查看: 881|回復(fù): 2
esp32和8×8點(diǎn)陣寫貪吃蛇會(huì)有別的列一起點(diǎn)亮
ID:900875 發(fā)表于 2024-9-4 16:07 來(lái)自觸屏版 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
import machine
import time
import random
import _thread  # MicroPython 線程庫(kù)
# 定義點(diǎn)陣的行和列引腳
rows = [machine.Pin(i, machine.Pin.OUT) for i in [32, 33, 25, 26, 27, 14, 12, 13]]
cols = [machine.Pin(i, machine.Pin.OUT) for i in [19, 18, 5, 17, 16, 4, 2, 15]]
snake_body = []  # 初始化蛇身體
direction = ()  # 蛇的方向
food = ()  # 食物的位置
direction_lock = _thread.allocate_lock()
def create_food():
    """生成不與蛇重合的食物位置"""
    global food
    while True:
        # 隨機(jī)生成食物的位置
        food = (random.randint(0, 7), random.randint(0, 7))
        if food not in snake_body:
            break  # 找到不重合的位置,退出循環(huán)
def init_snake():
    """初始化蛇的位置和方向"""
    global snake_body, direction
    snake_body = [(3, 3), (3, 2), (3, 1)]  # 初始化蛇身體
    direction = (0, 1)  # 初始化食物方向
    create_food()  # 初始化食物
def set_pixel(x, y, state):
    """設(shè)置點(diǎn)陣某個(gè)像素的狀態(tài)"""
    rows[x].value(not state)
    cols[y].value(state)
def clear_display():
    print("clear")
    for i in range(8):
        for j in range(8):
            set_pixel(i, j, 0)
def draw_snake():
    """繪制蛇和食物"""
    for segment in snake_body:
        print(f"{segment}")
        set_pixel(segment[0], segment[1], 1)
def draw_food():
    """繪制蛇和食物"""
    set_pixel(1, 1, 1)
    print(f"{food}")
def change_direction(new_direction):
    global direction
    opposite_direction = (-direction[0], -direction[1])
    if new_direction != opposite_direction:
        with direction_lock:
            direction = new_direction
def snake_move():
    """移動(dòng)蛇的位置"""
    global snake_body, food
    # 計(jì)算新位置
    new_head = (snake_body[0][0] + direction[0], snake_body[0][1] + direction[1])
    # 使用取模運(yùn)算使蛇在碰到墻壁時(shí)從另一側(cè)出現(xiàn)
    new_head = (new_head[0] % 8, new_head[1] % 8)
    if new_head in snake_body:
        return False  # 撞到自己,游戲結(jié)束
    snake_body.insert(0, new_head)  # 更新蛇頭位置
    # 吃到食物
    if new_head == food:
        create_food()
    else:
        snake_body.pop()  # 如果沒有吃到食物,尾巴移動(dòng)
    return True
if __name__ == "__main__":
    init_snake()
#     _thread.start_new_thread(key_scan, ()) # 創(chuàng)建線程
    while True:
        if not snake_move():
            break  # 游戲結(jié)束
        clear_display()
        draw_snake()
        draw_food()
        time.sleep_ms(500)
這是代碼,如果是整列從左到右或者從上到下進(jìn)行點(diǎn)亮就沒問題,如果是用這個(gè)代碼進(jìn)行單個(gè)循環(huán)點(diǎn)亮?xí)r就會(huì)有別的列一起點(diǎn)亮,是為什么呢
ID:900875 發(fā)表于 2024-9-4 16:09 來(lái)自觸屏版 | 只看該作者
就像這樣
ID:469589 發(fā)表于 2024-9-6 12:02 | 只看該作者
顯示或循環(huán)處理速度過快,加點(diǎn)延時(shí)
主站蜘蛛池模板: 欧美性生交xxxxx久久久 | 国产欧美一区二区精品忘忧草 | 亚洲一区视频 | 日韩一级免费 | 欧美精品综合 | 超碰99在线 | 黄色网av| 亚洲成人高清 | 国产成人av在线 | 秋霞午夜鲁丝一区二区老狼 | 国产免费小视频 | 亚洲欧美日韩综合 | 成人免费视频一区二区 | 求av网址 | 欧美一级做性受免费大片免费 | 视频一区二区三区在线观看 | 91插插插插插 | 成人a毛片 | 91超碰人人 | 亚洲一区二区三区在线 | 日韩视频第一页 | 久久精品视频网站 | 在线观看av的网站 | 亚洲国产精品久久 | 最新超碰 | av手机在线看 | 欧美日韩无 | 亚洲精品国产精品国自产观看 | 国产草逼视频 | 国产又粗又猛又黄又爽的视频 | 情侣av | 日本亚洲欧美 | 久久精品国产亚洲 | 日韩成人中文字幕 | 激情综合网五月 | 色片在线| 中文字幕一区二区在线播放 | 蜜桃精品一区二区 | 青青久草 | 黄色成人在线 | 亚洲高清视频在线 |
