查看: 883|回復: 1
PID控制溫度無法控溫怎么判斷哪里出問題?
ID:1125252 發表于 2024-10-14 10:02 | 顯示全部樓層 |閱讀模式
PID控制溫度目前是可以加熱,但是到達設定溫度沒法關閉加熱,示波器里顯示時有關閉加熱的部分,不過一下又恢復成加熱了。大部分時間都是加熱。大佬們幫忙分析下是哪里的問題?
#include "include/ca51m020_config.h"
#include "include/ca51m020sfr.h"
#include "include/ca51m020xsfr.h"
#include "include/gpiodef_m020.h"
#include "include/system_clock.h"
#include "include/uart.h"
#include "include/adc.h"
#include "include/delay.h"
unsigned int count=0;
unsigned int temp_adc=0,cnt=0;
unsigned int PWM_OUT=0;
unsigned int get_ntc=0;
unsigned int AD_Value;
void Timer0_Init(void);
void ADC_Init(void);
unsigned int Get_AdcValue(unsigned char channel);
        ADC控制例程
#define INT_TIME                        1000        //定時時間,單位為us
#define        TH_VAL                                (unsigned char)((0x10000 - (INT_TIME*(FOSC/1000))/12000)>>8)
#define        TL_VAL                                (unsigned char)((0x10000 - (INT_TIME*(FOSC/1000))/12000))
void TIMER0_ISR (void) interrupt 1         //每1ms產生中斷
        TH0 = TH_VAL;
        TL0 = TL_VAL;
        count++;
        if(count>=10)                                //10ms
                cnt++;                                //計數
                count=0;
//        P03 = ~P03;
        TMOD = (TMOD&0xFC)|0x01;                 //模式選擇: 定時器0,模式1。
        TH0 = TH_VAL;                                    //高8位裝初值
        TL0 = TL_VAL;                                    //低8位裝初值
        TR0 = 1;                                               //定時器0使能
        ET0 = 1;                                               //定時器0中斷使能
        EA = 1;
//        PT0 = 1;                                               //設置定時器0中斷優先級為高優先級
函數名稱: ADC_Init
功能描述: 初始化ADC寄存器(設置ADC時鐘、設置采樣時間、選擇ADC參考電壓)
輸入參數: 無
返 回 值: 無
void ADC_Init(void)
//         ADCON = AST(0) | ADIE(0) | HTME(7) | ADCALE(1) | VSEL(ADC_REF_INNER);        //設置ADC參考電壓為內部1.5V
        ADCON = AST(0) | ADIE(0) | HTME(7) | ADCALE(0) | VSEL(ADC_REF_VDD);                //設置ADC參考電壓為VDD
        ADCFGL = ACKD(7);
        P06F = P06_ADC8_SETTING;        //設置P0.6為ADC引腳功能
函數名稱: Get_AdcValue
功能描述: 獲取ADC轉換數值
輸入參數: channel ADC通道號
返 回 值: ADC值
        ADCFGL = (ADCFGL&0xE0) | ADCHS(channel);                //選擇ADC通道
        ADCON |= AST(1);        //啟動ADC轉換
        while(!(ADCON & ADIF));                                                        //等待ADC轉換完成
        ADCON |= ADIF;        //清除ADC中斷標志
        AD_Value = ADCDH*256 + ADCDL;                                        //讀取AD值
        AD_Value >>= 4;
        return AD_Value;
struct _pid{
        float Set_WD;                        //設定值
        float Actual_WD;                //實際值
        float err;                                //偏差
        float err_last;                        //上一次偏差
        float err_next;
        float Kp,Ki,Kd;
        float voltage;                        //電壓值
        float integral;                        //積分值
}pid;
void PID_INIT()
        pid.Set_WD=0.0;
        pid.Actual_WD=0.0;
        pid.err=0.0;
        pid.err_last=0.0;
        pid.err_next=0.0;
        pid.voltage=0.0;
        pid.integral=0.0;
        pid.Kp=0.3;
        pid.Ki=0.05;
        pid.Kd=0.3;
unsigned int temp=40;
void PID_Realize(){
        unsigned int index;
        if(temp==40){temp_adc=1419;}     //設定溫度,對應100K熱敏電阻40攝氏度下的ADC值
        pid.Actual_WD=AD_Value;             //獲取ADC值
        pid.Set_WD=temp_adc;                //設定溫度
        pid.err=pid.Set_WD-pid.Actual_WD;
        if(pid.err>200 || pid.err<-200)
                index=0;
        else if((pid.err<100 && pid.err>0)|| (pid.err<0 && pid.err>-100))
                index=1;
                pid.integral+=pid.err;
                if(pid.err>0)
                        index=(200-pid.err)/100;
                        index=(200+pid.err)/100;
        pid.voltage=pid.Kp*pid.err + pid.Ki*pid.integral + pid.Kd*(pid.err-pid.err_last);
        pid.err_last=pid.err;
        PWM_OUT=pid.voltage*1.0;
        if(PWM_OUT>100){PWM_OUT=100;}
void hot(unsigned int PWM)
        if(cnt<PWM){P07=1;}
        if(cnt>PWM){P07=0;}
        if(cnt>100){cnt=0;}
void System_Init(void)
        LVDCON = 0xE0;                                        //開啟LVD,設置為低電壓復位模式,檢測電壓為2.7V
#ifdef SYSCLK_8MHZ
        CKDIV = 0;                                                //系統時鐘上電默認為IRCH的二分頻(4MHz),運行8MHz,則CKDIV設置為0
#endif
#ifdef UART1_EN
        Uart1_Initial(UART1_BAUTRATE);
#endif
void main(void)
        P06F = INPUT | PU_EN;                //ADC
        P07F = OUTPUT | PU_EN;                //加熱
        P17F = OUTPUT | PU_EN;
        P17=1;
        P06=1;
        P07=0;
        System_Init();
        EA = 1;                                //開全局中斷
        Timer0_Init();
        ADC_Init();                        //初始化ADC
        PID_INIT();
                AD_Value = Get_AdcValue(ADC_CH8);        //獲取溫度值
                PID_Realize();    //PID控制
                hot(PWM_OUT);    //加熱控制
//                Uart1_PutChar(AD_Value>>8);
//                Uart1_PutChar(AD_Value);
ID:973695 發表于 2024-10-16 15:53 | 顯示全部樓層
在程序中加入動態顯示 PID 控制參數的設定值及 測量到在溫度值,看看邏輯是否正確
主站蜘蛛池模板: 国产精品看片 | 午夜视频免费在线观看 | 黄色小说视频网站 | 大尺度做爰呻吟舌吻网站 | 天天干天天操天天插 | www.久久久久| 亚洲视频一区二区三区四区 | 久久国产精品免费视频 | 一区二区三区免费 | 日韩精品在线一区二区 | 中文字幕在线观看不卡 | 超碰人人人人 | 91青青草 | 日韩爱爱视频 | 日韩三级影院 | 日韩精品久久久久久 | 色哟哟一区二区 | 天美传媒在线观看 | 久久青草视频 | 日日干av| 日产精品久久久一区二区 | 欧美一区二区在线 | 日韩午夜精品 | 色婷婷国产| 国产一级片免费观看 | 国产欧美日韩视频 | 日本a级大片 | 国产乱人乱偷精品视频 | 亚洲免费福利视频 | 国产资源视频 | xxxxx国产| 日韩美女一区 | ass亚洲尤物裸体pics | 国产天堂在线观看 | 国产视频中文字幕 | 久草国产视频 | 亚洲男人在线 | 男男av| 成年人网站在线免费观看 | 日韩欧美国产一区二区三区 | 日韩一级在线观看 |
