查看: 1345|回復: 1
DHT11和LCD1602顯示屏顯示溫濕度測量儀
ID:1142651 發表于 2025-1-7 13:29 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit Data = P1 ^ 6;
uchar rec_dat[9];
sbit lcdrs = P2 ^ 0;
sbit lcdrw = P2 ^ 1;
sbit lcden = P2 ^ 2;
sbit addr=P2^4;
sbit reducer=P2^5;
sbit addt=P2^6;
sbit reducet=P2^7;
int ET = 0, ER = 0;
uchar R_H, R_L, T_H, T_L, RH, RL, TH, TL;
void delay(uint n)
  uint x, y;
  for (x = n; x > 0; x--)
    for (y = 110; y > 0; y--)
void write_com(uchar com)
  lcdrs = 0;
  P0 = com;
  delay(5);
  lcden = 1;
  delay(5);
  lcden = 0;
void write_dat(uchar dat)
  lcdrs = 1;
  P0 = dat;
  delay(5);
  lcden = 1;
  delay(5);
  lcden = 0;
void init_lcd()
  lcden = 0;
  lcdrw = 0;
  write_com(0x38);
  write_com(0x0c);
  write_com(0x06);
  write_com(0x01);
void DHT11_delay_us(uchar n)
  while (--n)
void DHT11_delay_ms(uint z)
  uint i, j;
  for (i = z; i > 0; i--)
    for (j = 110; j > 0; j--)
void DHT11_start()
  Data = 1;
  DHT11_delay_us(2);
  Data = 0;
  DHT11_delay_ms(30);
  Data = 1;
  DHT11_delay_us(30);
uchar DHT11_rec_byte()
  uchar i, dat = 0;
  for (i = 0; i < 8; i++)
    while (!Data)
    DHT11_delay_us(8);
    dat <<= 1;
    if (Data == 1)
      dat += 1;
    while (Data)
  return dat;
void DHT11_receive()
  uchar revise;
  DHT11_start();
  if (Data == 0)
    while (Data == 0)
    DHT11_delay_us(40);
    R_H = DHT11_rec_byte();
    R_L = DHT11_rec_byte();
    T_H = DHT11_rec_byte();
    T_L = DHT11_rec_byte();
    revise = DHT11_rec_byte();
    DHT11_delay_us(25);
    if ((R_H + R_L + T_H + T_L) == revise)
      RH = R_H;
      RL = R_L;
      TH = T_H;
      TL = T_L;
    rec_dat[0]='0'+((RH+ER)/10);
        rec_dat[1]='0'+((RH+ER)%10);
        rec_dat[2]='.';
        rec_dat[3]='0'+(RL/10);
        rec_dat[4]='%';
                                rec_dat[5]=' ';
        rec_dat[6]='0'+((TH+ET)/10);
        rec_dat[7]='0'+((TH+ET)%10);
                                rec_dat[8]='.';
                                rec_dat[9]='0'+(TL/10);
  uchar i;
  init_lcd();
  while (1)
    if (addr == 0)
      delay(30);
      ER += 1;
    if (reducer == 0)
      delay(30);
      ER -= 1;
    if (addt == 0)
      delay(30);
      ET += 1;
    if (reducet == 0)
      delay(30);
      ET -= 1;
    DHT11_delay_ms(100);
    DHT11_receive();
    write_com(0x80);
     for(i=0;i<=9;i++)
       write_dat(rec_dat[i]);
    write_dat(0xdf);
    write_dat('C');
ID:404454 發表于 2025-4-3 17:48 | 顯示全部樓層
有壇友做過成功的嗎?我看程序顯示部分的都看不明白,也想做個當擺設。
主站蜘蛛池模板: 日韩一级大片 | 亚洲国产欧美日韩在线 | 欧美在线观看一区二区 | 日韩高清毛片 | 欧美日韩综合网 | 精品在线一区二区 | 欧美成人毛片 | 亚洲砖区区免费 | 97精品超碰一区二区三区 | 91女人18毛片水多国产 | 放几个免费的毛片出来看 | 18成人免费观看网站 | 成人精品一区二区三区 | 日韩欧美在线免费观看 | 久久国产精品免费视频 | 青青草成人在线 | 午夜影院黄| 一级毛片网 | 亚洲精品久久久久 | 黄色成人小视频 | 福利片在线 | 成年人视频在线免费观看 | 欧美日韩精品一区二区 | 一级免费视频 | 成年人在线观看 | 超碰人人网 | 国产精品美女视频 | 超碰福利在线 | 日本高清在线观看 | 欧美一级淫片免费视频魅影视频 | 免费观看全黄做爰视频 | 午夜精品久久久久久久99黑人 | 日本在线视频一区 | 亚洲精品911 | 美女网站视频在线观看 | 在线欧美日韩 | 国产区在线 | 免费在线观看av网站 | 久草新视频 | 911亚洲精品 | 欧美黄色一级视频 |
