查看: 494|回復: 11
請問有沒有穩壓管或LDO輸入5V-12V, 輸出5V的
ID:734017 發表于 2025-6-25 19:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
ID:332444 發表于 2025-6-25 22:31 | 只看該作者
TL431范圍很寬且有一定動態范圍
ID:824490 發表于 2025-6-25 23:13 | 只看該作者
進12V出5V太有了。。進5V出5V的貌似沒有。。。
ID:1155338 發表于 2025-6-26 04:50 | 只看該作者
有?烧{節就行
ID:1068450 發表于 2025-6-26 09:33 | 只看該作者
這個范圍了直接DCDC唄
ID:806793 發表于 2025-6-26 14:18 | 只看該作者
可以加穩壓管12V穩5V Y要看電流是多大
ID:879809 發表于 2025-6-27 16:16 | 只看該作者
只能選LDO了,但LDO也是有壓降的。
ID:1155481 發表于 2025-6-27 17:50 | 只看該作者
Yes, there are several voltage regulators and LDOs that can take an input range of 5V to 12V and output a stable 5V. The choice depends on your current requirements and how much efficiency or heat tolerance you need.
✅ Common Options:
🔹 1. Linear Regulators (e.g., 7805, AMS1117-5.0)
7805: Classic linear regulator, input up to 35V.
Easy to use, but inefficient—dissipates extra voltage as heat.
Good for low-power applications.
AMS1117-5.0: LDO with dropout ~1.1V.
Needs at least ~6.1V input to maintain stable 5V output.
Not suitable if your input drops to near 5V.
🔧 Note: Linear regulators get hot when stepping down from 12V to 5V at high current—add a heatsink if needed.
🔹 2. Switching Regulators (Buck Converters)
Much more efficient, especially if your input varies from 12V down to 5V.
Examples:
LM2596 (DC-DC buck module, very common)
MP1584, XL4015, TPS5430
Accept wide input (up to 30V depending on model), and maintain stable 5V output with high efficiency (80–90%).
✅ Great for powering microcontrollers, LED strips, sensors, etc.
🔹 3. LDO with Wide Input Support
If you need a proper LDO with better efficiency than a 7805:
LT1763, MIC29302, or LD1117 can be good choices depending on your current and dropout needs.
🔍 Recommendation:
If your input drops close to 5V, use a buck-boost converter or LDO with ultra-low dropout.
For most general use (like Arduino or Raspberry Pi), a buck converter is the most practical and efficient.
Let me know your specific current needs and whether efficiency or simplicity is more important—I’d be happy to recommend the best part number for your project!
ID:339654 發表于 2025-6-27 18:17 | 只看該作者
1117啊
ID:1034262 發表于 2025-6-28 17:57 | 只看該作者
使用BUCK-BOOST電路,輸入2~12V,可以得到5V。
ID:517951 發表于 2025-6-30 07:20 | 只看該作者
即便是LDO也是有0.幾v的壓降. 5.0V進,5.0v出, LDO是做不到的.
ID:168453 發表于 2025-6-30 11:36 | 只看該作者
LM1117-5V
主站蜘蛛池模板: 精品久久久一区二区 | av观看网站| 中文字幕亚洲欧美 | 成人h片在线观看 | 国产精品久久久久久久久久久久久久 | 国产999视频 | 久久黄色大片 | 成人av免费看 | 久久精品视频网 | 国产一区精品在线观看 | 久久午夜视频 | 国产成人精品毛片 | 一级片免费观看 | 中文字幕亚洲精品 | 在线观看欧美日韩视频 | 国产欧美日韩一区 | 国产一区在线播放 | 国产免费av在线 | 久草免费福利视频 | 欧美视频在线观看免费 | 色婷婷丁香 | 亚洲精品视频免费 | 看一级黄色片 | 午夜性视频 | 亚洲视频在线观看免费 | 国产精品羞羞答答 | 欧美性猛交xxxx黑人猛交 | 国产成人精品视频 | 好吊妞这里只有精品 | 欧美激情视频网站 | 欧美成视频 | 免费观看全黄做爰视频 | 日韩1区2区| 黄色影视 | 四虎网站在线观看 | 亚洲国产欧美在线 | 国产91精品在线观看 | 欧美精品一二区 | 亚洲看片| 久久久一区二区三区 | 黄色网页免费 |
