查看: 4166|回復: 1
1602程序修改
ID:59106 發表于 2014-2-19 10:10 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
請問1602的代碼如何寫啊,這是我寫的但是運行不了,怎么回事呢#include<reg52.h>sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
unsigned char code table[]="I LOVE MCU!";
unsigned char code table1[]="WWW.TXMCU.COM";
unsigned char num;
void delay(unsigned int t);
void write_com(unsigned char com)
   lcdrs=0;
   P0=com;
   delay(5);
   lcden=1;
   delay(5);
   lcden=0;
void write_data(unsigned char date)
   lcdrs=1;
   P0=date;
   delay(5);
   lcden=1;
   delay(5);
   lcden=0;
void init()
  dula=0;
  wela=0;
  lcden=0;
  write_com(0x38);
  write_com(0x0c);
  write_com(0x06);
  write_com(0x01);
     init();
     write_com(0x80);
     for(num=0;num<11;num++)
        write_data(table[num]);
        delay(5);
     write_com(0x80+0x40);
     for(num=0;num<13;num++)
       write_data(table1[num]);
       delay(5);
    while(1);
  while(--t);
ID:1 發表于 2014-2-24 22:40 | 只看該作者
#include "at89x52.h"
#include "51hei.h"
#define LCM_RW  P2_7 //定義引腳
#define LCM_RS  P3_5
#define LCM_E   P3_4
#define LCM_Data  P0
#define Busy    0x80 //用于檢測LCM狀態字中的Busy標識
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
unsigned char code uctech[] = {"    *51hei*    "};
unsigned char code net[] =    {" m.zg4o1577.cn "};
void main(void)
  guandz();//關閉點陣
  guanled();//關閉led數碼管
  Delay400Ms(); //啟動等待,等LCM講入工作狀態
  LCMInit(); //LCM初始化
  Delay5Ms(); //延時片刻(可不要)
  DisplayListChar(0, 5, uctech);
  DisplayListChar(0, 0, net);
  ReadDataLCM();//測試用句無意義
while(1);
//寫數據
ReadStatusLCM(); //檢測忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在這后加小的延時
LCM_E = 0; //延時
LCM_E = 1;
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
if (BuysC) ReadStatusLCM(); //根據需要檢測忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//讀數據
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//讀狀態
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //檢測忙信號
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
WriteCommandLCM(0x08,1); //關閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標移動設置
WriteCommandLCM(0x0C,1); // 顯示開及光標設置
//按指定位置顯示一個字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; // 算出指令碼
WriteCommandLCM(X, 0); //這里不檢測忙信號,發送地址碼
WriteDataLCM(DData);
//按指定位置顯示一串字符
unsigned char ListLength;
  ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到達字串尾則退出
   if (X <= 0xF) //X坐標應小于0xF
     DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
     ListLength++;
     X++;
//5ms延時
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延時
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
主站蜘蛛池模板: 九九热这里 | 天天曰天天操 | 欧美综合网 | 欧美日韩一二三区 | 视频一区在线播放 | 国产精品成人网 | 能看毛片的网站 | 操操操干干干 | 国产成人精品一区二区三区在线 | 日韩a在线| 日韩av手机在线 | 少妇性bbb搡bbb爽爽爽欧美 | 91白浆| 一区二区三区中文字幕 | 免费一区二区 | 超碰av在线播放 | 国产精品黄色 | 日韩精品一区二区三区四区 | 欧美操操操 | 欧美日韩一二三区 | 亚洲伊人影院 | av网站在线免费观看 | 色伊伊| 五月婷在线 | 亚洲一区二区中文字幕 | 久久靖品 | 久久久久久一区 | 亚洲精品日韩精品 | 五月天激情综合网 | 国产人成一区二区三区影院 | www视频在线观看 | 日本免费毛片 | 成人高清视频在线观看 | 96在线视频 | 免费a网站 | 国产在线视频一区 | 操少妇视频 | 天天操夜夜干 | 九九视频在线观看 | 日韩欧美一级 | 看黄网站在线观看 |
