查看: 1345|回復(fù): 6
解析串口4接收的數(shù)據(jù)包中的一幀數(shù)據(jù)
回帖獎(jiǎng)勵(lì) 10 黑幣 回復(fù)本帖可獲得 1 黑幣獎(jiǎng)勵(lì)! 每人限 1 次
ID:590050 發(fā)表于 2025-1-17 20:43 | 顯示全部樓層 |閱讀模式
      程序大部分是借鑒的網(wǎng)上或STC的例程,想實(shí)現(xiàn)從串口接收的數(shù)據(jù)包中,解析出一幀完整的命令。請(qǐng)教各位大神幫看一下程序,我用的STC單片機(jī),串口4接收數(shù)據(jù),接收的數(shù)據(jù)存在ucRX4_Buffer【】中,最大存UART4_BUF_LENGTH個(gè)數(shù)據(jù)。中斷部分程序如下:
unsigned char ucRX4_index=0;
void Uart4_isr() interrupt 18         //UART4 中斷服務(wù)程序
        UART4_INT_DISABLE();        //禁止串口4中斷
        if(RI4)                                        //串口4接收到數(shù)據(jù)
                CLR_RI4();          //清除中斷4的接收標(biāo)志
                ucRX4_Buffer[ucRX4_index] = S4BUF;         //將串口4接收到的數(shù)據(jù)放入ucRX4_Buffer[]
                ucRX4_index++;
                if(ucRX4_index>UART4_BUF_LENGTH)        ucRX4_index=0;
    if (TI4)
        CLR_TI4();         //清除中斷4的發(fā)送標(biāo)志
                bTX4_Busy = 0;           //設(shè)置串口4發(fā)送為空閑
        UART4_INT_ENABLE();                  //允許串口4中斷
數(shù)據(jù)接收后,從接收的數(shù)據(jù)包中查找以FD,FD,FD開頭的數(shù)據(jù)幀,不同的命令對(duì)應(yīng)不同的數(shù)據(jù)長(zhǎng)度,將查找出的數(shù)據(jù)存在ucRX4_CMD_Data_Buffer【】中,程序如下:
void  Uart4_Read_Cmd_Data(void)                //讀串口4接收的不同命令的數(shù)據(jù)
        unsigned char i;
        ucRX4_Read_Cnt = 0;
        switch(ucRX4_Read_State)
                case 0:                //判斷頭文件
//從接收緩存中查找?guī)^
                        if(ucRX4_Buffer[ucRX4_Read_Cnt] == 0xFD)         //幀頭0xFD 0xFD 0xFD
                                 ucRX4_Read_Cnt++;                 //讀下一個(gè)數(shù)
                                if(++ucRX4_Head_Cnt >= 3)        //頭0xFD 0xFD 0xFD
                                        ucRX4_Read_State=1;
                                ucRX4_Head_Cnt = 0;
                                ucRX4_Read_State = 0;
                break;
                case 1:        //判斷命令長(zhǎng)度,不同命令長(zhǎng)度不同;
                        if(ucRX4_Buffer[ucRX4_Read_Cnt] == 0x06)                //06命令,06后4個(gè)字節(jié),加上命令,共計(jì)5個(gè)字節(jié)
                                ucRX4_Recv_Data_Length=5;
                        else if(ucRX4_Buffer[ucRX4_Read_Cnt] == 0x07)        //07命令
                                ucRX4_Recv_Data_Length=15;
                        else if(ucRX4_Buffer[ucRX4_Read_Cnt] == 0x08)        //08命令
                                ucRX4_Recv_Data_Length=10;
                        else if(ucRX4_Buffer[ucRX4_Read_Cnt] == 0x09)        //09命令
                                ucRX4_Recv_Data_Length=11;
                        else  ucRX4_Recv_Data_Length=0;
                        ucRX4_Read_State=2;
                break;
                case 2:                //接收數(shù)據(jù)
                        for(i=0;i<ucRX4_Recv_Data_Length;i++)
                                ucRX4_CMD_Data_Buffer[ i]=ucRX4_Buffer[ucRX4_Read_Cnt];
                                ucRX4_Read_Cnt++;
                        bRX4_Flag=1;         //一幀數(shù)據(jù)接收完成
                        ucRX4_Read_State=0;
                        ucRX4_Head_Cnt = 0;
                }break;
                default:break;
在其它程序中,需要讀數(shù)據(jù)時(shí),就調(diào)用        void  Uart4_Read_Cmd_Data(void)函數(shù)。
以上程序,現(xiàn)在的問(wèn)題是,總是查找出的數(shù)據(jù)總是不對(duì),用串口助手驗(yàn)證,比如發(fā)的數(shù)據(jù)包中包含了一幀數(shù)據(jù),F(xiàn)D FD FD 06 01 02 03 06,但解析出的數(shù)據(jù)卻不是這個(gè),求大神幫看一下是哪里的問(wèn)題,先謝。
ID:338503 發(fā)表于 2025-1-18 08:07 | 顯示全部樓層
你上述程序調(diào)用void  Uart4_Read_Cmd_Data(void)函數(shù)1次只能讀取1個(gè)字節(jié)數(shù)據(jù),按你上述程序,要根據(jù)命令(0x06,0x07,0x08,0x09)的不同調(diào)用相應(yīng)次數(shù)才可以。
ID:338503 發(fā)表于 2025-1-18 08:16 | 顯示全部樓層
上述讀命令程序調(diào)用1次只能讀取一個(gè)字節(jié)數(shù)據(jù),只有根據(jù)命令(0x06,0x07,0x08,0x09)的不同調(diào)用相應(yīng)次數(shù)才可以。
ID:1143113 發(fā)表于 2025-1-19 11:04 | 顯示全部樓層
有一個(gè)問(wèn)題要注意,你是什么時(shí)候開始解析,建議要在解析前先判斷接收字節(jié)數(shù)夠不夠。只有字節(jié)數(shù)夠了才調(diào)用判斷。這個(gè)非常重要的。
ID:161164 發(fā)表于 2025-1-19 23:27 | 顯示全部樓層
ucRX4_Read_Cnt 是全局變量嗎?
為什么要在Uart4_Read_Cmd_Data函數(shù)開頭清零?
ID:1133081 發(fā)表于 2025-1-20 08:51 | 顯示全部樓層
首先要充分了解該自定義通訊協(xié)議,通常通訊協(xié)議的每一個(gè)字節(jié)都有其特定含義。例如:數(shù)據(jù)頭,數(shù)據(jù)長(zhǎng)度,有效數(shù)據(jù),驗(yàn)證碼,數(shù)據(jù)尾等。假設(shè)這串?dāng)?shù)據(jù)的前3個(gè)FD為數(shù)據(jù)頭,那么當(dāng)串口連續(xù)收到3個(gè)FD即判斷為有真實(shí)信號(hào)到來(lái),即持續(xù)對(duì)后續(xù)數(shù)據(jù)保存。否則清除緩存。如果數(shù)據(jù)長(zhǎng)度固定很好辦,收完若干字節(jié)即給出結(jié)束標(biāo)志。數(shù)據(jù)長(zhǎng)度不固定,但有字節(jié)長(zhǎng)度信息也好辦,根據(jù)長(zhǎng)度信息確定結(jié)束接收并給出結(jié)束標(biāo)志。如不含根據(jù)長(zhǎng)度信息通常啟動(dòng)定時(shí)器,若干時(shí)間收不到數(shù)據(jù)表示傳輸結(jié)束即給出結(jié)束標(biāo)志。解析函數(shù)在得到結(jié)束標(biāo)志后才開始解析并清除結(jié)束標(biāo)志和緩存,為下次接收做準(zhǔn)備。假設(shè)FD FD FD 06 01 02 03 06是固定長(zhǎng)度,串口中斷示例:
  1. void UARTInterrupt() interrupt 4
  2. {
  3.         static uchar num=0;                //靜態(tài)計(jì)數(shù)變量
  4.         uchar i;
  5.         RI=0;                                        //接收中斷請(qǐng)求標(biāo)志位清0
  6.         rec_buf[num]=SBUF;                //接收到的數(shù)據(jù)串保存在緩存數(shù)組
  7.         if(rec_buf[0]==0xFD)        //驗(yàn)證數(shù)據(jù)頭(起始位)
  8.         {
  9.                 num++;
  10.                 if(num==3)
  11.                 {
  12.                         if((rec_buf[0]&rec_buf[1]&rec_buf[2])!=0xFD)
  13.                         {
  14.                                 for(i=0;i>7;i++)
  15.                                         rec_buf[i]=0x00;//清除緩存
  16.                         }
  17.                 }
  18.                 if(num>=8)
  19.                 {
  20.                         flag=1;                        //接收完成標(biāo)志置1
  21.                         num=0;                        //計(jì)數(shù)變量清0
  22.                 }
  23.         }
  24. }
ID:1143357 發(fā)表于 2025-1-24 12:50 | 顯示全部樓層
你調(diào)用這個(gè)函數(shù)時(shí)switch結(jié)構(gòu)只進(jìn)去了一次就出來(lái)了,而且用于計(jì)數(shù)的參數(shù)又是局部變量,再次調(diào)用計(jì)數(shù)參數(shù)又會(huì)歸零,這里可以改一下
主站蜘蛛池模板: 日本中文字幕网站 | 国产精品一区二区在线播放 | igao在线观看 | 黄色片aaa| 青娱乐99 | 日韩精品视频一区二区三区 | 伊人久久av | 日韩在线资源 | 日本少妇做爰全过程毛片 | 国产一级在线 | 欧美精产国品一二三区 | 欧美黄色一级大片 | 超碰人人干 | 精品国产一区二区三区久久久蜜月 | 99热99re6国产在线播放 | 日韩小视频 | 狠狠做深爱婷婷久久综合一区 | 51成人网 | 永久免费看mv网站入口亚洲 | 91久久综合亚洲鲁鲁五月天 | 亚洲黄色网址 | 免费观看一区二区 | 一区二区三区日韩 | 啊v在线 | 麻豆成人91精品二区三区 | 日韩1级片| 国产一级18片视频 | 九月丁香婷婷 | 久久精品久久精品 | 日韩一区二区三区四区 | 欧美日韩毛片 | 激情久久久久 | 青青久久久| 日韩一级片在线观看 | 国产又黄又爽视频 | 欧美精品三级 | 91综合在线 | 精品国产成人 | 狼人色| 免费看a级片 | 国产在线高清 |
