查看: 6226|回復: 0
[求助]關于數字鐘的程序問題
ID:6799 發表于 2009-9-17 22:01 | 顯示全部樓層 |閱讀模式
//*************************C語言寫的可調數字時鐘顯示 *************************
//*******************************2009-09-13***********************************
//***************************可調數字鐘的功能介紹*******************************
//K1:adjtime  K2:hour  K3:min  K4:OK
//K2:lookalarm  K4:OK
//K3:adjalarm  K2:hh  K3:mm  K4:OK
//K4:SET alarm OFF/ON
#include"reg51.h"
unsigned char ss=0,hour=12,min=0,hh=7,mm=30; //初始化  顯示12:00鬧鈴:7:30
unsigned char code leds_a[]={0xC0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};  //0-9
unsigned char code leds_b[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};   //帶點的0-9
sbit P37=P3^7; //蜂鳴器開關
sbit P20=P2^0;
sbit P21=P2^1;
sbit P22=P2^2;
sbit P23=P2^3;  //數碼管選位
#define K1 0xde
#define K2 0xee
#define K3 0xf6
#define K4 0xdd //按鍵的分別代碼
unsigned char key;
TIMER_INTO();
unsigned char kbscan();  //鍵盤掃描
void lookalarm();  //查看鬧鈴
void disp_off(); //鬧鈴關的顯示
void process();    //有按鍵按下的處理
void disp_on();   //鬧鈴開的顯示
void alarm();   //鬧鈴
unsigned char flag_alarm=1;  //鬧鐘標志位,默認鬧鈴關
static unsigned int count=0;  //計數器初始
unsigned char dema=0;    //數碼管顯示的延時標中斷志
unsigned char atemp=0;
unsigned char demb=0;   //按鍵的延時中斷標志
unsigned char btemp=0;
main()      //主程序
 TIMER_INTO();   //定時 中斷 初始化
  key=kbscan();//掃描鍵盤
   process();
  if(flag_alarm==1)
   disp_off();//關閉鬧鐘的顯示
   disp_on(); //鬧鐘開啟 的顯示
  alarm();    //鬧鈴
void process() //按鍵的處理
 if(key!=0)
  if(key==K1)
   TR0=0;
    while((key=kbscan())!=K4)
    disp_off();
    if((key=kbscan())==K2)
     hour++;
     disp_off();
     if(hour>=24)
      hour=0;
    if((key=kbscan())==K3)
     min++;
     if(min>=60)
      min=0;
   TR0=1;
  else if(key==K2)
   while(((key=kbscan())!=K4))
    lookalarm();
  else if(key==K3)
    lookalarm();
     hh++;
     lookalarm();
     if(hh>=24)
      hh=0;
     mm++;
     if(mm>=60)
      mm=0;
  else if(key==K4)
   flag_alarm=~flag_alarm;
TIMER_INTO()   //中斷初始化
 TMOD=0X01;
 TH0=0Xf8;
 TL0=0X30;  //2mS初值
 TR0=1;
 ET0=1;
 EA=1;
timer0() interrupt 1  //中斷進程
 TR0=0;
 TH0=0Xf8;
 TL0=0X30;  //重裝初值
 TR0=1;
 count++;
 dema++;
 demb++;
 if(dema>1)
  dema=0;    //2mS延時
  atemp=1;
 if(demb>=15)
  demb=0;   //30mS延時
  btemp=1;
 if(count>=500) //1S延時
  count=0;
  ss++;
  if(ss>=60)
   ss=0;
   min++;
   if(min>=60)
    min=0;
    hour++;
    if(hour>=24)
     hour=0;
void disp_off() //鬧鈴關的走時
 P23=0;
 P0=leds_a[min%10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P23=1;
 P22=0;
 P0=leds_a[min/10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P22=1;
 P21=0;
 P0=leds_b[hour%10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P21=1;
 P20=0;
 P0=leds_a[hour/10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P20=1;
void disp_on()   //鬧鈴開的走時
 P23=0;
 P0=leds_b[min%10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P23=1;
 P22=0;
 P0=leds_a[min/10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P22=1;
 P21=0;
 P0=leds_b[hour%10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P21=1;
 P20=0;
 P0=leds_a[hour/10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P20=1;
void lookalarm() //查看鬧鐘
 P23=0;
 P0=leds_a[mm%10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P23=1;
 P22=0;
 P0=leds_a[mm/10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P22=1;
 P21=0;
 P0=leds_b[hh%10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P21=1;
 P20=0;
 P0=leds_a[hh/10];
 dema = 0;
 atemp=0;
 while(atemp!=1);
 P20=1;
unsigned char kbscan()   //掃描鍵盤
 unsigned char sccode,recode,temp;
 P1=0XF8;
 temp=P1;
 if(temp!=0xf8)
  while(btemp!=1);
  btemp=0;
  if(temp==P1)
   sccode=0xfe;
   while((sccode&0xf7)!=0)
    P1=sccode;
    if((P1&0xf8)!=0xf8)
     recode=P1&0Xf8;
     sccode=sccode&0xc7;
     return(recode|sccode);
     sccode=sccode<<1|0x01;
 return(0);
void alarm()//鬧鈴
 if((min==mm)&&(hour==hh)&&(flag_alarm==1))
  P37=0;
 問題是這樣的:1、下載到實驗板上時間都正常走時但現象是只有當K1按下后數碼管就黑屏,只有復位后正常,其他按鍵都正常工作;
                     2、當時間走到河設置的鬧鈴時間一樣后,鬧鈴不響,沒任何反映,鬧鈴的標志位都正常;
想了很久都沒找到問題的原因,懇請高人指點,謝謝了~~~~
[此貼子已經被作者于2009-9-18 13:12:37編輯過]
主站蜘蛛池模板: 日本在线视频观看 | 欧美午夜视频 | 国产成人精品自拍 | 在线一区二区三区 | 国产成人小视频 | www.亚洲精品 | 美女张开腿 | 黄色一级影片 | 欧美一区二区免费 | 成人免费毛片aaaaaa片 | 国产黄色在线观看 | 欲望岛av| 国产三级在线观看 | 成人一区二区三区 | 国产黄色免费网站 | 亚洲欧美精品 | 中文字幕三级 | 国产一级二级三级 | 亚洲永久免费 | 日韩欧美国产高清91 | www.av在线视频| 91亚洲国产 | 91av免费观看| 国产成人精品一区二区三区福利 | www.日本高清 | 日韩欧美在线观看 | 精品欧美一区二区三区久久久 | 亚洲黄色成人 | 色在线播放 | 久草手机在线视频 | 日韩欧美激情 | 中文字幕在线观看日本 | 青青草一区二区 | 亚洲激情片 | 国产精品羞羞答答 | 乳色吐息在线观看 | 亚洲二区视频 | 亚洲欧美一区二区三区四区 | 中文字幕有码在线 | 国产传媒在线 | 欧美日韩在线精品 |
