查看: 151|回復(fù): 1
MSPM0G3507配置pwm后下載提示無法寫入falsh
回帖獎勵 20 黑幣 回復(fù)本帖可獲得 20 黑幣獎勵! 每人限 1 次
ID:1000104 發(fā)表于 2025-7-12 16:46 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
在學(xué)習(xí)MSPM0G3507的時候突然發(fā)現(xiàn)程序無法下載了提示
  1. Error: Flash Download failed  -  "Cortex-M0+"
經(jīng)過排查發(fā)現(xiàn)只要把初始化中的pwm初始化隱去就可以正下載。
貼上這個初始化函數(shù)的代碼
  1. SYSCONFIG_WEAK void SYSCFG_DL_PWM_0_init(void) {
  2.     DL_TimerA_setClockConfig(
  3.         PWM_0_INST, (DL_TimerA_ClockConfig *) &gPWM_0ClockConfig);
  4.     DL_TimerA_initPWMMode(
  5.         PWM_0_INST, (DL_TimerA_PWMConfig *) &gPWM_0Config);
  6.     // Set Counter control to the smallest CC index being used
  7.     DL_TimerA_setCounterControl(PWM_0_INST,DL_TIMER_CZC_CCCTL0_ZCOND,DL_TIMER_CAC_CCCTL0_ACOND,DL_TIMER_CLC_CCCTL0_LCOND);
  8.     DL_TimerA_setCaptureCompareOutCtl(PWM_0_INST, DL_TIMER_CC_OCTL_INIT_VAL_LOW,
  9.                 DL_TIMER_CC_OCTL_INV_OUT_DISABLED, DL_TIMER_CC_OCTL_SRC_FUNCVAL,
  10.                 DL_TIMERA_CAPTURE_COMPARE_0_INDEX);
  11.     DL_TimerA_setCaptCompUpdateMethod(PWM_0_INST, DL_TIMER_CC_UPDATE_METHOD_IMMEDIATE, DL_TIMERA_CAPTURE_COMPARE_0_INDEX);
  12.     DL_TimerA_setCaptureCompareValue(PWM_0_INST, 5000, DL_TIMER_CC_0_INDEX);
  13.     DL_TimerA_setCaptureCompareOutCtl(PWM_0_INST, DL_TIMER_CC_OCTL_INIT_VAL_LOW,
  14.                 DL_TIMER_CC_OCTL_INV_OUT_DISABLED, DL_TIMER_CC_OCTL_SRC_FUNCVAL,
  15.                 DL_TIMERA_CAPTURE_COMPARE_1_INDEX);
  16.     DL_TimerA_setCaptCompUpdateMethod(PWM_0_INST, DL_TIMER_CC_UPDATE_METHOD_IMMEDIATE, DL_TIMERA_CAPTURE_COMPARE_1_INDEX);
  17.     DL_TimerA_setCaptureCompareValue(PWM_0_INST, 2500, DL_TIMER_CC_1_INDEX);
  18.     DL_TimerA_setCaptureCompareOutCtl(PWM_0_INST, DL_TIMER_CC_OCTL_INIT_VAL_LOW,
  19.                 DL_TIMER_CC_OCTL_INV_OUT_DISABLED, DL_TIMER_CC_OCTL_SRC_FUNCVAL,
  20.                 DL_TIMERA_CAPTURE_COMPARE_2_INDEX);
  21.     DL_TimerA_setCaptCompUpdateMethod(PWM_0_INST, DL_TIMER_CC_UPDATE_METHOD_IMMEDIATE, DL_TIMERA_CAPTURE_COMPARE_2_INDEX);
  22.     DL_TimerA_setCaptureCompareValue(PWM_0_INST, 1250, DL_TIMER_CC_2_INDEX);
  23.     DL_TimerA_setCaptureCompareOutCtl(PWM_0_INST, DL_TIMER_CC_OCTL_INIT_VAL_LOW,
  24.                 DL_TIMER_CC_OCTL_INV_OUT_DISABLED, DL_TIMER_CC_OCTL_SRC_FUNCVAL,
  25.                 DL_TIMERA_CAPTURE_COMPARE_3_INDEX);
  26.     DL_TimerA_setCaptCompUpdateMethod(PWM_0_INST, DL_TIMER_CC_UPDATE_METHOD_IMMEDIATE, DL_TIMERA_CAPTURE_COMPARE_3_INDEX);
  27.     DL_TimerA_setCaptureCompareValue(PWM_0_INST, 0, DL_TIMER_CC_3_INDEX);
  28.     DL_TimerA_enableClock(PWM_0_INST);
  29.
  30.     DL_TimerA_setCCPDirection(PWM_0_INST , DL_TIMER_CC0_OUTPUT | DL_TIMER_CC1_OUTPUT | DL_TIMER_CC2_OUTPUT | DL_TIMER_CC3_OUTPUT );
  31. }
下面貼上dap里面的設(shè)置
ID:1156447 發(fā)表于 2025-7-13 14:19 | 只看該作者
試一試調(diào)節(jié)參數(shù)
主站蜘蛛池模板: 草逼视频网站 | 可以免费看黄的网站 | 日韩av在线不卡 | 91国内在线| 综合久久99| 国产成人精品一区二区三区视频 | 九九香蕉视频 | 日韩午夜在线观看 | 天天射一射 | 精品免费| 欧美黑人一区二区三区 | 天天干天天干天天 | 国产盗摄一区二区三区 | 好色婷婷 | 波多野结衣一区二区三区 | 亚洲综合伊人 | 九九热在线视频观看 | 国产精品99久久久久久久久 | 国产精品日韩欧美 | 日韩精品国产一区 | 一区二区国产精品 | 午夜国产一区 | 成人精品一区二区三区 | 毛片资源 | 国产美女免费 | 水蜜桃一区二区 | 亚洲欧美另类在线 | 亚洲不卡在线观看 | 久久av资源 | 日韩中文字幕在线视频 | 99精品久久 | 日韩在线不卡视频 | 黄色一及片 | 久久不射网| 国产精品福利一区 | 久艹在线观看 | 国产欧美精品一区二区三区 | av大全在线观看 | 亚洲一级二级三级 | 亚洲成人精品 | 国内精品一区二区三区 |
