查看: 421|回復: 2
求佬解惑,關于mpu6050接收數據
ID:1142986 發表于 2025-4-13 22:44 | 顯示全部樓層 |閱讀模式
問題是串口接收數據不變,均為:
temp= 36.53X= 0.00,y=0.00,z=0.00,X= 0.00,y=0.00,z=1.59,
如圖:
而且只有這一個能接收數據,其他兩個都不行,如下圖:
設置端口屬性錯誤:31
硬件接線為
系統板PA9、PA10接ch340模塊;PB6、PB7作IIC的SCL和SDA,接連mpu6050。其他就是電源接線了
cubemx引腳設置如下圖:
代碼:
初始化部分
  1. void MPU6050_INIT ()
  2. {
  3.         HAL_Delay(100);
  4.
  5.         uint8_t SendAddress = 0x68;
  6.         uint8_t SendData = 0x00; //解除休眠
  7.         HAL_I2C_Mem_Write (&hi2c1,0xD0, SendAddress, 1, &SendData, 1, 0xff) ;
  8.         SendAddress = 0x19;
  9.         SendData = 0x07; //采樣率分頻器
  10.         HAL_I2C_Mem_Write (&hi2c1,0xD0, SendAddress, 1, &SendData, 1,0xff);
  11.         SendAddress = 0x1A; //低通濾波器
  12.         SendData = 0x06;
  13.         HAL_I2C_Mem_Write (&hi2c1,0xD0,SendAddress, 1, &SendData, 1, 0xff);
  14.         SendAddress = 0x1B; //陀螺儀
  15.         SendData = 0x08;//±500°/s
  16.         HAL_I2C_Mem_Write (&hi2c1,0xD0, SendAddress,1, &SendData, 1,0xff);
  17.         SendAddress = 0x1C; //加速度計
  18.         SendData = 0x00;//±2g
  19.         HAL_I2C_Mem_Write(&hi2c1,0xD0, SendAddress, 1, &SendData, 1, 0xff);
  20.
  21. }
函數部分
  1. uint8_t MPU_DATA[14]={0};
  2.         uint8_t StartAddress=0x68;
  3.         double ACCEL_XOUT = 0.0,ACCEL_YOUT=0.0,ACCEL_ZOUT=0.0;
  4.         double GYR0_XOUT = 0.0,GYR0_YOUT = 0.0,GYR0_ZOUT = 0.0;
  5.         MPU6050_INIT();
  6.   /* USER CODE END 2 */
  7.   /* Infinite loop */
  8.   /* USER CODE BEGIN WHILE */
  9.   while (1)
  10.   {
  11.     /* USER CODE END WHILE */
  12.         HAL_I2C_Mem_Read (&hi2c1,0xD1, StartAddress, I2C_MEMADD_SIZE_8BIT,MPU_DATA, 14, 50);
  13.         float Temp = (MPU_DATA[6]<<8)|MPU_DATA[7];
  14.         if(Temp >32768) Temp-=65536;
  15.         Temp = (36.53+ Temp/340);
  16.
  17.         short int ACCEL_XOUT1 = (( MPU_DATA[0]<<8) | MPU_DATA[1]);ACCEL_XOUT = (double)ACCEL_XOUT1/16384;
  18.         short int ACCEL_YOUT1 = (( MPU_DATA[2]<<8) | MPU_DATA[3]);ACCEL_XOUT =(double)ACCEL_YOUT1/16384;
  19.         short int ACCEL_ZOUT1 = (( MPU_DATA[4]<<8) | MPU_DATA[5]);ACCEL_ZOUT = (double)ACCEL_ZOUT1/16384;
  20.
  21.         short int GYRO_XOUT1= ((MPU_DATA[8]<<8) | MPU_DATA[9]);GYR0_XOUT = (double)GYRO_XOUT1/65.5;
  22.         short int GYRO_YOUT1=((MPU_DATA[10]<<8) | MPU_DATA[11]);GYR0_YOUT = (double)GYRO_YOUT1/65.5;
  23.         short int GYRO_ZOUT1= ((MPU_DATA[12]<<8) | MPU_DATA[13]);GYR0_ZOUT = (double)GYRO_ZOUT1/65.5;
  24.
  25.         printf("temp= %0.2f" ,Temp);
  26.         printf("X= %0.2f,y=%0.2f,z=%0.2f," ,ACCEL_XOUT,ACCEL_YOUT,ACCEL_ZOUT);
  27.         printf("X= %0.2f,y=%0.2f,z=%0.2f," ,GYR0_XOUT,GYR0_YOUT,GYR0_ZOUT);
  28.         printf("\r\n");
  29.         HAL_Delay(200);
  30.
  31.   }
聽了上次問題中的大佬回答,將讀寫地址分別改為0xD1和0xD0
然后現象就是開頭所言。
求大佬解惑:
出現這樣的數據接收結果是哪里有問題?
軟件?程序?硬件?接線?設置?初始化?還是一開始的理解就有問題?
折騰了快一天了,明天再看看江科大的32視頻中關于mpu6050的部分
ID:1148020 發表于 2025-4-14 18:18 | 顯示全部樓層
您好請問解決了嗎,我的mpu6050也是這個問題,跑神經網絡的代碼輸出一直固定,現在我懷疑是不是沒用電源線給stm32供電導致mpu6050測量不完全
ID:1142986 發表于 2025-4-14 20:27 | 顯示全部樓層
老黃忠 發表于 2025-4-14 18:18
您好請問解決了嗎,我的mpu6050也是這個問題,跑神經網絡的代碼輸出一直固定,現在我懷疑是不是沒用電源線 ...
我問了豆包,它給出的解決是
將電源管理寄存器 1 地址改為 0x6B,而非 0x68;
將讀取數據的起始寄存器地址為 0x3B(加速度計 X 高位),而非 0x68。
主站蜘蛛池模板: 久久国产小视频 | 可以看的毛片 | 亚洲欧美精品一区二区 | 国产视频一区二区在线观看 | 中文字幕第一 | 婷婷狠狠爱 | 性做久久久久久久免费看 | 国产乱轮视频 | 久久久影院 | 欧美一区二区 | 欧美日韩a | 日韩一区二区在线播放 | 91日韩欧美 | 国产精品久久久国产盗摄 | 大尺度做爰呻吟舌吻网站 | 欧美日韩在线观看视频 | 久久综合伊人77777蜜臀 | 俺去俺来也在线www色官网 | 精品视频在线观看免费 | 久久天天 | 日本在线观看 | 日韩在线观看一区 | 在线不卡一区二区 | 夜夜草av | 欧美日韩亚洲另类 | 一级片在线播放 | 欧美在线视频观看 | 免费a网站| 91麻豆精品国产91久久久久久久久 | 亚洲黄色在线 | 亚洲视频区 | 欧美性猛交xxxx黑人猛交 | 免费观看全黄做爰大片视频美国 | 久久九九国产 | 日本不卡在线视频 | 伊人成人在线视频 | 国产精品一区二区三区免费 | 毛片免费观看视频 | 国产精品99久久久久久久久久久久 | 欧美激情一区二区 | 九九九精品视频 |
