查看: 870|回復: 1
這個怎么改成52的程序?
ID:950193 發表于 2024-9-12 19:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "33A04.h"
void AiP33A04_Port_Init(void)
        CLK = 0;
        DIN = 0;
void AiP33A04_Write_Reg(unsigned char Current_Mode,unsigned char COM_Data,unsigned int SEG_Data)
        unsigned char i;
        /*傳輸16bit SEG數據*/
        for(i=0;i<16;i++)
                CLK = 0;
                delay();
                if(SEG_Data & 0x0001 == 0x0001)
                        DIN = 1;
                        DIN = 0;
                delay();
                CLK = 1;
                delay();
                SEG_Data = SEG_Data >> 1;
        /*傳輸8bit COM數據*/
        for(i=0;i<8;i++)
                CLK = 0;
                delay();
                if(COM_Data & 0x01 == 0x01)
                        DIN = 1;
                        DIN = 0;
                delay();
                CLK = 1;
                delay();
                COM_Data=COM_Data>>1;
        /*傳輸4bit 恒流選擇*/
        for(i=0;i<4;i++)
                CLK = 0;
                delay();
                if(Current_Mode & 0x1 == 0x1)
                        DIN = 1;
                        DIN = 0;
                delay();
                CLK = 1;
                delay();
                Current_Mode = Current_Mode>>1;
        /*傳輸2bit保留位*/
        for(i=0;i<2;i++)
                CLK = 0;
                delay();
                DIN = 0;
                delay();
                CLK = 1;
                delay();
void AiP33A04_Latch(void)
        CLK = 1;
        delay();
        DIN = 1;
        delay();
        DIN = 0;
        delay();
void AiP33A04_Stop(void)
        CLK = 0;
        delay();
        DIN = 1;
        delay();
        DIN = 0;
        delay();
void port_init()
          P0IO = 0xFF;            // direction
                P0PU = 0x00;            // pullup      P1PU &= ~0x3f;
                P0OD = 0x00;            // open drain
                P0DB = 0x00;            // bit7~6(debounce clock), bit5~0=P07~02 debounce
                P0   = 0x00;            // port initial value
                P1IO = 0xFF;            // direction
                P1PU = 0x00;            // pullup
                P1OD = 0x00;            // open drain
                P15DB = 0x00;           // debounce : P54, 52, 17, 16, 12, 11
                P1   = 0x00;            // port initial value
                P2IO = 0xFF;            // direction
                P2PU = 0x00;            // pullup
                P2OD = 0x00;            // open drain
                P2   = 0x00;            // port initial value
                P3IO = 0xFF;            // direction
                P3PU = 0x00;            // pullup
                P3   = 0x00;            // port initial value
                P4IO = 0xFF;            // direction
                P4PU = 0x00;            // pullup
                P4OD = 0x00;            // open drain
                P4   = 0x00;            // port initial value
                P5IO = 0xFF;            // direction
                P5PU = 0x00;            // pullup
                P5   = 0x00;            // port initial value
                // Set port functions
                P0FSRH = 0x00;          // P0 selection High
                P0FSRL = 0x00;          // P0 selection Low
                P1FSRH = 0x00;          // P1 selection High
                P1FSRL = 0x00;          // P1 selection Low
                P2FSRH = 0x00;          // P2 selection High
                P2FSRL = 0x00;          // P2 selection Low
                P3FSR = 0x00;           // P3 selection
                P4FSR = 0x00;           // P4 selection
                P5FSR = 0x00;           // P5 selection
#include "timer.h"
void Timer2_init()
        // initialize Timer2
        // T2ADRH = 0x07; T2ADRL = 0xcf;  period = 1mS
//  T2ADRH = 0x00; T2ADRL = 0xc7;  period = 0.1mS
        IE |= 0x80;
        IE2 |= 0x08;            // Enable Timer2 interrupt 定時器中斷使能
        T2CRH |= 0x80;           // timer setting High
        T2CRL = 0x60;           // timer setting Low8分頻
        T2ADRH = 0x00;          // period count High
        T2ADRL = 0xc7;          // period count Low
        T2CRH |= 0x01;           // timer setting High
void clock_init()
        // internal RC clock (16.000000MHz)
        OSCCR = 0x28;           // Set Int. OSC
        SCCR = 0x00;            // Use Int. OSC
void INT_Timer2() interrupt 15
                s=s-1;
304.zip
95.66 KB, 下載次數: 1
ID:344848 發表于 2024-9-13 01:10 | 只看該作者
   首先解釋下面程序的含義,再談如何轉換
主站蜘蛛池模板: 国产三级视频 | 国产精品一区二区在线播放 | 国产91丝袜在线播放 | 欧美色综合天天久久综合精品 | 久久av一区二区三区亚洲 | 国产精品毛片va一区二区三区 | 国产黄色在线播放 | 一区二区三区国产精品 | 中国特级毛片 | 在线中文字幕网站 | 久草视频免费 | 亚洲www啪成人一区二区麻豆 | 精品国产视频 | 欧美一区二| 日韩在线看片 | 国产黄色在线 | 青青综合 | 欧美日韩激情 | 亚洲福利精品 | 免费看毛片网站 | 国产精品久久久久久久午夜 | 特黄a级片 | 男人操女人的网站 | 真实人妻互换毛片视频 | 日本久久久久 | 一区二区三区在线播放 | 日韩福利在线 | 亚洲一级精品 | 成人激情在线 | 国产精品第二页 | 成人在线免费观看网站 | 麻豆一区二区三区 | 在线观看av免费 | 九色91| 国产精品成人国产乱一区 | 国产一区二区免费在线观看 | 成人在线a| 日韩一区二区在线视频 | 激情小说五月天 | 日本三级香港三级 | 国产精品一区二区三区在线 |
