查看: 1011|回復(fù): 7
請(qǐng)教怎樣更函數(shù)改才能控制LED亮度
ID:891876 發(fā)表于 2025-2-22 11:29 | 顯示全部樓層 |閱讀模式
請(qǐng)教師傅們?cè)鯓痈牟拍芸刂屏炼龋恐x謝
#define numLED 16 //燈的個(gè)數(shù)
unsigned char xdata buf_G[numLED] = {0};//顏色緩存
unsigned char xdata buf_R[numLED] = {0};
unsigned char xdata buf_B[numLED] = {0};
/*=================== 50us延時(shí) =====================*/
  void Delay50us()  //@24MHz
        unsigned char i, j;
        _nop_();
        _nop_();
        i = 2;
        j = 15;
        do
          while (--j);
        } while (--i);
/*=================== 1碼,高電平850ns 低電平400ns 誤差正負(fù)150ns =====================*/
void RGB_Set_Up() //1碼,高電平850ns 低電平400ns 誤差正負(fù)150ns
     WS2812 = 1;
     _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_();
     WS2812 = 0;
/*=================== 0碼,高電平400ns 低電平850ns 誤差正負(fù)150ns =====================*/
void RGB_Set_Down()  //0碼,高電平400ns 低電平850ns 誤差正負(fù)150ns
        WS2812 = 1;
    WS2812 = 0;
/*=================== 發(fā)送24位數(shù)據(jù) =====================*/
void Send_2812_24bits(unsigned char G8,unsigned char R8,unsigned char B8)//發(fā)送24位數(shù)據(jù)
    unsigned int n = 0;
    for(n=0;n<8;n++)    //發(fā)送G8位
          G8<<=n;
          if(G8&0x80 == 0x80)RGB_Set_Up();
                     RGB_Set_Down();
    for(n=0;n<8;n++)   //發(fā)送R8位
          R8<<=n;
          if(R8&0x80 == 0x80)RGB_Set_Up();
                     RGB_Set_Down();
    for(n=0;n<8;n++)  //發(fā)送B8位
          B8<<=n;
          if(B8&0x80 == 0x80)RGB_Set_Up();
                     RGB_Set_Down();
/*=================== 顏色交換24位不拆分發(fā) =====================*/
void SetPixelColor(unsigned char num,unsigned long c)//顏色交換24位不拆分發(fā)
     unsigned char i;
     for(i=0;i<numLED;i++)
          buf_G[num]=(unsigned char)(c>>16);
          buf_R[num]=(unsigned char)(c>>8);
          buf_B[num]=(unsigned char)(c);
           Send_2812_24bits(buf_G[i],buf_R[i],buf_B[i]);
/*=================== 復(fù)位 =====================*/
void PixelUpdate() //ws2812復(fù)位
   Delay50us();
/*=================== 用一種顏色填充這些圓點(diǎn) =====================*/
void colorWipe(unsigned long c, unsigned int wait)//用一種顏色填充這些圓點(diǎn)
  unsigned char i=0;
  for( i=0; i<numLED; i++)
        SetPixelColor(i, c);
        PixelUpdate();
        delay_ms(wait);
main()
             colorWipe(0xffffff,10); //白色全亮
ID:891876 發(fā)表于 2025-2-22 16:17 | 顯示全部樓層
這樣改了下也不得行
void SetPixelColor(unsigned char num,unsigned char g,unsigned char r,unsigned char b)//顏色交換24位不拆分發(fā)
     unsigned char i;
          buf_G[num]=(g);
          buf_R[num]=(r);
          buf_B[num]=(b);
   Delay50us();
void colorWipe(unsigned char g,unsigned char r, unsigned char b)//用一種顏色填充這些圓點(diǎn)
  unsigned char i=0;
        SetPixelColor(i,g,r,b);
        PixelUpdate();
main()
        EAXFR = 1;
        CKCON = 0x00;
        WTST = 0x02;
        P3M0 = 0x00; P3M1 = 0x00;
       colorWipe(255,255,255);
ID:466250 發(fā)表于 2025-2-22 21:14 | 顯示全部樓層
colorWipe(10,10,10);
ID:624769 發(fā)表于 2025-2-23 01:35 | 顯示全部樓層
main()
             colorWipe(0xffffff,8); //白色全亮
             colorWipe(0x000000,8); //一半亮度
//             colorWipe(0x000000,16); //1/3亮度
//             colorWipe(0x000000,24); //1/4亮度
//             colorWipe(0x000000,4); //2/3亮度
//             colorWipe(0x000000,2); //4/5亮度
ID:866313 發(fā)表于 2025-2-27 03:22 | 顯示全部樓層
以下內(nèi)容由 DeepSeek R1 生成
為了控制LED的亮度,需要對(duì)代碼進(jìn)行以下修改。這里假設(shè)使用的是WS2812 LED燈帶,亮度通過(guò)調(diào)整RGB各通道的PWM值實(shí)現(xiàn):
// 新增亮度控制變量(0-255)
unsigned char brightness = 255; // 初始最大亮度
/*=================== 修正后的發(fā)送24位數(shù)據(jù)函數(shù) =====================*/
void Send_2812_24bits(unsigned char G8, unsigned char R8, unsigned char B8)
     unsigned char n;
     // 綠色通道(應(yīng)用亮度調(diào)節(jié))
     for(n = 0; n < 8; n++) {
         if(G8 & 0x80) RGB_Set_Up();
         else RGB_Set_Down();
         G8 <<= 1;
     // 紅色通道(應(yīng)用亮度調(diào)節(jié))
         if(R8 & 0x80) RGB_Set_Up();
         R8 <<= 1;
     // 藍(lán)色通道(應(yīng)用亮度調(diào)節(jié))
         if(B8 & 0x80) RGB_Set_Up();
         B8 <<= 1;
/*=================== 修正后的顏色設(shè)置函數(shù) =====================*/
void SetPixelColor(unsigned char num, unsigned char g, unsigned char r, unsigned char b)
     if(num >= numLED) return;
     // 應(yīng)用全局亮度調(diào)節(jié)
     buf_G[num] = (g * brightness) / 255;
     buf_R[num] = (r * brightness) / 255;
     buf_B[num] = (b * brightness) / 255;
/*=================== 統(tǒng)一刷新函數(shù) =====================*/
void Show()
     unsigned char i;
     for(i = 0; i < numLED; i++) {
         Send_2812_24bits(buf_G, buf_R, buf_B);
     PixelUpdate(); // 發(fā)送復(fù)位信號(hào)
/*=================== 顏色填充函數(shù) =====================*/
void colorWipe(unsigned char g, unsigned char r, unsigned char b)
     unsigned char i;
         SetPixelColor(i, g, r, b);
     Show();
main()
     EAXFR = 1;
     CKCON = 0x00;
     WTST = 0x02;
         // 示例:50%亮度白色
         brightness = 128; // 0-255范圍
         colorWipe(255, 255, 255);
         // 可以添加延時(shí)或其他亮度變化邏輯
         delay_ms(1000);
         // 示例:25%亮度紅色
         brightness = 64;
         colorWipe(255, 0, 0);
         delay_ms(1000);
主要修改點(diǎn)說(shuō)明:
  • 亮度控制原理
  • 新增全局變量brightness(0-255)
  • 在設(shè)置顏色值時(shí)進(jìn)行亮度計(jì)算:(顏色值 * brightness) / 255
  • 通過(guò)調(diào)整brightness的值即可全局控制亮度
  • 關(guān)鍵函數(shù)修正
  • Send_2812_24bits():修正位操作邏輯,確保數(shù)據(jù)正確發(fā)送
  • SetPixelColor():直接操作指定LED,不再循環(huán)錯(cuò)誤覆蓋
  • 新增Show()函數(shù)統(tǒng)一刷新所有LED
  • 使用建議
  • 調(diào)用colorWipe(255,255,255)時(shí),實(shí)際亮度由brightness參數(shù)決定
  • 可通過(guò)漸變算法實(shí)現(xiàn)呼吸燈效果
  • 每個(gè)顏色通道可單獨(dú)控制亮度
  • 注意事項(xiàng)
  • 確保延時(shí)函數(shù)精度(WS2812對(duì)時(shí)序敏感)
  • 顏色值范圍保持0-255
  • 復(fù)位信號(hào)(Delay50us)需保證至少50μs低電平
可通過(guò)以下方式動(dòng)態(tài)調(diào)整亮度:
// 呼吸燈效果示例
for(int i=0; i<256; i++){
     brightness = i;
     delay_ms(10);
for(int i=255; i>=0; i--){
     brightness = i;
     delay_ms(10);
根據(jù)后續(xù)需求,我們可以進(jìn)一步完善代碼結(jié)構(gòu)和功能擴(kuò)展。以下是優(yōu)化后的代碼框架和功能增強(qiáng)說(shuō)明:
// 硬件配置 & 宏定義
#define numLED 16       // 最大LED數(shù)量
#define BRIGHTNESS_MAX 255 // 最大亮度值
#define DELAY_RESET_US 50  // 復(fù)位信號(hào)延時(shí)(us)
// 全局緩存 & 狀態(tài)控制
unsigned char xdata buf_G[numLED] = {0}; // 綠色通道緩存
unsigned char xdata buf_R[numLED] = {0}; // 紅色通道緩存
unsigned char xdata buf_B[numLED] = {0}; // 藍(lán)色通道緩存
unsigned char global_brightness = BRIGHTNESS_MAX; // 全局亮度(0-255)
bit refresh_flag = 1;                     // 刷新標(biāo)志位
// 硬件接口定義
sbit WS2812 = P3^4;      // 數(shù)據(jù)引腳定義
/*===================== 精密延時(shí)函數(shù) ======================*/
// @24MHz時(shí)鐘
void Delay50us() {
     // 保持原有精確延時(shí)實(shí)現(xiàn)
     unsigned char i, j;
     _nop_(); _nop_();
     i = 2;
     j = 15;
     do { while (--j); } while (--i);
void delay_ms(unsigned int ms) {
     // 需根據(jù)實(shí)際需求實(shí)現(xiàn)毫秒級(jí)延時(shí)
     unsigned int i, j;
     for(i=0; i<ms; i++)
         for(j=0; j<114; j++);
/*===================== 硬件層驅(qū)動(dòng) =======================*/
// 時(shí)序生成函數(shù)保持不變
void RGB_Set_Up() { /* 原有實(shí)現(xiàn) */ }
void RGB_Set_Down() { /* 原有實(shí)現(xiàn) */ }
/*===================== 數(shù)據(jù)發(fā)送優(yōu)化 ======================*/
void Send_2812_24bits(unsigned char g, unsigned char r, unsigned char b)
     unsigned char mask;
     // 綠色通道(優(yōu)化后的位操作)
     for(mask = 0x80; mask; mask >>= 1) {
         (g & mask) ? RGB_Set_Up() : RGB_Set_Down();
     // 紅色通道
         (r & mask) ? RGB_Set_Up() : RGB_Set_Down();
     // 藍(lán)色通道
         (b & mask) ? RGB_Set_Up() : RGB_Set_Down();
/*===================== 亮度管理模塊 ======================*/
// 設(shè)置全局亮度(0-255)
void SetGlobalBrightness(unsigned char brightness)
     global_brightness = (brightness > BRIGHTNESS_MAX) ? BRIGHTNESS_MAX : brightness;
     refresh_flag = 1; // 標(biāo)記需要刷新
// 設(shè)置單燈亮度(帶Gamma校正)
void SetPixelBrightness(unsigned char index, unsigned char r, unsigned char g, unsigned char b)
     if(index >= numLED) return;
     // Gamma校正表(2.8修正值)
     static const unsigned char gamma_table[] = {
         0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
         1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2,
         2, 2, 2, 3, 3, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5,
         // ... 完整256項(xiàng)Gamma表數(shù)據(jù)需補(bǔ)充
     // 應(yīng)用Gamma校正和全局亮度
     buf_R[index] = gamma_table[(r * global_brightness) >> 8];
     buf_G[index] = gamma_table[(g * global_brightness) >> 8];
     buf_B[index] = gamma_table[(b * global_brightness) >> 8];
     refresh_flag = 1;
/*===================== 顯示刷新控制 ======================*/
void RefreshLEDs()
     if(!refresh_flag) return;
     unsigned char i;
     Delay50us();      // 發(fā)送復(fù)位信號(hào)
     refresh_flag = 0; // 清除刷新標(biāo)志
/*===================== 高級(jí)效果函數(shù) ======================*/
// 呼吸燈效果(帶平滑過(guò)渡)
void BreathingEffect(unsigned char r, unsigned char g, unsigned char b, unsigned int cycle)
     static unsigned int step = 0;
     unsigned char brightness;
     // 正弦波亮度變化(0-255)
     brightness = BRIGHTNESS_MAX/2 * (1 + sin(2*3.14159*step/cycle));
     SetGlobalBrightness(brightness);
     // 全燈設(shè)置顏色
     for(unsigned char i=0; i<numLED; i++) {
         SetPixelBrightness(i, r, g, b);
     RefreshLEDs();
     step = (step < cycle) ? step+1 : 0;
// 梯度亮度設(shè)置(示例)
void GradientBrightnessDemo()
     static unsigned char base = 0;
         // 創(chuàng)建彩虹漸變效果
         unsigned char pos = (i + base) % numLED;
             abs(pos - numLED/3)*3,
             abs(pos - 2*numLED/3)*3,
             pos*3
     base++;
     RefreshLEDs();
     delay_ms(50);
/*===================== 主程序框架 ======================*/
     // 系統(tǒng)初始化
     EAXFR = 1;        // 擴(kuò)展RAM使能
     CKCON = 0x00;     // 時(shí)鐘設(shè)置
     WTST = 0x02;      // 等待狀態(tài)配置
     P3M0 = 0x00;      // 端口模式設(shè)置
     P3M1 = 0x00;
     // 初始顏色設(shè)置
         SetPixelBrightness(i, 255, 255, 255); // 初始白色
     RefreshLEDs();
     while(1) {
         // 效果演示選擇
         BreathingEffect(255, 255, 255, 200); // 白色呼吸燈
         // GradientBrightnessDemo();          // 漸變效果
主要改進(jìn)點(diǎn)說(shuō)明:
  • 分層架構(gòu)設(shè)計(jì)
    • 硬件驅(qū)動(dòng)層:專(zhuān)注于時(shí)序生成
    • 亮度管理模塊:集成Gamma校正
    • 效果函數(shù)層:實(shí)現(xiàn)復(fù)雜光效
    • 主控邏輯:協(xié)調(diào)各模塊工作
  • 高級(jí)功能增強(qiáng)
// Gamma校正示例(需補(bǔ)全256項(xiàng))
     0, 0, 0, 0, 1, 1, 2, 2, 3, 3, 4, 5, 6, 7, 8, 9,
     10, 11, 12, 13, 15, 16, 18, 19, 21, 22, 24, 26, 28,
     // ... 完整Gamma表數(shù)據(jù)
  • 動(dòng)態(tài)效果實(shí)現(xiàn)
    • 呼吸燈使用正弦波算法
    • 梯度亮度采用相對(duì)位置計(jì)算
    • 支持多種效果無(wú)縫切換
  • 性能優(yōu)化
    • 引入刷新標(biāo)志位,避免冗余刷新
    • 使用移位運(yùn)算替代浮點(diǎn)計(jì)算
    • 采用查表法加速Gamma校正
  • 擴(kuò)展接口
// 設(shè)置獨(dú)立亮度通道(示例)
void SetIndividualBrightness(
     unsigned char r_bright,
     unsigned char g_bright,
     unsigned char b_bright)
     // 各通道獨(dú)立亮度控制
     buf_R[index] = (buf_R[index] * r_bright) >> 8;
     buf_G[index] = (buf_G[index] * g_bright) >> 8;
     buf_B[index] = (buf_B[index] * b_bright) >> 8;
     refresh_flag = 1;
實(shí)際應(yīng)用建議:
  • 時(shí)序校準(zhǔn)工具:
void TimingCalibration()
     while(1) {
         WS2812 = 1;
         Delay50us(); // 實(shí)際需調(diào)整延時(shí)觀察效果
         WS2812 = 0;
         Delay50us();
  • 顏色空間轉(zhuǎn)換(HSV支持):
void HSVtoRGB(unsigned char h, unsigned char s, unsigned char v,
              unsigned char *r, unsigned char *g, unsigned char *b)
     // 實(shí)現(xiàn)HSV到RGB的轉(zhuǎn)換算法
     // 可添加亮度參數(shù)集成
調(diào)試技巧:
  • 使用邏輯分析儀驗(yàn)證時(shí)序
  • 分段測(cè)試顏色通道
  • 漸進(jìn)式亮度調(diào)試(從25%、50%、75%到100%)
  • 添加狀態(tài)指示燈輔助調(diào)試
通過(guò)這種結(jié)構(gòu)化的設(shè)計(jì),可以方便地?cái)U(kuò)展更多燈光效果,同時(shí)保持代碼的可維護(hù)性。實(shí)際應(yīng)用中可根據(jù)具體需求刪減或增強(qiáng)相應(yīng)模塊。
ID:975305 發(fā)表于 2025-2-27 11:01 | 顯示全部樓層
修改說(shuō)明
添加全局亮度變量:引入一個(gè)全局變量brightness,范圍0-255(0為全滅,255為全亮)。
修正SetPixelColor函數(shù):在設(shè)置顏色時(shí)應(yīng)用亮度系數(shù),確保每次設(shè)置顏色時(shí)根據(jù)當(dāng)前亮度調(diào)整。
更新顏色時(shí)重新應(yīng)用亮度:當(dāng)亮度改變時(shí),重新設(shè)置所有LED的顏色以應(yīng)用新亮度。
#define numLED 16 // 燈的個(gè)數(shù)
unsigned char xdata buf_G[numLED] = {0}; // 顏色緩存
unsigned char brightness = 255; // 全局亮度控制變量,0-255
void Delay50us() { //@24MHz
    unsigned char i, j;
    _nop_();
    _nop_();
    i = 2;
    j = 15;
    do {
        while (--j);
    } while (--i);
/*=================== 1碼,高電平850ns 低電平400ns =====================*/
void RGB_Set_Up() {
    WS2812 = 1;
    WS2812 = 0;
/*=================== 0碼,高電平400ns 低電平850ns =====================*/
    WS2812 = 1;
    WS2812 = 0;
void Send_2812_24bits(unsigned char G8, unsigned char R8, unsigned char B8) {
    unsigned int n;
    for(n=0; n<8; n++) { // 發(fā)送G
        G8 <<= 1;
    for(n=0; n<8; n++) { // 發(fā)送R
        R8 <<= 1;
    for(n=0; n<8; n++) { // 發(fā)送B
        B8 <<= 1;
/*=================== 設(shè)置單個(gè)LED顏色(應(yīng)用亮度) =====================*/
void SetPixelColor(unsigned char num, unsigned long c) {
    unsigned char g = (c >> 16) & 0xFF;
    unsigned char r = (c >> 8) & 0xFF;
    unsigned char b = c & 0xFF;
    // 應(yīng)用亮度系數(shù)
    buf_G[num] = (g * brightness) >> 8;
    buf_R[num] = (r * brightness) >> 8;
    buf_B[num] = (b * brightness) >> 8;
/*=================== 更新所有LED顏色到硬件 =====================*/
void PixelUpdate() {
        Send_2812_24bits(buf_G[i], buf_R[i], buf_B[i]);
    Delay50us(); // 復(fù)位信號(hào)
/*=================== 填充顏色并更新亮度 =====================*/
void colorWipe(unsigned long c, unsigned int wait) {
        PixelUpdate();
        delay_ms(wait);
main() {
    while(1) {
        // 示例:設(shè)置不同亮度
        brightness = 255; // 全亮
        colorWipe(0xFFFFFF, 10);
        delay_ms(1000);
        brightness = 128; // 50%亮度
        delay_ms(1000);
亮度變量:brightness的值(0-255)控制整體亮度,通過(guò)全局變量調(diào)整。
顏色應(yīng)用亮度:在SetPixelColor中,顏色分量(G, R, B)會(huì)乘以brightness后右移8位(相當(dāng)于除以256),實(shí)現(xiàn)快速亮度縮放。
動(dòng)態(tài)亮度調(diào)整:修改brightness后重新調(diào)用colorWipe,所有LED顏色會(huì)根據(jù)新亮度重新計(jì)算并更新。
ID:620461 發(fā)表于 2025-3-6 09:25 | 顯示全部樓層
可以一個(gè)周期內(nèi)交替的形式顯示黑色和需要的顏色,就可以室內(nèi)亮度的變化,周期要短,單位周期內(nèi)黑色占比越大亮度就越黑,占比越小亮度就越亮,占比為0的時(shí)候就是最亮的。
ID:891876 發(fā)表于 2025-3-7 17:36 | 顯示全部樓層
慧原馬迪 發(fā)表于 2025-2-27 11:01
修改說(shuō)明
感謝修改程序,已經(jīng)可以調(diào)節(jié)亮度了!
主站蜘蛛池模板: 亚洲国产日韩欧美 | 久久精品国产亚洲 | 亚洲精品大片 | 夜夜夜夜操 | 欧美日本在线 | 欧美一级艳片视频免费观看 | 免费视频久久 | 在线观看日韩视频 | 日韩精品久久久久久 | 丁香九月婷婷 | 欧美日韩在线看 | 成人午夜在线观看 | 青青草视频污 | 一道本在线| 四虎久久久 | 亚洲欧美日韩另类 | 日韩精品一区二区视频 | 亚洲精品中文字幕乱码三区91 | 91精品国产成人www | 丁香午夜 | 欧美久久久久久久久 | 日韩黄色网址 | 午夜两性 | 一级片免费网站 | www.青青草 | 毛片在线观看视频 | 亚洲免费网站 | 神马午夜久久 | 韩日一级片 | 免费观看全黄做爰大片视频美国 | 可以看毛片的网站 | 久久老司机| 国产美女一区二区三区 | 欧美在线视频一区二区 | 欧美在线亚洲 | www.夜夜操| 亚洲经典一区二区 | 成人在线免费网站 | 亚洲视频一区二区三区四区 | 欧美视频在线观看 | 亚洲精品911 |
