查看: 1108|回復: 1
賽元微單片機ADC初始化問題
在NTC那里我接了4.7K的電阻,也就是下圖CN3的位置,理應ADC得返回2048左右的ADC值,但是返回出來只有200多,我的單片機芯片SC92F7411,用過他們賽元微里面的例程代碼,返回出來的值也是一樣,請問我應該怎么改,請大伙指點迷津,謝謝。。。
void ADC_Init(uint Channel);
unsigned int ADC_GetAverageValue(void);
//unsigned int ADCValue = 0x0000;
uint8_t  tmpValue;
bit AdcFlag = 0;
float  ADC_Voltage;                                     //ADC電壓
float NTC_Temperature;     //NTC溫度值
uint32_t xdata ADC_Value;           //ADC值
/***********ADC采樣頻率選擇*************/
enum ADCFreq {F32=0,F24,F16,F12,F8,F6,F4,F3};
*函數名稱:void ADC_Init(uint Channel,uchar ADCFreq)
*函數功能:ADC初始化
*入口參數:void
*出口參數:void
        ADCCON = 0X80|Channel;                //開啟ADC,ADC采樣頻率為3M ,選擇Channel位ADC采樣口
        if(Channel<8)
                ADCCFG0 = 1<<Channel;   //設置Channel作為采樣口
                ADCCFG1 = 1<<(Channel-8);   //設置Channel作為采樣口
        //ADCCFG2 = F8;
        IE |= 0X40;        //開啟ADC中斷
*函數名稱:uint ADC_GetAverageValue(uint Channel,ADC_SamplesNum_TypeDef ADC_SamplesNum)
*函數功能:ADC采樣取平均值
*入口參數:
ADC_SamplesNum_TypeDef ADC_SamplesNum:采樣次數
*出口參數:
uint:多次采樣平均值
uint32_t ADC_GetAverageValue(void)
        ADCCON |= 0X40;             //開始一次ADC轉換
        while(!AdcFlag);          //等待ADC轉換完成
        AdcFlag = 0;
        tmpValue=(ADCVH<<4)+(ADCVL>>4);     //獲取單次轉換值
        return tmpValue;                        //返回平均值
void ADC_Interrupt(void) interrupt 6
        ADCCON&=~(0X20);  //清中斷標志位
        AdcFlag = 1;
//NTC電阻值
uint32_t code ntc_r[100]=
        //180°~ 189°
        1548,1514,1480,1447,1414,1383,1353,1323,1294,1266,
        //190°~199°
        1239,1212,1186,1160,1136,1112,1088,1065,1043,1021,
        //200°~209°
        1000,978,957,937,917,897,878,860,841,824,
        //210~219°
        807,790,773,758,742,727,712,698,683,670,
        //220°~229°
        656,643,630,618,606,594,582,571,560,549,
// 定義常量
#define R_FIXED 4700.0 // 固定電阻值4.7kΩ
#define B_CONST 4537.0 // NTC的B常數
#define T0 473.15 // 200℃轉換為開爾文
#define R0 1000.0 // NTC在200℃時的電阻值1kΩ
函數功能:計算溫度的值
參數:無
返回值:無
備注:無
float calculate_temperature(float voltage)
    float R_ntc;
    float V_supply = 5.0; // 電源電壓5.0V
          float tmp1 = 0.0;
                float tmp2 = 0.0;
    // 計算NTC電阻值
    R_ntc = R_FIXED * (V_supply / voltage - 1);   //voltage是ADC值換算過來的電壓
    // 計算溫度(開爾文)
                tmp1 = R_ntc/R0;
                tmp2 = log(tmp1);
                tmp1 = tmp2/B_CONST;
                tmp2 = 1/T0;
                tmp1 = (tmp1+tmp2);
                tmp2 = 1.0/tmp1;
                if(tmp2 <= 274)tmp2 = 274;
                // 轉換為攝氏度
                tmp2 -= 273.15;
                //tmp1 = tmp2+0.05;   //溫度補償
                //返回溫度
    return tmp2;
ID:404160 發表于 2024-9-2 14:13 | 只看該作者
試試這段程序,如果還是一樣,可能是硬件問題
#include "sc92f7411.h"
// 假設ADC模塊的基地址為0x50000000
#define ADC_BASE 0x50000000
// ADC控制寄存器定義
#define ADC_CR1 *(volatile unsigned int *)(ADC_BASE)
#define ADC_CR2 *(volatile unsigned int *)(ADC_BASE + 4)
#define ADC_DR  *(volatile unsigned short *)(ADC_BASE + 8)
// ADC時鐘使能(請根據實際情況修改)
void ADC_ClockInit() {
// ADC初始化
void ADC_Init() {
    ADC_ClockInit();
    // 配置ADC控制寄存器
    ADC_CR1 = 0x00; // 清除控制寄存器
    ADC_CR2 = 0x00; // 清除控制寄存器
    // 設置采樣時間、通道等(根據數據手冊配置)
    ADC_CR1 |= (1 << 12); // 設置采樣時間
    ADC_CR2 |= (3 << 0);  // 選擇通道3
    // 使能ADC
    ADC_CR2 |= (1 << 0);
// 啟動ADC轉換
void ADC_StartConvert() {
    // 啟動ADC轉換
    ADC_CR2 |= (1 << 3);
// 讀取ADC轉換結果
uint16_t ADC_ReadValue() {
    // 等待轉換完成(可通過中斷方式)
    return ADC_DR;
主站蜘蛛池模板: 亚洲无av在线中文字幕 | 日本精品免费 | 婷婷99| 在线观看av免费 | 视频一区二区在线 | 国产精品毛片一区二区在线看 | av青青草原 | 日韩小视频 | 黄色小视频免费观看 | 久久天天躁狠狠躁夜夜躁2014 | 久久成人免费视频 | 久久99国产精品 | 日韩在线视频免费 | 国产日韩欧美亚洲 | 中文字幕在线一区二区三区 | 黄色在线小视频 | 91亚色视频| 日韩国产一区 | 国产性色av | 日韩免费小视频 | 日韩高清在线播放 | 综合久久99 | 国产成人午夜高潮毛片 | 中文字幕在线视频观看 | 欧美一区在线视频 | 四虎影院在线 | 在线观看日韩av | 狠狠干av | 麻豆国产一区二区三区四区 | 国产美女一区二区三区 | 国产性猛交 | 色女人影院 | 亚洲最大黄色网址 | 精品久久免费视频 | 欧美啪啪网站 | 少妇一级淫片免费看 | 人人爽人人澡 | 亚洲毛片av | 日韩免费一区二区 | 久久精品2 | 国产在线一区二区 |
