int Position_PID (int shiji,int Target)
// float Position_KP=-80,Position_KI=0,Position_KD=-170;
float Position_KP=-40,Position_KI=0,Position_KD=-50;
static float Bias,Pwm,Integral_bias,Last_Bias;
Bias=shiji-Target; //計(jì)算偏差
Integral_bias+=Bias; //求出偏差的積分
Pwm=Position_KP*Bias+Position_KI*Integral_bias+Position_KD*(Bias-Last_Bias); //位置式PID控制器
Last_Bias=Bias; //保存上一次偏差
if(Pwm>7200) Pwm=7200;
else if(Pwm<-7200) Pwm=-7200;
return Pwm; //增量輸出
int coder;
// int speed;
int speed_s=0;
int speed_po=0;
int SET_Pos=0;
int pwm_out=0;
void TIM1_UP_IRQHandler(void)
// 檢查更新中斷標(biāo)志位
if (TIM_GetITStatus(TIM1, TIM_IT_Update) == SET)
// 執(zhí)行定時(shí)器中斷處理操作
coder=Encoder_Get();
speed_po=Position_PID(coder,SET_Pos);
//speed_s=pid_speed(coder,10);
//pwm_out=speed_s+speed_po;
if(pwm_out>7200) pwm_out=7200;
else if(pwm_out<-7200) pwm_out=-7200;
if(pwm_out>0) motorA_stata (fan,speed_po,enable);
else if(pwm_out<=0) motorA_stata (zhen,-speed_po,enable);
// 清除更新中斷標(biāo)志位
TIM_ClearITPendingBit(TIM1, TIM_IT_Update);
以上是我實(shí)現(xiàn)速度環(huán)的電機(jī)控制, 脈沖數(shù)是一直累計(jì)的,獲取后不清零處理,,,后面我該這么加入速度環(huán)呢? 我直接把速度環(huán)計(jì)算出的PWM和位置環(huán)輸出的PWM相加輸出給電機(jī),這樣沒(méi)有成功.
該這么才能實(shí)現(xiàn)控制位置環(huán)和速度環(huán)串級(jí)PID呢? (小白求助,謝謝回復(fù),謝謝你~)
