再次輸入的時(shí)候,lcd怎么清掉之前的數(shù)據(jù)
#include <REGX51.H>
#define uchar unsigned char
#define uint unsigned int
// 定義LCD控制引腳
sbit RS = P1^0;
sbit RW = P1^1;
sbit E = P1^2;
// 定義按鍵引腳
sbit KEY = P1^6;
// 定義數(shù)據(jù)數(shù)組
uchar data_to_send[8];
uchar received_data;
// 延時(shí)函數(shù)
void delayms(uint ms)
uchar i;
while (ms--)
for (i = 0; i < 123; i++);
// 向LCD寫(xiě)指令函數(shù)
void w_com(uchar com)
RS = 0;
RW = 0;
E = 1;
P0 = com;
E = 0;
delayms(1);
// 向LCD寫(xiě)數(shù)據(jù)函數(shù)
void w_dat(uchar dat)
RS = 1;
RW = 0;
E = 1;
P0 = dat;
E = 0;
delayms(1);
// LCD初始化函數(shù)
void lcd_ini(void)
delayms(10);
w_com(0x38);
delayms(10);
w_com(0x0c);
delayms(10);
w_com(0x06);
delayms(10);
w_com(0x01);
delayms(10);
w_com(0x80);
delayms(10);
// 通過(guò)串口發(fā)送一個(gè)字節(jié)數(shù)據(jù)
void send_data(uchar data_to_send)
SBUF = data_to_send;
while (TI == 0);
TI = 0;
// 串口初始化函數(shù)
void uart_init()
// 9600bps 11.0592MHz
SCON = 0x50; // 8位數(shù)據(jù),可變波特率
TMOD &= 0x0F; // 清除定時(shí)器1模式位
TMOD |= 0x20; // 設(shè)定定時(shí)器1為8位自動(dòng)重裝方式
TL1 = 0xFD; // 設(shè)定定時(shí)初值
TH1 = 0xFD; // 設(shè)定定時(shí)器重裝值
ET1 = 0; // 禁止定時(shí)器1中斷
TR1 = 1; // 啟動(dòng)定時(shí)器1
EA = 1; // 開(kāi)啟總中斷
ES = 1; // 開(kāi)啟串口中斷
// 主函數(shù)
uchar i;
lcd_ini();
uart_init();
while (1)
if (KEY == 0)
delayms(20);
if (KEY == 0)
for (i = 0; i < 8; i++)
send_data(data_to_send[ i]);
while (KEY == 0);
// 串口中斷服務(wù)函數(shù)
void uart_interrupt() interrupt 4
if (RI == 1)
RI = 0;
received_data = SBUF;
w_dat(received_data);
