為AVCC
    .positiveRefVoltageSourceSelect = ADC12_A_VREFNEG_AVSS, // 參考電壓為AVSS
    // 配置ADC P6.1
    ADC12_A_configureMemoryParam  ADCA1_InitStructure = {
    .inputSourceSelect = ADC12_A_INPUT_A1,
    .memoryBufferControlIndex = ADC12_A_MEMORY_1,
    // 配置ADC P6.2
    ADC12_A_configureMemoryParam  ADCA2_InitStructure = {
    .inputSourceSelect = ADC12_A_INPUT_A2,
    .memoryBufferControlIndex = ADC12_A_MEMORY_2,
    // 配置ADC P6.5
    ADC12_A_configureMemoryParam  ADCA5_InitStructure = {
    .inputSourceSelect = ADC12_A_INPUT_A5,
    .memoryBufferControlIndex = ADC12_A_MEMORY_5,
    // 配置ADC P6.6
    ADC12_A_configureMemoryParam ADCA6_InitStructure = {
    .endOfSequence = ADC12_A_ENDOFSEQUENCE,
    .inputSourceSelect = ADC12_A_INPUT_A6,
    .memoryBufferControlIndex = ADC12_A_MEMORY_6,
    // 配置ADC
    ADC12_A_configureMemory(ADC12_A_BASE ,&ADCA0_InitStructure);
    ADC12_A_configureMemory(ADC12_A_BASE ,&ADCA1_InitStructure);
    ADC12_A_configureMemory(ADC12_A_BASE ,&ADCA2_InitStructure);
    ADC12_A_configureMemory(ADC12_A_BASE ,&ADCA5_InitStructure);
    ADC12_A_configureMemory(ADC12_A_BASE ,&ADCA6_InitStructure);
    // 開(kāi)始轉(zhuǎn)換
    ADC12_A_startConversion(ADC12_A_BASE, ADC12_A_MEMORY_0, ADC12_A_REPEATED_SEQOFCHANNELS);
    ADC12_A_startConversion(ADC12_A_BASE, ADC12_A_MEMORY_1, ADC12_A_REPEATED_SEQOFCHANNELS);
    ADC12_A_startConversion(ADC12_A_BASE, ADC12_A_MEMORY_2, ADC12_A_REPEATED_SEQOFCHANNELS);
    ADC12_A_startConversion(ADC12_A_BASE, ADC12_A_MEMORY_3, ADC12_A_REPEATED_SEQOFCHANNELS);
#pragma vector=ADC12_VECTOR
__interrupt void ADC12_interrupt (void)
    static unsigned int index = 0;
    switch (__even_in_range(ADC12IV,34)){
        case  0: break;   //Vector  0:  No interrupt
        case  2: break;   //Vector  2:  ADC overflow
        case  4: break;   //Vector  4:  ADC timing overflow
        case  6: break;   //Vector  6:  ADC12IFG0
        case  8: break;   //Vector  8:  ADC12IFG1
        case 10: break;   //Vector 10:  ADC12IFG2
        case 12: break;   //Vector 12:  ADC12IFG3
        case 14: break;   //Vector 14:  ADC12IFG4
        case 16: break;   //Vector 16:  ADC12IFG5
        case 18:
            A0results[index] = ADC12_A_getResults(ADC12_A_BASE, ADC12_A_MEMORY_0);           // Move A0 results, IFG is cleared
            UART_printf(USCI_A1_BASE,"%f",A0results[index] / 0xffff * 3.3);
            A1results[index] = ADC12_A_getResults(ADC12_A_BASE, ADC12_A_MEMORY_1);           // Move A1 results, IFG is cleared
            UART_printf(USCI_A1_BASE,"%f",A1results[index] / 0xffff * 3.3);
            A2results[index] = ADC12_A_getResults(ADC12_A_BASE, ADC12_A_MEMORY_2);           // Move A2 results, IFG is cleared
            UART_printf(USCI_A1_BASE,"%f",A2results[index] / 0xffff * 3.3);
            A5results[index] = ADC12_A_getResults(ADC12_A_BASE, ADC12_A_MEMORY_5);           // Move A5 results, IFG is cleared
            UART_printf(USCI_A1_BASE,"%f",A5results[index] / 0xffff * 3.3);
            A6results[index] = ADC12_A_getResults(ADC12_A_BASE, ADC12_A_MEMORY_6);           // Move A6 results, IFG is cleared
            UART_printf(USCI_A1_BASE,"%f",A6results[index] / 0xffff * 3.3);
            index++;
            if (index == 8)
              (index = 0);
            break;   //Vector 18:  ADC12IFG6
        case 20: break;   //Vector 20:  ADC12IFG7
        case 22: break;   //Vector 22:  ADC12IFG8
        case 24: break;   //Vector 24:  ADC12IFG9
        case 26: break;   //Vector 26:  ADC12IFG10
        case 28: break;   //Vector 28:  ADC12IFG11
        case 30: break;   //Vector 30:  ADC12IFG12
        case 32: break;   //Vector 32:  ADC12IFG13
        case 34: break;   //Vector 34:  ADC12IFG14
        default: break;
串口無(wú)法打印ADC值
主站蜘蛛池模板: 四虎av在线 | 黄视频网站在线观看 | 亚洲精品在线免费 | 日韩国产一区 | 伊人色播 | 久久黄色大片 | 国产激情在线视频 | 国产成人精品av在线观 | www.日本在线 | 免费观看全黄做爰视频 | 天天拍天天操 | 日日夜夜草 | 亚欧在线观看 | 精品伊人久久 | 日韩欧美亚洲国产 | 日韩一区二区不卡 | 欧美视频在线观看免费 | 综合久久久 | 欧美啪啪网 | 国产精品自拍一区 | 国产女优在线 | 日韩视频免费在线观看 | 国产中文字幕一区 | 欧美午夜精品 | 色综合一区二区 | 亚洲国产一区在线观看 | 成人精品在线观看 | 欧美色综合天天久久综合精品 | 亚洲精品久久 | 色婷婷久久综合 | 一级片在线视频 | 日韩欧美亚洲 | 天天干夜夜草 | a在线视频 | 欧美黄色一级 | 日本中文字幕一区 | 日本熟妇毛耸耸xxxxxx | 精品www | 官场少妇尤物雪白高耸 | 欧美一区二区三区在线 | 特黄一级视频 |
