查看: 709|回復: 7
STC15單片機矩陣鍵盤的代碼哪里出錯了,大佬可以幫我看看嗎
ID:1142520 發表于 2025-3-7 23:23 | 顯示全部樓層 |閱讀模式
這個STC15單片機的矩陣鍵盤代碼哪里出錯了呀,大佬幫我看看吧,給我矩陣鍵盤的代碼也可以
ID:1110477 發表于 2025-3-17 03:50 | 顯示全部樓層
譚1234 發表于 2025-3-15 08:25
這寫法看著都頭疼
sbit R1 = P3^0;
sbit R2 = P3^1;
為啥鍵值要加大
ID:1132182 發表于 2025-3-15 08:25 | 顯示全部樓層
這寫法看著都頭疼
sbit R1 = P3^0;
sbit R2 = P3^1;
sbit R3 = P3^2;
sbit R4 = P3^3;
sbit C1 = P4^4;
sbit C2 = P4^2;
sbit C3 = P3^5;
sbit C4 = P3^4;
uchar Key_Open(void)
  uchar key = 0;
  C1 = 0;C2 = 1;C3 = 1;C4 = 1;
  if(R1 == 0) key = 7;
  if(R2 == 0) key = 6;
  if(R3 == 0) key = 5;
  if(R4 == 0) key = 4;
  C1 = 1;C2 = 0;C3 = 1;C4 = 1;
  if(R1 == 0) key = 11;
  if(R2 == 0) key = 10;
  if(R3 == 0) key = 9;
  if(R4 == 0) key = 8;
  C1 = 1;C2 = 1;C3 = 0;C4 = 1;
  if(R1 == 0) key = 15;
  if(R2 == 0) key = 14;
  if(R3 == 0) key = 13;
  if(R4 == 0) key = 12;
  C1 = 1;C2 = 1;C3 = 1;C4 = 0;
  if(R1 == 0) key = 19;
  if(R2 == 0) key = 18;
  if(R3 == 0) key = 17;
  if(R4 == 0) key = 16;
  return key;
ID:1132182 發表于 2025-3-15 08:20 | 顯示全部樓層
跳線帽沒接到矩陣?
ID:1145512 發表于 2025-3-14 18:00 | 顯示全部樓層
你這個暫時看不出問題,我附上我之前參加藍橋杯時候的矩陣鍵盤代碼#include "ALL.H"
#include "REG52.H"
/*矩陣鍵盤編號
1     2    3    4   P3_0
5     6    7    8   P3_1
9    10   11   12   P3_2
13   14   15   16   P3_3
P4_4 P4_2 P3_5 P3_4
unsigned char Matric_Scan(){
        unsigned char Num=0;
        P3_0=0;
        P3_1=P3_2=P3_3=1;
        P4_4=P4_2=P3_5=P3_4=1;
        if(P4_4==0){
                Num=1;
        else if(P4_2==0){
                Num=2;
        else if(P3_5==0){
                Num=3;
        else if(P3_4==0){
                Num=4;
        P3_1=0;
        P3_0=P3_2=P3_3=1;
        if(P4_4==0){
      Num=5;
        else if(P4_2==0){
                Num=6;
        else if(P3_5==0){
                Num=7;
        else if(P3_4==0){
                Num=8;
        P3_2=0;
        P3_0=P3_1=P3_3=1;
        if(P4_4==0){
      Num=9;
        else if(P4_2==0){
                Num=10;
        else if(P3_5==0){
                Num=11;
        else if(P3_4==0){
                Num=12;
        P3_3=0;
        P3_0=P3_1=P3_2=1;
        if(P4_4==0){
      Num=13;
        else if(P4_2==0){
                Num=14;
        else if(P3_5==0){
                Num=15;
        else if(P3_4==0){
                Num=16;
        return Num;
void Matric_Show_Num(){
        if(Matric_Scan()==1){
                        Display(1,1);
                else if(Matric_Scan()==2){
                        Display(1,2);
                else if(Matric_Scan()==3){
                        Display(1,3);
                else if(Matric_Scan()==4){
                        Display(1,4);
                else if(Matric_Scan()==5){
                        Display(1,5);
                else if(Matric_Scan()==6){
                        Display(1,6);
                else if(Matric_Scan()==7){
                        Display(1,7);
                else if(Matric_Scan()==8){
                        Display(1,8);
                else if(Matric_Scan()==9){
                        Display(1,9);
                else if(Matric_Scan()==10){
                        Display(1,10);
                else if(Matric_Scan()==11){
                        Display(1,11);
                else if(Matric_Scan()==12){
                        Display(1,12);
                else if(Matric_Scan()==13){
                        Display(1,13);
                else if(Matric_Scan()==14){
                        Display(1,14);
                else if(Matric_Scan()==15){
                        Display(1,15);
                else if(Matric_Scan()==16){
                        Display(1,16);
應該會有幫助
ID:1145512 發表于 2025-3-14 17:55 | 顯示全部樓層
代碼上看,沒啥問題,你是現象出問題了還是什么
ID:891003 發表于 2025-3-8 10:45 | 顯示全部樓層
這個不好回答!代碼跟硬件需要配合,原理圖都沒有,我個人才疏學淺,不懂回答。
ID:1133081 發表于 2025-3-8 06:55 | 顯示全部樓層
這個程序用在51內核的MCU具有普適性
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. uchar key=0;                                        //定義鍵值全局變量
  5. void keyscan()                                        //按鍵掃描程序
  6. {
  7.         static bit sign=0;                        //按鍵狀態標志
  8.         static uint count=0;                //消抖計數變量
  9.         uchar num=0;                                //臨時變量
  10.         P3=0xf0;                                        //賦值P3 1111 0000
  11.         if(P3!=0xf0)                                //檢測有按鍵按下
  12.         {
  13.                 count++;                                //消抖計數
  14.                 if(count>=100 && sign==0)//100~10000,根據循環周期調整約10~20ms
  15.                 {
  16.                         sign=1;                                //按鍵狀態標志置1
  17.                         num=P3;                                //保存P3值xxxx 0000,x為0或1
  18.                         num|=0x0f;                        //保存num按位或0x0f值xxxx 1111
  19.                         P3=num;                                //賦值P3 xxxx 1111
  20.                         switch(P3)
  21.                         {
  22.                                 case 0xee: key= 1; break;
  23.                                 case 0xde: key= 2; break;
  24.                                 case 0xbe: key= 3; break;
  25.                                 case 0x7e: key= 4; break;
  26.                                 case 0xed: key= 5; break;
  27.                                 case 0xdd: key= 6; break;
  28.                                 case 0xbd: key= 7; break;
  29.                                 case 0x7d: key= 8; break;
  30.                                 case 0xeb: key= 9; break;
  31.                                 case 0xdb: key=10; break;
  32.                                 case 0xbb: key=11; break;
  33.                                 case 0x7b: key=12; break;
  34.                                 case 0xe7: key=13; break;
  35.                                 case 0xd7: key=14; break;
  36.                                 case 0xb7: key=15; break;
  37.                                 case 0x77: key=16; break;
  38.                         }
  39.                 }
  40.         }
  41.         else                                                //鍵抬起
  42.         {
  43.                 sign=0;                                        //按鍵自鎖標志清0
  44.                 count=0;                                //消抖計數清0
  45.         }
  46. }
  47. void main()                                                //主函數
  48. {
  49.         while(1)
  50.         {
  51.                 keyscan();                                //按鍵掃描程序
  52.                 P1=~key;                                //LED顯示鍵碼1~16,低電平亮
  53.         }
  54. }
主站蜘蛛池模板: 黄色在线免费看 | 国产精品xxx在线观看 | 欧美激情一区二区三区 | 亚州成人| 欧美一区二区在线播放 | 好吊妞这里只有精品 | 精品久久一区二区三区 | 黄色成人在线视频 | 91网站免费观看 | 一区二区三区国产精品 | 人人插人人爱 | 黑人精品xxx一区一二区 | 亚洲乱淫 | 色综合99 | 免费毛片网站 | 999毛片| 女人高潮特级毛片 | 中文字幕在线一区二区三区 | 中文字幕在线看 | 欧美日韩视频 | 国产日韩在线播放 | 国产精品一级二级 | 欧美高清在线 | 亚洲香蕉视频 | 中文在线字幕免费观看 | 青青草精品视频 | 久久国产精品一区二区 | 我要看一级黄色片 | 欧美一区二区三区的 | 国产91页| 国产日韩欧美精品 | 一级特黄妇女高潮 | 欧美成人激情视频 | 日本免费黄色 | 亚洲成人一区二区 | 亚洲综合另类 | 国产天堂网 | 做爰xxxⅹ性生交 | 亚洲国产精品久久久 | 在线观看国产小视频 | 国产精品一区一区三区 |
