查看: 360|回復: 3
STM32怎么連AD9959
ID:1152879 發表于 2025-6-5 21:06 | 顯示全部樓層 |閱讀模式
孩子想整個電路,用32連9959產生幾個有相位差的信號,有佬指點一下怎么做原理圖和程序嗎?
ID:1128898 發表于 2025-6-6 03:57 | 顯示全部樓層
多讀書
ID:1153200 發表于 2025-6-9 09:36 | 顯示全部樓層
配置 SPI 的工作模式,數據傳輸方向設為雙線單向,數據大小為 8 位,時鐘極性和相位根據 AD9959 的要求來定。// 初始化SPI void SPI1_Init(void) {     SPI_InitTypeDef SPI_InitStructure;     GPIO_InitTypeDef GPIO_InitStructure;          // 使能SPI1和GPIOA時鐘     RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1 | RCC_APB2Periph_GPIOA, ENABLE);          // 配置SPI1引腳:SCK(PA5)、MISO(PA6)、MOSI(PA7)     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;     GPIO_Init(GPIOA, &GPIO_InitStructure);          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;     GPIO_Init(GPIOA, &GPIO_InitStructure);          // 配置NSS引腳(PA4)     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;     GPIO_Init(GPIOA, &GPIO_InitStructure);     GPIO_SetBits(GPIOA, GPIO_Pin_4);  // 使能NSS          // SPI1配置     SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;     SPI_InitStructure.SPI_Mode = SPI_Mode_Master;     SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;     SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;     SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;     SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;     SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;     SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;     SPI_InitStructure.SPI_CRCPolynomial = 7;     SPI_Init(SPI1, &SPI_InitStructure);          // 使能SPI1     SPI_Cmd(SPI1, ENABLE); }  // 向AD9959寫數據 void AD9959_WriteByte(uint8_t addr, uint8_t data) {     uint8_t cmd;          // 拉低FSYNC開始傳輸     GPIO_ResetBits(GPIOA, GPIO_Pin_4);          // 發送地址(最高位為0表示寫操作)     cmd = addr & 0x7F;     while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);     SPI_I2S_SendData(SPI1, cmd);     while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);     SPI_I2S_ReceiveData(SPI1);          // 發送數據     while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);     SPI_I2S_SendData(SPI1, data);     while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);     SPI_I2S_ReceiveData(SPI1);          // 拉高FSYNC結束傳輸     GPIO_SetBits(GPIOA, GPIO_Pin_4); }
ID:1153641 發表于 2025-6-11 21:30 | 顯示全部樓層
相位計算:
AD9959 的相位寄存器為 14 位,范圍 0-16383
相位角度 = 相位字 × 360°/16384
例如:90 度相位差對應的相位字 = 16384 × 90°/360° = 4096
頻率計算:
頻率字 = (目標頻率 × 2^32) / 系統時鐘頻率
例如:系統時鐘 1GHz,1kHz 頻率對應的頻率字 = 1000 × 4294967296 / 1000000000 ≈ 4295
硬件設計注意事項
為 AD9959 提供穩定的電源(通常需要 3.3V 和 1.8V)
時鐘輸入要干凈,建議使用晶振
輸出端添加適當的低通濾波器,改善信號質量
PCB 布局時注意數字地和模擬地分離,單點連接
調試建議
先用示波器測量 AD9959 的時鐘輸入,確保時鐘穩定
逐步調試每個通道,先確認基本功能
使用邏輯分析儀監控 SPI 通信,檢查命令是否正確發送
先設置相同頻率,調整相位差,觀察波形關系
主站蜘蛛池模板: 亚洲深夜福利 | 日韩中文字幕在线视频 | 噜噜噜在线 | 午夜免费福利 | 亚洲一区欧美一区 | 亚洲在线一区二区 | 欧美性精品 | 天天操狠狠干 | 免费不卡av | 91美女片黄在线观看91美女 | 久久精品日韩 | 精品伊人久久 | 日韩精品在线观看视频 | 黄色一级大片 | 日韩精品网 | 欧美日韩中文在线 | 天天操天天拍 | 蜜桃在线观看视频 | 成人免费看片98欧美 | 中文字幕日韩欧美 | 国产性猛交╳xxx乱大交 | 日韩中文字幕一区二区三区 | 中文字幕丰满人伦在线 | 欧美爱爱视频 | 一级欧美一级日韩 | 高清免费视频日本 | 久久亚洲欧美 | 91精品国产综合久久久久久 | 国产又黄又爽视频 | 黄色国产在线观看 | 免费av网址在线观看 | 天堂av在线资源 | 免费在线观看毛片 | 久久精品在线播放 | 午夜精品国产 | 69视频网站 | 国产精品久久久国产盗摄 | 欧美日韩亚洲天堂 | www.色综合 | 成年人免费在线视频 | 一区二区免费 |
