查看: 175|回復(fù): 0
51單片機(jī)舞蹈機(jī)器人 步進(jìn)電機(jī)Proteus仿真圖源程序
單片機(jī)源程序如下:
  1. #include "reg51.h"
  2. #include "intrins.H"
  3. //8步式步進(jìn)電機(jī)脈沖序列
  4. //unsigned char steps[8] = {0x77,0x33,0xbb,0x99,0xdd,0xcc,0xee,0x66};
  5. unsigned char steps[8] = {0x2,0x6,0x4,0xc,0x8,0x9,0x1,0x3};
  6. //當(dāng)前各電機(jī)在上述序列中的位置
  7. unsigned char cur_step[8] = {0,0,0,0,0,0,0,0};
  8. //這個(gè)文件用于記錄舞步信息序列
  9. char speed_tickers[8] = {0,0,0,0,0,0,0,0};
  10. //從上述文件中讀出的當(dāng)前舞步信息
  11. unsigned char speeds[8] = {0,0,0,0,0,0,0,0};
  12. unsigned char data_pointer = 0;//指向舞步數(shù)據(jù)的指針
  13. unsigned char time_t = 0;//指定重新讀取一次 speeds 值的計(jì)時(shí)周期
  14. code char dancedata[] = {54,15,12,12,87,95,65,45,-89,-88,-54,-54,54,68,-45,-65,-65,-48,101,121,115,117,19,
  15. -98,-100,-21,-114,-101,-24,-98,95,102,102,100,130,30,10,-90,-120,87,102,103,105,109,104,-30,-102,-104,-106,110,100,
  16. 54,15,12,12,87,95,65,45,-89,-88,-54,-54,-98,95,102,102,100,130,30,10,-90,-120,87,102-114,-101,-24,-98,95,102,102,
  17. 100,130,30,10,-90,-120,87,102,102,100,130,30,10,-90,-120,87,102,103,105,54,15,12,12,87,95,65,45,-89,-88,-54,
  18. -98,-100,-21,-114,-101,-24,-98,95,102,102,100,130,30,10,-90,-120,87,102,103,105,12,87,95,65,45,-89,-88,-54,
  19. -98,-100,-21,-114,-101,-24,-98,95,102,102,100,130,30,10,-90,-120,87,102,103,105,109,104,-30,-102,-104,-106,110,
  20. 100,130,30,10,-90,-120,87,102,102,100,130,30,10,-90,-120,87,-120,87,102,103,105,109,104,-30,-102,-104,-106,110,
  21. 54,15,12,12,87,95,65,45,-89,-88,-54,-54,-98,95,102,102,100,130,30,10,-90,-120,87,102-114,-101,-24,-98,95,102,102,
  22. 54,15,12,12,87,95,65,45,-89,-88,-54,-54,-98,95,102,102,100,130,30,10,-90,-120,87,102-114,-101,-24,-98,95,102,102,
  23. 54,15,12,12,87,95,65,45,-89,-88,-54,-54,-98,95,102,102,100,130,30,10,-90,-120,87,102-114,-101,-24,-98,95,102,102,
  24. 54,15,12,12,87,95,65,45,-89,-88,-54,-54,-98,95,102,102,100,130,30,10,-90,-120,87,102-114,-101,-24,-98,95,102,102,
  25. -98,-100,-21,-114,-101,-24,-98,95,102,102,100,130,30,10,-90,-120,87,102,103,105,12,87,95,65,45,-89,-88,-54,
  26. -98,-100,-21,-114,-101,-24,-98,95,102,102,100,130,30,10,-90,-120,87,102,103,105,12,87,95,65,45,-89,-88,-54,
  27. -98,-100,-21,-114,-101,-24,-98,95,102,102,100,130,30,10,-90,-120,87,102,103,105,12,87,95,65,45,-89,-88,-54,
  28. };
  29. code char pin[8] = {1,2,4,8,16,32,64,128};
  30. char MAX_SPEED_TICKER = 120;
  31. unsigned char i; //電機(jī)序號(hào)
  32. void InitTimer(void) //初始化計(jì)數(shù)器
  33. {
  34.   TH0 = 0xFA;  //設(shè)置觸發(fā)周期:1000次
  35.   TL0 = 0x24;
  36.   TMOD = TMOD |0x01;  //select mode 1
  37.   TR0 = 1; //start timer0
  38.   ET0 = 1; //enable timer 0 interrupt
  39.   EA =1; //global interrupt enable
  40. }
  41. void SetAllSpeeds(void)  //設(shè)置各電機(jī)的速度,并讓它運(yùn)動(dòng)起來
  42. {
  43.   char delta;  //旋轉(zhuǎn)方向 1:正 -1:反  0:停
  44.   for(i=0;i<8;i++)
  45.   {
  46.     P2=pin[i]; //發(fā)送鎖存信號(hào)
  47.     speed_tickers[i] += speeds[i]; //計(jì)數(shù)值增加 speed[i]越高,增加得越多
  48.     if(speed_tickers[i] >= MAX_SPEED_TICKER) //如果計(jì)數(shù)值超過預(yù)定最大值,就發(fā)送脈沖
  49.     {
  50.       speed_tickers[i] = 0;
  51.       delta = 1;
  52.     }
  53.     else if(speed_tickers[i] <= -MAX_SPEED_TICKER) //同上,反響旋轉(zhuǎn)
  54.     {
  55.       speed_tickers[i] = 0;
  56.       delta = -1;
  57.     }
  58.     else delta = 0;
  59.     cur_step[i] += delta;
  60.     cur_step[i] &= 0x07; //計(jì)算當(dāng)前應(yīng)發(fā)脈沖
  61.     P0 = steps[cur_step[i]];
  62.     P2 = 0;
  63.   }
  64. }
  65. void OnTimer(void) interrupt 1 using 2
  66. {
  67.   unsigned char j;
  68.   SetAllSpeeds();
  69.   InitTimer();
  70.   time_t++;
  71.   if(time_t==200) //每200次觸發(fā)讀取一次新舞步數(shù)據(jù)
  72.   {
  73.     for(j=0;j<8;j++)
  74.       speeds[j] = dancedata[data_pointer+j];
  75.     data_pointer += 8;
  76.     time_t = 0;
  77.   }
  78. }
  79. void main()  //程序的入口
  80. {
  81.   InitTimer();  //初始化后等中斷
  82.   while(1);
  83. }
  84.
仿真程序: 舞蹈機(jī)器人步進(jìn)機(jī)仿真,C51程序通過.7z (69.24 KB, 下載次數(shù): 0)
主站蜘蛛池模板: 精品久久久久久一区二区里番 | 96在线视频 | 午夜看看 | 亚洲乱码在线 | 亚洲va韩国va欧美va精品 | 欧美激情一区 | 嫩草视频在线观看 | 亚洲一区国产精品 | 久久久久久久久久久久久久久久久 | 在线视频一区二区三区 | 天堂网中文 | 国产一区二区三区在线 | 欧美一区二区三区四区五区 | 欧美国产日韩视频 | 午夜av在线 | 青青操国产 | 狠狠综合网 | 亚洲成人免费av | 国产欧美精品一区二区三区 | 黄色小视频免费观看 | 日韩欧美自拍 | 日批视频网站 | 成人免费视频网站 | 日韩中文字幕一区二区三区 | 日韩欧美精品 | 三级视频在线观看 | 黄色片网站在线观看 | 中文字幕系列 | 国产嫩草视频 | 欧美狠狠干 | 手机看片国产 | 国产一级黄色大片 | 99黄色| 国产一区二区三区视频 | 激情综合五月婷婷 | www.久久久久久 | 国产一区二区影院 | 中文字幕在线日韩 | 亚洲精品视频免费 | 99久久综合 | 一级黄色在线观看 |
