查看: 467|回復(fù): 1
求助單片機(jī)仿真程序,找不到修復(fù)的地方
ID:1144486 發(fā)表于 2025-4-22 14:22 | 顯示全部樓層 |閱讀模式
求求各位指導(dǎo)一下我維修的方向,程序仿真lcd1602不顯示任何字符,按鈕只有最后一列有反饋
所有程序:
dht11.h的程序:
// dht11.h
#ifndef __DHT11_H__
#define __DHT11_H__
#include "main.h"
void DHT11_Start(void);
unsigned char DHT11_Read(void);
float Read_TRH(UCHAR channel);
#endif
dht11.c的程序:
// dht11.c
#include "adc0832.h"
#include "delay.h"
#include "dht11.h"
#include "HW_key.h"
#include "main.h"
#include "lcd1602.h"
#include <intrins.h>
#include <reg52.h>
sbit DHT11_DATA = P1^7;  // 定義數(shù)據(jù)引腳
// 函數(shù)聲明
void DHT11_Start(void) {
    DHT11_DATA = 0;
    Delay_ms(18);
    DHT11_DATA = 1;
    Delay_us(30);
unsigned char DHT11_Read(void) {
    unsigned char i = 0;
        unsigned char received_data = 0;
    for(i = 0; i < 8; i++) {  // 變量i必須在循環(huán)外聲明
        received_data <<= 1;
        while(!DHT11_DATA);
        Delay_us(30);
        if(DHT11_DATA)
            received_data |= 0x01;
        while(DHT11_DATA);
    return received_data;
float Read_TRH(UCHAR channel) {
    unsigned char dht_data[5]; // 重命名數(shù)組
    unsigned char i; // 提前聲明循環(huán)變量
    float temperature = 0.0;
    float humidity = 0.0;
    DHT11_Start();
    for(i = 0; i < 5; i++) {
        dht_data[i] = DHT11_Read(); // 使用新名稱
    if(dht_data[4] == (dht_data[0] + dht_data[1] + dht_data[2] + dht_data[3])) {
        if(channel == 1) {
            temperature = dht_data[2];
            temperature += dht_data[3] / 10.0;
            if (dht_data[2] & 0x80) {
                temperature = -((dht_data[2] & 0x7F) + dht_data[3] / 10.0);
            return temperature;
        else if(channel == 0) {
            humidity = (dht_data[0] * 256.0 + dht_data[1]) / 10.0;
            return humidity;
    return 0.0;
adc0832.h的程序:
// adc0832.h
#ifndef __ADC0832_H__
#define __ADC0832_H__
#include "main.h"
sbit ADC0832_CS = P1^2;  // 避免與其它模塊共用P1口
sbit ADC0832_CLK = P1^1;
sbit ADC0832_DI = P1^0;
sbit ADC0832_DO = P1^0;
// 函數(shù)聲明
unsigned char ADC0832_Read(unsigned char channel);
#endif // __ADC0832_H__
adc0832.c的程序:
// adc0832.c
#include "delay.h"
#include "dht11.h"
#include "HW_key.h"
#include "main.h"
unsigned char ADC0832_Read(unsigned char channel) {
    unsigned char i;
        unsigned char adc_data = 0;  // 變量名改為 adc_data
    ADC0832_CS = 0;
    ADC0832_CLK = 0;
    ADC0832_DI = 1;
    ADC0832_CLK = 1; _nop_(); ADC0832_CLK = 0;
    ADC0832_DI = (channel >> 0) & 0x01;
    ADC0832_DI = (channel >> 1) & 0x01;
        ADC0832_CLK = 1;
        adc_data <<= 1;          // 同步修改變量名
        if(ADC0832_DO) {
            adc_data |= 0x01;    // 同步修改變量名
        ADC0832_CLK = 0;
    ADC0832_CS = 1;
    return adc_data;             // 同步修改變量名
delay.c的程序:
// delay.c
#include "delay.h"
#include "dht11.h"
#include "HW_key.h"
#include "main.h"
void Delay_ms(u16 ms) {
    u16 i, j;
    for(i = 0; i < ms; i++)
        for(j = 0; j < 120; j++);
void Delay_us(u16 us) {
    while(us--) {
        _nop_(); _nop_(); _nop_(); _nop_(); // 約1us(根據(jù)晶振頻率調(diào)整)
delay.h的程序:
// delay.h
#ifndef __DELAY_H__
#define __DELAY_H__
#include "main.h"
void Delay_ms(u16 ms);
void Delay_us(u16 us);
#endif // __DELAY_H__
lcd1602.c的程序:
#include "delay.h"
#include "dht11.h"
#include "HW_key.h"
#include "main.h"
#include <intrins.h>  // 包含_nop_()函數(shù)
// 全局變量定義(嚴(yán)格符合C89規(guī)范)
LCD_Command lcdQueue[LCD_QUEUE_SIZE];
unsigned char lcdQueueCount = 0;
unsigned char lcdQueueHead = 0;
unsigned char lcdQueueTail = 0;
  // 定義尾指針
bit lcdBusy = 0;
// 命令寫(xiě)入函數(shù)
void WriteCOMDATA(unsigned char lcd_data, unsigned char cmd) {
    if(lcdQueueCount >= LCD_QUEUE_SIZE) return;
    lcdQueue[lcdQueueTail].lcd_data = lcd_data;
    lcdQueue[lcdQueueTail].isCommand = cmd;
    lcdQueueTail = (lcdQueueTail + 1) % LCD_QUEUE_SIZE;
    lcdQueueCount++;
// LCD初始化
void LCD_Init(void) {
    Delay_ms(20);
    WriteCOMDATA(0x38, 1);  // 8位模式,雙行顯示
    Delay_ms(5);
        while (lcdQueueCount > 0);
    WriteCOMDATA(0x0C, 1);  // 顯示開(kāi),光標(biāo)關(guān)
        WriteCOMDATA(0x06, 1);  // 光標(biāo)右移
    WriteCOMDATA(0x01, 1);  // 清屏
    Delay_ms(5);
// 字符寫(xiě)入函數(shù)
void WriteChar(unsigned char Row, unsigned char Col, unsigned char Num, unsigned char *pBuffer) {
    unsigned char address, i;
    // 計(jì)算地址
    address = (Row == 1) ? (0x80 + Col) : (0xC0 + Col);
    WriteCOMDATA(address, 1);
    // 寫(xiě)入數(shù)據(jù)
    for(i = 0; i < Num; i++) {
        WriteCOMDATA(*pBuffer++, 0);
// 命令處理函數(shù)(定時(shí)器中斷中調(diào)用)
void LCD_Process(void) interrupt 1 {
    if(lcdQueueCount > 0 && !lcdBusy) {
        LCD_Command cmd;
        // 提取命令
        cmd = lcdQueue[lcdQueueHead];
        lcdQueueHead = (lcdQueueHead + 1) % LCD_QUEUE_SIZE;
        lcdQueueCount--;
        // 硬件操作
        lcdBusy = 1;
        RS = cmd.isCommand ? 0 : 1;
        RW = 0;
        LCD_PINDATA = cmd.lcd_data;
        E = 1;
        _nop_(); _nop_(); _nop_(); _nop_();  // 至少保持300ns
        E = 0;
        Delay_us(100);  // 確保命令執(zhí)行完成
        lcdBusy = 0;
lcd1602.h的程序:
#ifndef __LCD1602_H__
#define __LCD1602_H__
#include "main.h"
// 隊(duì)列長(zhǎng)度定義
#define LCD_QUEUE_SIZE 16
// 命令結(jié)構(gòu)體
typedef struct {
    unsigned char lcd_data;
    unsigned char isCommand;
} LCD_Command;
typedef unsigned char u8;  // 添加u8類型定義
extern LCD_Command lcdQueue[LCD_QUEUE_SIZE];
extern unsigned char lcdQueueCount;
extern unsigned char lcdQueueHead;
extern unsigned char lcdQueueTail;  // 新增聲明
extern bit lcdBusy;
// 函數(shù)聲明
void WriteCOMDATA(UCHAR lcd_data, UCHAR cmd);
void LCD_Init(void);
void WriteChar(UCHAR Row, UCHAR Col, UCHAR Num, UCHAR *pBuffer);
void LCD_Process(void) interrupt 1;;
#endif
HW_key.c的程序:
// HW_key.c
#include "delay.h"
#include "dht11.h"
#include "HW_key.h"
#include "main.h"
UCHAR Key_row = 0x0F; // 初始化為無(wú)按鍵狀態(tài)
UCHAR KEY_ROW_SCAN(void) {
    // 讀取行引腳狀態(tài)
    Key_row = 0x0F; // 默認(rèn)無(wú)按鍵
    if (ROW1 == 0) Key_row &= ~0x08; // 第1行
    if (ROW2 == 0) Key_row &= ~0x04; // 第2行
    if (ROW3 == 0) Key_row &= ~0x02; // 第3行
    if (ROW4 == 0) Key_row &= ~0x01; // 第4行
    if (Key_row != 0x0F) { // 有按鍵按下
        Delay_ms(10); // 消抖
            return Key_row;
    return 0x0F; // 無(wú)按鍵按下
UCHAR KEY_SCAN(void) {
    char key = 0;
    char row = KEY_ROW_SCAN();
    if(row != 0x0F) {
        // 掃描列前復(fù)位
        COL1 = 1; COL2 = 1; COL3 = 1; COL4 = 1;
        // 掃描列
        COL1 = 1; COL2 = 0; COL3 = 1; COL4 = 1;
        if(!ROW1) key = '1';
        else if(!ROW2) key = '2';
        else if(!ROW3) key = '3';
        else if(!ROW4) key = 'A';
        COL1 = 0; COL2 = 1; COL3 = 1; COL4 = 1;
        if(!ROW1) key = '4';
        else if(!ROW2) key = '5';
        else if(!ROW3) key = '6';
        else if(!ROW4) key = 'B';
        COL1 = 1; COL2 = 1; COL3 = 0; COL4 = 1;
        if(!ROW1) key = '7';
        else if(!ROW2) key = '8';
        else if(!ROW3) key = '9';
        else if(!ROW4) key = 'C';
        COL1 = 1; COL2 = 1; COL3 = 1; COL4 = 0;
        if(!ROW1) key = '*';
        else if(!ROW2) key = '0';
        else if(!ROW3) key = '#';
        else if(!ROW4) key = 'D';
    return key;
void HW_KEY_FUNCTION(void) {
    char key = KEY_SCAN();
    if(key != 0x0F) {
        // 根據(jù)按鍵執(zhí)行相應(yīng)操作
        switch(key) {
            // 第一行按鍵:調(diào)整溫度上限和下限閾值
            case '1':
                T1H = (T1H < 99) ? T1H + 1 : 99;
                break;
            case '2':
                T1H = (T1H > T1L + 1) ? T1H - 1 : T1L + 1;
                break;
            case '3':
                T1L = (T1L < T1H - 1) ? T1L + 1 : T1H - 1;
                break;
            case 'A':
                T1L = (T1L > 0) ? T1L - 1 : 0;
                break;
            // 第二行按鍵:調(diào)整濕度上限和下限閾值
            case '4':
                R1H = (R1H < 99) ? R1H + 1 : 99;
                break;
            case '5':
                R1H = (R1H > R1L + 1) ? R1H - 1 : R1L + 1;
                break;
            case '6':
                R1L = (R1L < R1H - 1) ? R1L + 1 : R1H - 1;
                break;
            case 'B':
                             R1L = (R1L > 0) ? R1L - 1 : 0;
                break;
            // 第三行按鍵:調(diào)整PM2.5上限和下限閾值
            case '7':
                HPM = (HPM < 9999) ? HPM + 1 : 9999;
                break;
            case '8':
                HPM = (HPM > 0) ? HPM - 1 : 0;
                break;
            case '9':
                break;
            case 'C':
                break;
            // 第四行按鍵:進(jìn)入設(shè)置模式,確認(rèn)操作,返回上一級(jí)操作,以及返回當(dāng)前讀取的溫度、濕度和PM2.5頁(yè)面
            case '*':
                shezhi_flag = (shezhi_flag + 1) % 7; // 進(jìn)入設(shè)置模式
                break;
            case '0':
                shezhi_flag = 0; // 確認(rèn)操作
                break;
            case '#':
                shezhi_flag = 0; // 返回上一級(jí)操作
                break;
            case 'D':
                shezhi_flag = 0; // 返回當(dāng)前讀取的頁(yè)面
                break;
            default:
                break;
HW_key.h的程序:
// HW_key.h
#ifndef __HW_KEY_H__
#define __HW_KEY_H__
#include "main.h"
extern UCHAR Key_row; // 全局變量聲明
UCHAR KEY_ROW_SCAN(void);
UCHAR KEY_SCAN(void);
void HW_KEY_FUNCTION(void);
#endif // __HW_KEY_H__
main.c的程序:
// main.c
#include "main.h"
#include "LCD1602.h"
#include "dht11.h"
#include "HW_key.h"
#include "delay.h"
#include "keymap.h"
#include <stdio.h>
#include <string.h>
// 全局變量定義
int T1L = 12;    // 溫度下限閾值初始值
int T1H = 35;    // 溫度上限閾值初始值
int R1L = 15;    // 濕度下限閾值初始值
int R1H = 60;    // 濕度上限閾值初始值
int HPM = 75;    // PM2.5 上限閾值初始值
UCHAR shezhi_flag = 0; // 設(shè)置模式標(biāo)志
UCHAR Mode_flag = 0;   // 工作模式標(biāo)志
float pm1 = 0.0;      // 溫度值
float pm2 = 0.0;      // 濕度值
float PM = 0.0;       // PM2.5 值
extern int T1L, T1H, R1L, R1H, HPM;
extern UCHAR shezhi_flag, Mode_flag;
// main.c 中實(shí)現(xiàn) read_data:
float read_data(UCHAR channel) {
    return (float)ADC0832_Read(channel);  // 調(diào)用 ADC0832_Read
// 主函數(shù)
void main(void) {
    // 初始化各個(gè)模塊
        Timer0_Init();
    LCD_Init();
    // 主循環(huán)
    while(1) {
        // 1. 讀取傳感器數(shù)據(jù)
        pm1 = Read_TRH(1); // 讀取溫度,假設(shè)通道1為溫度
        pm2 = Read_TRH(0); // 讀取濕度,假設(shè)通道0為濕度
        PM = read_data(2);     // 讀取PM2.5,假設(shè)通道2為PM2.5
        // 2. 處理按鍵輸入
        HW_KEY_FUNCTION();
        // 3. 檢查閾值并控制報(bào)警
        check_thresholds();
        // 4. 更新LCD顯示
        update_display();
        // 5. 延時(shí)以穩(wěn)定讀取頻率
                set_parameters();
        Delay_ms(200); // 根據(jù)需要調(diào)整延時(shí)
// 檢查閾值并控制報(bào)警
void check_thresholds(void) {
    bit temp_alarm = (pm1 > T1H || pm1 < T1L);
    bit humi_alarm = (pm2 > R1H || pm2 < R1L);
    bit pm_alarm = (PM > HPM);
    BUZZER = (temp_alarm || humi_alarm || pm_alarm) ? 0 : 1;
    LED1 = (pm1 > T1H) ? 0 : 1;  // 溫度上限報(bào)警
    LED2 = (pm1 < T1L) ? 0 : 1;  // 溫度下限報(bào)警
    LED3 = (pm2 > R1H) ? 0 : 1;  // 濕度上限報(bào)警
    LED4 = (pm2 < R1L) ? 0 : 1;  // 濕度下限報(bào)警
    LED5 = (PM > HPM) ? 0 : 1;   // PM2.5報(bào)警
// 更新LCD顯示
void update_display(void) {
    char buffer[16];
    // 顯示溫度
    sprintf(buffer, "T:%dC", (int)pm1);
    WriteChar(1, 1, strlen(buffer), buffer);
    // 顯示濕度
    sprintf(buffer, "H:%d%%", (int)pm2);
    WriteChar(1, 9, strlen(buffer), buffer);
    // 顯示PM2.5
    sprintf(buffer, "PM2.5:%d", (int)PM);
    WriteChar(2, 1, strlen(buffer), buffer);
void Timer0_Init(void) {
    TMOD |= 0x01;    // 模式1(16位定時(shí)器)
    TH0 = 0x3C;      // 12MHz,50ms中斷
    TL0 = 0xB0;
    ET0 = 1;         // 啟用中斷
    EA = 1;          // 全局中斷使能
    TR0 = 1;               // 啟動(dòng)定時(shí)器0
// 設(shè)置參數(shù)處理函數(shù)
void set_parameters(void) {
    // 根據(jù) shezhi_flag 設(shè)置不同的參數(shù)
    // shezhi_flag = 0: 設(shè)置溫度上限
    // shezhi_flag = 1: 設(shè)置溫度下限
    // shezhi_flag = 2: 設(shè)置濕度上限
    // shezhi_flag = 3: 設(shè)置濕度下限
    // shezhi_flag = 4: 設(shè)置PM2.5上限
    // shezhi_flag = 5: 設(shè)置PM2.5下限
    // shezhi_flag = 6: 退出設(shè)置模式
    switch(shezhi_flag) {
        case 0:
            // 設(shè)置溫度上限
            break;
        case 1:
            // 設(shè)置溫度下限
            break;
        case 2:
            // 設(shè)置濕度上限
            break;
        case 3:
            // 設(shè)置濕度下限
            break;
        case 4:
            // 設(shè)置PM2.5上限
            break;
        case 5:
            // 設(shè)置PM2.5下限
            // 這里假設(shè)沒(méi)有單獨(dú)的PM2.5下限設(shè)置,可以根據(jù)需要調(diào)整
            // 例如:
            // PM2.5_L = (PM2.5_L < HPM - 1) ? PM2.5_L + 1 : HPM - 1;
            break;
        case 6:
            // 退出設(shè)置模式
            shezhi_flag = 0;
            break;
        default:
            shezhi_flag = 0;
            break;
// 鍵盤(pán)掃描函數(shù)
main.h的程序:
// main.h
#ifndef __MAIN_H__
#define __MAIN_H__
#include <reg52.h>
#include <string.h>
// 統(tǒng)一硬件接口定義
sbit RS = P1^4;   // LCD 控制引腳
sbit RW = P1^5;
sbit E  = P1^6;
sbit COL1 = P3^4; // 鍵盤(pán)列
sbit COL2 = P3^5;
sbit COL3 = P3^6;
sbit COL4 = P3^7;
sbit ROW1 = P3^0; // 鍵盤(pán)行
sbit ROW2 = P3^1;
sbit ROW3 = P3^2;
sbit ROW4 = P3^3;
sbit LED1 = P2^0; // 溫度上限報(bào)警
sbit LED2 = P2^1; // 溫度下限報(bào)警
sbit LED3 = P2^2; // 濕度上限報(bào)警
sbit LED4 = P2^3; // 濕度下限報(bào)警
sbit LED5 = P2^4; // PM2.5 上限報(bào)警
sbit BUZZER = P1^3; // 蜂鳴器
#define LCD_PINDATA P0
typedef unsigned char UCHAR;
typedef unsigned int  u16;
typedef unsigned long u32;
// 全局變量聲明(extern)
extern int T1H, T1L, R1H, R1L, HPM;
void Timer0_Init(void);           // 定時(shí)器初始化
float read_data(UCHAR channel);   // 讀取PM2.5數(shù)據(jù)
void check_thresholds(void);      // 閾值檢查
void update_display(void);        // 顯示更新
void set_parameters(void);        // 設(shè)置參數(shù)處理
UCHAR KEY_SCAN(void);             // 按鍵掃描
void HW_KEY_FUNCTION(void);       // 按鍵功能處理
#endif
ID:584814 發(fā)表于 2025-4-27 11:10 | 顯示全部樓層
1、在本論壇找現(xiàn)成的;
2、上含仿真的全部工程文件
主站蜘蛛池模板: 亚洲精品免费在线观看 | 综合久久99| 91在线视频播放 | 夜夜骑夜夜操 | 免费国产一区二区 | 国产成人午夜 | 黄色成人毛片 | 99久久精品一区二区成人 | 黄色免费大片 | 成人免费视频视频 | 精品网站999www | 久久香蕉国产 | 黑人系列合集h | 天天草天天干 | 免费的毛片 | 狠狠久| 精品国产99久久久久久宅男i | 成人综合婷婷国产精品久久 | 黄色大片在线免费观看 | 亚洲精品一二三区 | 欧美日韩小视频 | 国产日本在线观看 | 黄色一节片 | 国产三级黄色片 | 激情五月综合网 | 黄色片网站在线观看 | 亚洲国产小视频 | 不卡在线视频 | 亚洲经典av | 国产黄色在线播放 | 一区中文字幕 | 中文字幕日韩高清 | 九九久久精品视频 | 一区二区三区久久 | 亚洲一区二区在线视频 | 天天干夜夜骑 | 人人综合网 | 私人午夜影院 | 黄色a一级 | 亚洲精品www久久久久久广东 | 自由成熟xxxx色视频 |
