查看: 21187|回復: 71
本人做的單片機鬧鐘,還不錯啊,
希望大家多提寶貴意見。
經過測試,是一個不錯的程序.rar (51.29 KB, 下載次數: 504)
admin + 50 共享資料的積分獎勵!
收藏收藏8 分享淘帖 頂2 踩
ID:36525 發表于 2014-3-9 16:26 | 只看該作者
先下來看看,怎么沒人下,順便把樓主的源碼貼出來 給大家省51黑電子論壇的黑幣啊
  1. //提示:k1k2k3k4分別是:小時。分鐘。秒鐘的調節功能。定時時間的顯示功能。k5k6分別是設定第二時間定為0:01:00,啟用或者關閉鬧鐘,
  2. #include"AT89X52.H"
  4. uchar code seg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf};   //斷碼
  5. uchar code pos[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};                                                //微碼
  6. sbit k1=P1^0;
  7. sbit k2=P1^1;
  8. sbit k3=P1^2;
  9. sbit k4=P1^3;
  10. sbit k5=P1^4;
  11. sbit jidianqi1=P1^5;
  12. sbit k6=P1^6;
  13. sbit led=P1^7;
  14. uchar k[8]={0,0,16,0,0,16,0,0};      //01234567
  15. uchar code seg00[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf};   //斷碼
  16. uchar code pos00[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};                                                //微碼
  17. uchar k00[8]={0,0,16,0,0,16,0,0};        //01234567
  18. uchar second;
  19. uchar minite;
  20. uchar hour;
  21. uchar num;
  22. uchar naozhongqiyongFlag;
  23. uchar second00;
  24. uchar minite00;
  25. uchar hour00;
  26. uchar num00;
  27. ////////////////////////////////////////////////////////////////////////////////////
  28. void TimeCompate(void)
  29.   {
  30. if(naozhongqiyongFlag)
  31.   {
  32.     if((second00==0)&&(minite00==1)&&(hour00==0))               ///&&(minite00<=2),,,(naozhongqiyongFlag==1)&&,,  led=1
  33.         {
  34.               jidianqi1=0;
  35.              }
  36.          else if((second00==5)&&(minite00==42)&&(hour00==0))
  37.         {
  38.               jidianqi1=1;   naozhongqiyongFlag=~naozhongqiyongFlag;    led=~led;
  39.              }
  40.   }
  41. /*        if(hour00!=0)
  42.        { jidianqi1=1;   naozhongqiyongFlag=0;
  43.            }
  44.          if(hour00==0)
  45.        {
  46.              if(minite00<1)
  47.              { jidianqi1=1;   naozhongqiyongFlag=0;
  48.              }
  49.             else if(minite00>2)
  50.               { jidianqi1=1;   naozhongqiyongFlag=0;
  51.               }
  52.                     else
  53.            {
  54.                   jidianqi1=0;
  55.                }
  56.                 }
  57.
  58. /*/
  59. //////////////////////////////////////////
  60.
  61. }
  62. //////////////// //延時程序///////////////////////////////
  63. void delay_5ms(void)
  64. {
  65.   uchar i,j;
  66.   for(i=10;i>0;i--)
  67.   for(j=248;j>0;j--)
  68.   ;
  69. }
  70. ////////////顯示程序,這個寫法不錯啊。//////////////////////////
  71. void disp(uchar m,uchar n)
  72. {
  73. P2=pos[n];                          //查表法 把對應的段碼送P2?
  74. P0=seg[m];                           //查表法 把對應的未碼送P0口
  75. delay_5ms();
  76. P2=0x00;
  77. }
  78. ////////////顯示程序,這個寫法不錯啊。//////222222222222222/////
  79. void disp00(uchar x,uchar y)
  80. {
  81. P2=pos00[y];                          //查表法 把對應的段碼送P2?
  82. P0=seg00[x];                           //查表法 把對應的未碼送P0口
  83. delay_5ms();
  84. P2=0x00;
  85. }
  86. ////////////////////主程序//////////////////////////////
  87. void main(void)
  88. {
  89.   uchar j;
  90.   uchar p;
  91.   TMOD=0x01;
  92.   // TH0=-50000/256;
  93.   // TL0=-50000%256;
  94.   TR0=1;
  95.   ET0=1;
  96.   EA=1;
  97.   second=0;
  98.   minite=0;
  99.   hour=0;
  100.   second00=7;
  101.   minite00=8;
  102.   hour00=9;
  103.   jidianqi1=1;
  104.   naozhongqiyongFlag=0;
  105.   led=1;
  106.   while(1)
  107.    {
  108.           TimeCompate();
  109.      if(k1==0)
  110.        {
  111.          delay_5ms();
  112.           if(k1==0)        //判斷按鍵是否按下
  113.             {
  114.              second=0;
  115.                        while(k1==0);
  116.             }
  117.         }
  118.      if(k2==0)                //判斷按鍵是否按下
  119.         {
  120.           delay_5ms();
  121.           if(k2==0)
  122.             {
  123.               minite++;
  124.               if(minite==60)  minite=0;
  125.                           while(k2==0);
  126.             }
  127.         }
  128.      if(k3==0)                    //判斷按鍵是否按下
  129.         {
  130.           delay_5ms();
  131.           if(k3==0)
  132.             {
  133.               hour++;
  134.               if(hour==24)  hour=0;
  135.               while(k3==0)
  136.                    {for(j=0;j<8;j++)              //掃描顯示程序,循環有8次,01234567.
  137.                    disp(k[j],j);               //掃描顯示程序
  138.                                             }
  139.             }
  140.         }
  141.         //////////////////////////////////////////////////////////////////////
  142.
  143.                  if(k4==0)                    //判斷按鍵是否按下
  144.         {
  145.           delay_5ms();
  146.           if(k4==0)
  147.             {
  148.               while(k4==0)
  149.                                    {
  150.                     for(p=0;p<8;p++)
  151.                      disp00(k00[p],p);
  152.                                                         TimeCompate();
  153.                                      ;
  154.                  }
  155.             }
  156.         }
  157.     ///////////////////////////////////////////////////////////////////////////////
  158.          if(k5==0)                    //判斷按鍵是否按下
  159.         {
  160.           delay_5ms();
  161.           if(k5==0)
  162.             {
  163.                           second00=57;
  164.               minite00=0;
  165.               hour00=0;
  166.               while(k5==0)
  167.                                    {
  168.                     for(p=0;p<8;p++)
  169.                      disp00(k00[p],p);
  170.                                      ;
  171.                  }
  172.             }
  173.         }
  174. //////////////////////////////////////////////////////////////////////////////////////
  175. if(k6==0)                    //判斷按鍵是否按下
  176.         {
  177.           delay_5ms();
  178.           if(k6==0)
  179.             {
  180.              naozhongqiyongFlag=~naozhongqiyongFlag;
  181.                                  led=~led;
  182.
  183.               while(k6==0)
  184.                                    {
  185.                   ;
  186.                  }
  187.             }
  188.         }
  189.    ////////////////////////////////////////////////////////////////////////////////////
  190.       for(j=0;j<8;j++)              //掃描顯示程序,循環有8次,01234567.
  191.       disp(k[j],j);               //掃描顯示程序
  192.   ////////////////////////////////////////////////////////////////////////////////////
  193.       TimeCompate();
  194.   ////////////////////////////////////////////////////////////////////////////////////
  195.
  196.    }
  197. }
  198. ////////////////*定時器工作方式*/ /////////////////////////////////
  199. void t0(void) interrupt 1  /*定時器工作方式*/  using 0   //工作寄存器
  200. {
  201.   num++;
  202.
  203.   if(num==20)
  204.     {
  205.       num=0;
  206.       second++;
  207.       if(second==60)
  208.         {
  209.           second=0;
  210.           minite++;
  211.           if(minite==60)
  212.             {
  213.               minite=0;
  214.               hour++;
  215.               if(hour==24)
  216.                 {
  217.                   hour=0;
  218.                 }
  219.              }
  220.          }
  221.      k[0]=second%10;     //各位
  222.      k[1]=second/10;         //各十位
  223.      k[3]=minite%10;        //各位
  224.      k[4]=minite/10;      //各十位
  225.      k[6]=hour%10;        //各位
  226.      k[7]=hour/10;        //各十位
  227.     }
  228.   num00++;
  229.   if(num00==20)
  230.     {
  231.       num00=0;
  232.       second00++;
  233.       if(second00==60)
  234.         {
  235.           second00=0;
  236.           minite00++;
  237.           if(minite00==60)
  238.             {
  239.               minite00=0;
  240.               hour00++;
  241.               if(hour00==99)
  242.                 {
  243.                   hour00=0;
  244.                 }
  245.              }
  246.          }
  247.                              k00[0]=second00%10;         //各位
  248.               k00[1]=second00/10;         //各十位
  249.               k00[3]=minite00%10;         //各位
  250.               k00[4]=minite00/10;         //各十位
  251.               k00[6]=hour00%10;           //各位
  252.               k00[7]=hour00/10;           //各十位
  253.      }
  254.
  255.
  256.    TH0=-50000/256;
  257.    TL0=-50000%256;
  258.
  259. }
ID:58972 發表于 2014-3-15 21:43 | 只看該作者
謝謝分享。!51黑有你更精彩!!
ID:59247 發表于 2014-3-17 10:31 | 只看該作者
下下來看看吧
ID:59655 發表于 2014-3-18 07:57 | 只看該作者
下來學習,先謝了
參與人數 1威望 +2 收起 理由
小飛胖胖 + 2
ID:59676 發表于 2014-3-18 08:19 | 只看該作者
學習學習
ID:59700 發表于 2014-3-21 22:28 | 只看該作者
下下來看看吧
ID:59072 發表于 2014-3-25 14:14 來自觸屏版 | 只看該作者
不錯,值的收藏
ID:59983 發表于 2014-3-25 15:08 | 只看該作者
謝謝分享
ID:60246 發表于 2014-4-2 09:42 | 只看該作者
謝謝分享
ID:63244 發表于 2014-7-4 16:18 | 只看該作者
謝謝分享!!!
ID:63588 發表于 2014-12-16 19:58 | 只看該作者
來學習的。。。。。。。。。。。。。。。。。
ID:68076 發表于 2014-12-16 22:13 | 只看該作者
下來學習
ID:70614 發表于 2014-12-17 13:27 | 只看該作者
學習學習也想作一個
ID:69803 發表于 2014-12-17 15:07 | 只看該作者
下載試試看
ID:69803 發表于 2014-12-17 15:08 | 只看該作者
我先下載試試看
我先下載試試看
我先下載試試看
ID:69833 發表于 2014-12-17 15:14 | 只看該作者
先看看
ID:70267 發表于 2014-12-18 18:26 | 只看該作者
看一下
ID:71279 發表于 2014-12-28 23:44 | 只看該作者
真的假的呀
ID:11942 發表于 2015-1-7 11:06 | 只看該作者
good  想看看
ID:64913 發表于 2015-2-8 17:40 | 只看該作者
看看再說..................
ID:46999 發表于 2015-2-8 21:12 | 只看該作者
先下來看看。感謝!
ID:46999 發表于 2015-2-8 21:15 | 只看該作者
M幣扣了下載沒到
ID:46999 發表于 2015-2-8 21:16 | 只看該作者
M幣扣了下載沒到
ID:70330 發表于 2015-2-10 10:43 | 只看該作者
太好了,謝謝
樓主很強大,學習了
ID:70614 發表于 2015-2-15 19:51 | 只看該作者
看看學習學習
ID:72872 發表于 2015-3-5 18:23 | 只看該作者
先看看什么鬧鐘
ID:71233 發表于 2015-3-5 19:38 | 只看該作者
是用1302還是單片機定時器?
ID:84753 發表于 2015-7-4 15:18 來自觸屏版 | 只看該作者
可以嗎?
ID:93890 發表于 2015-10-28 17:21 | 只看該作者
很想做一個
ID:94340 發表于 2015-11-1 19:31 | 只看該作者
挺好的
ID:94980 發表于 2015-11-14 11:22 | 只看該作者
下載試試看
ID:67336 發表于 2015-11-14 11:48 | 只看該作者
如果用DS1302就好了
ID:19947 發表于 2015-11-20 14:25 | 只看該作者
要是增加1302時鐘芯片就更好了。
ID:96393 發表于 2015-12-7 16:39 來自觸屏版 | 只看該作者
學習學習
ID:96702 發表于 2015-12-7 19:56 | 只看該作者
要是增加1302時鐘芯片就更好了。
ID:95809 發表于 2015-12-24 13:57 | 只看該作者
挺好的,已經下載了·1,
主站蜘蛛池模板: 久国产| 性欧美精品 | av片在线观看 | 久久精品一区二区三区不卡牛牛 | 亚洲精品一二区 | 性生活网址 | 欧美视频在线一区 | 夜夜贪欢〈高h〉 | 国产日韩欧美亚洲 | 久久精品亚洲 | 国产不卡在线观看 | 男男巨肉啪啪动漫3d | 国产成人免费观看 | 日本在线观看一区 | 精品国产乱码久久久久久蜜柚 | 蜜桃精品一区二区 | 亚洲第一av | 国产超碰人人模人人爽人人添 | 午夜精品视频在线 | 欧美精品一区二区三区四区 | 久久精品三级 | 久久久久成人网 | 国产成人区 | 国产福利av | 亚洲欧美日韩一区二区三区四区 | 欧美日韩在线观看一区二区 | 黄色录像免费看 | 国产第二页| 91亚洲国产成人久久精品网站 | 亚洲一级特黄 | 亚洲精品1区2区 | 黄色一级大片 | 黄色片视频免费 | 日韩视频一区 | 国产精品一区视频 | 国产视频一区在线观看 | 欧美精品一二三区 | 国产精品二区一区二区aⅴ污介绍 | 欧美一级在线播放 | 在线播放毛片 | 欧美黄色精品 |
