查看: 1095|回復: 4
如何使用Arduino設計延時繼電器?
如題,求大俠!
ID:444392 發表于 2024-8-31 10:26 | 只看該作者
簡單程序直接用等待語句,復雜場合用中斷?
ID:155507 發表于 2024-8-31 12:50 | 只看該作者
給你個參考。
int led_pin = 18;
int relay_pin = 12;
int sensor_pin = 4;
bool detected = false;
bool stop_relay = false;
unsigned long motion_stopped_time = 0; //will track the elapsed time after the motion stop
void setup() {
  pinMode(led_pin, OUTPUT);
  pinMode(relay_pin, OUTPUT);
  pinMode(sensor_pin, INPUT_PULLUP);
  Serial.begin(9600);
void loop(){
  if(digitalRead(sensor_pin) == HIGH){ //the sensor has detected motion
        //enclose the code here so it only executes once when motion is detected
        if(detected == false){
            Serial.println("Motion detected!");
            detected = true;
            digitalWrite(led_pin, HIGH); //turn led on
            digitalWrite(relay_pin, HIGH); //switch the relay on
  }else{ //the sensor has stopped detecting motion
      if(detected == true){ //execute this only once when motion stops
            Serial.println("Motion stopped!");
            detected = false;
            digitalWrite(led_pin, LOW); //turn the led off
            motion_stopped_time = millis(); //remember the current time
            stop_relay = true;
       }else{
          if(stop_relay == true){ // ensures that this block will only execute once after the delay timer logic below
            //the current millis() time is 60sec more than the remembered time when the motion stopped
            if(millis() - motion_stopped_time >= 60000){
                digitalWrite(relay_pin, LOW); //switch the relay off
                stop_relay = false;
ID:291549 發表于 2024-8-31 14:18 | 只看該作者
1、輸入定時延時函數數值。2、為了模擬,輸出為13,板子上面有LED觀察,可改為其它引腳為繼電器輸出。
3、2、3設定為定時開始和停止按鍵。
由于要求未說明白,本例使用MsTimer2定時器和硬件中斷,以提高穩定性。
  1. #include <MsTimer2.h>
  2. // 設定各類函數,定時、開始、停止、執行
  3. volatile int atime;
  4. volatile boolean start;
  5. volatile boolean stop;
  6. volatile boolean led;
  7. void msTimer2_func() {
  8.   start = start;
  9.   digitalWrite(13,start);
  10. }
  11. void attachInterrupt_fun_RISING_2() {
  12.   // MsTime2定時器
  13.   MsTimer2::set(atime, msTimer2_func);
  14.   MsTimer2::start();
  15. }
  16. void attachInterrupt_fun_RISING_3() {
  17.   MsTimer2::stop();
  18.   digitalWrite(13,stop);
  19. }
  20. void setup(){
  21.   atime = 5000;//定時時間設定
  22.   start = true;
  23.   stop = false;
  24.   led = true;
  25.   pinMode(2, INPUT_PULLUP);
  26.   pinMode(13, OUTPUT);//執行輸出
  27.   pinMode(3, INPUT_PULLUP);
  28.   interrupts();// 硬件中斷,2、3接開始和停止按鈕
  29.   attachInterrupt(digitalPinToInterrupt(2),attachInterrupt_fun_RISING_2,RISING);
  30.   attachInterrupt(digitalPinToInterrupt(3),attachInterrupt_fun_RISING_3,RISING);
  31. }
  32. void loop(){
  33. }
看能否適用這個要求。
[color=rgba(0, 0, 0, 0.85)]
ID:204072 發表于 2024-9-2 22:04 | 只看該作者
感謝前輩指點!的確沒有描述清楚,奉上原理圖及時序圖。煩請指點,謝謝!
如圖,按鈕AN按下后,D2、D3點亮,D4保持熄滅;按鈕松開,開始延時,D2熄滅,D3延時后熄滅,D4點亮;延時結束后全部熄滅。
主站蜘蛛池模板: 日韩精品久久久久久免费 | 99热国产在线 | 精品国产91 | 毛片aaa| 久久久久久久久久国产精品 | 中文字幕黄色片 | 日日不卡av | av观看网站 | 国产精品久久久久久久免费看 | 手机看片欧美 | 欧美激情小视频 | 日韩精品国产精品 | www.com国产| 国产一区在线播放 | 又色又爽又黄gif动态图 | 久久亚洲免费视频 | 一区二区三区四区五区 | 成人一级毛片 | 中文字幕av久久爽av | 欧美一区在线视频 | 日韩欧美在线视频观看 | 中文字幕丰满人伦在线 | 超碰免费在线播放 | 国产日韩一区二区三区 | 伊人成人在线视频 | 亚洲精品乱码久久久久久蜜桃91 | www四虎影院 | 国产日产精品一区二区三区的介绍 | 日韩欧美高清 | 国产精品入口66mio男同 | 国产色视频一区二区三区qq号 | 亚洲国产激情 | 欧美午夜在线 | 国产精品av一区二区 | 亚洲天堂一区 | av福利在线观看 | 黄色a一级片 | 欧美精品久久久久久久多人混战 | 欧美视频亚洲视频 | 国产又粗又猛又黄又爽的视频 | 五月综合色 |
