可以參考這個(gè)測(cè)試程序
- //測(cè)試條件:TX-1C實(shí)驗(yàn)板,轉(zhuǎn)換板MCU型號(hào)IAP15W4K58S4,系統(tǒng)時(shí)鐘11.0592MHz
- //注意:測(cè)試本示例時(shí),需在ISP下載時(shí)將低壓復(fù)位功能和低壓時(shí)禁止EEPROM操作關(guān)閉
- #include "STC15Fxxxx.H"
- #include <intrins.h> //庫(kù)頭文件
- #define uint unsigned int //宏定義數(shù)據(jù)類型uint
- #define uchar unsigned char //宏定義數(shù)據(jù)類型uchar
- //宏定義ISP的操作命令
- #define CMD_IDLE 0 //空閑模式
- #define CMD_READ 1 //IAP字節(jié)讀命令
- #define CMD_PROGRAM 2 //IAP字節(jié)編程命令
- #define CMD_ERASE 3 //IAP扇區(qū)擦除命令
- #define ENABLE_IAP 0x82 //CPU的等待時(shí)間
- #define IAP_ADDRESS 0x0800 //測(cè)試地址
- sbit duan=P2^6;
- sbit wein=P2^7;
- //順序共陰極數(shù)碼管段碼表,段碼a-h順序接PX0-PX7
- uchar code table[]={//共陰數(shù)碼管段碼"0~f-."
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71,0x40,0x80};
- uchar data dis_buf[8]; //緩存數(shù)組
- uint num,sec;
- uchar i;
- void Timer0Init(); //定時(shí)器初始化聲明
- void IapIdle(); //關(guān)閉IAP/EEPROM
- uchar IapReadByte(uint addr); //讀取EEPROM數(shù)據(jù)
- void IapProgramByte(uint addr, uchar dat);//寫入EEPROM數(shù)據(jù)
- void IapEraseSector(uint addr); //擦除EEPROM數(shù)據(jù)
- void main()
- P0M0 = 0x00;
- P0M1 = 0x00;
- P1M0 = 0x00;
- P1M1 = 0x00;
- P2M0 = 0x00;
- P2M1 = 0x00;
- P3M0 = 0x00;
- P3M1 = 0x00;
- P4M0 = 0x00;
- P4M1 = 0x00;
- P5M0 = 0x00;
- P5M1 = 0x00;
- P6M0 = 0x00;
- P6M1 = 0x00;
- P7M0 = 0x00;
- P7M1 = 0x00;
- sec=IapReadByte(IAP_ADDRESS)<<8|IapReadByte(IAP_ADDRESS+1);//讀取保存的數(shù)據(jù) 用時(shí)11.75us
- if(sec==0xffff)//如果沒有保存數(shù)據(jù)
- sec=0;//變量為0
- else IapEraseSector(IAP_ADDRESS);//擦除數(shù)據(jù),為下次掉電保存數(shù)據(jù)做準(zhǔn)備
- PCON &= 0xDF;//清0掉電標(biāo)志
- ELVD = 1;//開低壓中斷
- EA = 1;//開總中斷
- Timer0Init();//初始化定時(shí)器
- while(1)
- if(TF0)//查詢T0中斷請(qǐng)求標(biāo)志
- TF0=0;//T0中斷請(qǐng)求標(biāo)志清0
- if(++num>=1000)//1秒
- num=0;
- sec++;
- dis_buf[0]=table[sec/10000%10];
- dis_buf[1]=table[sec/1000%10];
- dis_buf[2]=table[sec/100%10];
- dis_buf[3]=table[sec/10%10];
- dis_buf[4]=table[sec%10];
- P0=0x00;duan=1;duan=0;
- P0=~(0x01<<i);wein=1;wein=0;
- P0=dis_buf[i];duan=1;duan=0;
- i=++i%5;
- void Timer0Init(void) //1毫秒@11.0592MHz
- AUXR |= 0x80; //定時(shí)器時(shí)鐘1T模式
- TMOD &= 0xF0; //設(shè)置定時(shí)器模式
- TL0 = 0xCD; //設(shè)置定時(shí)初始值
- TH0 = 0xD4; //設(shè)置定時(shí)初始值
- TF0 = 0; //清除TF0標(biāo)志
- TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
- 關(guān)閉IAP功能
- void IapIdle()
- IAP_CONTR = 0; //關(guān)閉IAP功能
- IAP_CMD = 0; //清除命令寄存器
- IAP_TRIG = 0; //清除觸發(fā)寄存器
- IAP_ADDRH = 0x80; //將地址設(shè)置到非IAP區(qū)域
- IAP_ADDRL = 0;
- 從ISP/IAP/EEPROM區(qū)域讀取一字節(jié)
- uchar dat; //數(shù)據(jù)緩沖區(qū)
- IAP_CONTR = ENABLE_IAP; //使能IAP
- IAP_CMD = CMD_READ; //設(shè)置IAP命令
- IAP_ADDRL = addr; //設(shè)置IAP低地址
- IAP_ADDRH = addr >> 8; //設(shè)置IAP高地址
- IAP_TRIG = 0x5a; //寫觸發(fā)命令(0x5a)
- IAP_TRIG = 0xa5; //寫觸發(fā)命令(0xa5)
- _nop_(); //等待ISP/IAP/EEPROM操作完成
- dat = IAP_DATA; //讀ISP/IAP/EEPROM數(shù)據(jù)
- IapIdle(); //關(guān)閉IAP功能
- return dat; //返回
- 寫一字節(jié)數(shù)據(jù)到ISP/IAP/EEPROM區(qū)域
- IAP_CMD = CMD_PROGRAM; //設(shè)置IAP命令
- IAP_DATA = dat; //寫ISP/IAP/EEPROM數(shù)據(jù)
- ISP/IAP/EEPROM扇區(qū)擦除
- IAP_CMD = CMD_ERASE; //設(shè)置IAP命令
- void PowerLost() interrupt 6 //剩余電量從中斷開始到完全斷電2.5ms
- EA = 0; //關(guān)閉總中斷
- P0M1 = 0xff; //所有端口高阻用時(shí)2.75us
- P1M1 = 0xff;
- P2M1 = 0xff;
- P3M1 = 0xff;
- P4M1 = 0xff;
- P5M1 = 0xff;
- P6M1 = 0xff;
- P7M1 = 0xff;
- IapProgramByte(IAP_ADDRESS,sec>>8);//寫數(shù)據(jù)高8位到EEPROM
- IapProgramByte(IAP_ADDRESS+1,sec);//寫數(shù)據(jù)低8位到EEPROM 寫兩個(gè)字節(jié)用時(shí)215.25us
- while((PCON & 0x20) != 0) //復(fù)查低壓標(biāo)志
- PCON &= 0xDF; //清除低壓標(biāo)志
- _nop_();
- _nop_(); //坐等掉電
- IAP_CONTR = 0x20; //發(fā)現(xiàn)是誤報(bào),重啟單片機(jī),恢復(fù)正常工作
復(fù)制代碼 |
