查看: 14157|回復: 4
51單片機紅外接收代碼加解碼
ID:59583 發表于 2014-3-13 22:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
頭文件 stc12c5a.h下載: http://m.zg4o1577.cn/mcu/2564.html
頭文件 1602.h 下載: http://m.zg4o1577.cn/bbs/dpj-24671-1.html
  ///*redPC838.c文件
* 紅外接收數據,中斷方式,并通過串口發送
* 晶振:11.0592M*/
#include<STC12c5a.h>
#include<1602.h>
typedef unsigned char uint8;
sbit Ir_Pin = P3^3;
uint8 Ir_Buf[4]; //用于保存解碼結果
extern int keynum=1;
void int1_init(void)
IT1 = 1; //下降沿有效
EX1 = 1;
EA = 1;
TMOD = 0x01;
/*獲取低電平時間*/
unsigned int Ir_Get_Low()
TL0 = 0;
TH0 = 0;
TR0 = 1;
while (!Ir_Pin && (TH0&0x80)==0);
TR0 = 0;
return (TH0 * 256 + TL0);
/* 獲取高電平時間*/
unsigned int Ir_Get_High()
TL0 = 0;
TH0 = 0;
TR0 = 1;
while (Ir_Pin && (TH0&0x80)==0);
TR0 = 0;
void PC838()
{ int1_init();
void int1_isr() interrupt 2
unsigned int temp;
char i,j;
temp = Ir_Get_Low();
if ((temp < 7833) || (temp > 8755))  //引導脈沖低電平8500~9500us
return;
temp = Ir_Get_High();
if ((temp < 3686) || (temp > 4608))  //引導脈沖高電平4000~5000us
return;
for (i=0; i<4; i++) //4個字節
for (j=0; j<8; j++) //每個字節8位
if ((temp < 184) || (temp > 737)) //200~800us
return;
if ((temp < 184) || (temp > 1843)) //200~2000us
return;
Ir_Buf[ i] >>= 1;
if (temp > 1032) //1120us
Ir_Buf[ i] |= 0x80;
if( Ir_Buf[2]=~ Ir_Buf[3])  //驗證鍵數據碼和其反碼是否相等,一般情況下不必驗證用戶碼
if(Ir_Buf[2]==0x16)  keynum=0; //a[0]=00h;a[1]=ffh
if(Ir_Buf[2]==0x0c)  keynum=1; //a[0]=00h;a[1]=ffh
if(Ir_Buf[2]==0x18)  keynum=2; //a[0]=00h;a[1]=ffh
if(Ir_Buf[2]==0x5E)  keynum=3;
if(Ir_Buf[2]==0x08)  keynum=4;
if(Ir_Buf[2]==0x1C)  keynum=5;
if(Ir_Buf[2]==0x5A)  keynum=6;
if(Ir_Buf[2]==0x42)  keynum=7;
if(Ir_Buf[2]==0x52)  keynum=8;
if(Ir_Buf[2]==0x4A)  keynum=9;
if(Ir_Buf[2]==0x45)  keynum=10; //ON/OFF
if(Ir_Buf[2]==0x46)  keynum=11; //MODE
if(Ir_Buf[2]==0x47)  keynum=12; //靜音
if(Ir_Buf[2]==0x44)  keynum=13; //暫停
if(Ir_Buf[2]==0x40)  keynum=14; //下一曲
if(Ir_Buf[2]==0x43)  keynum=15; //上一曲
if(Ir_Buf[2]==0x07)  keynum=16; //EQ
if(Ir_Buf[2]==0x15)  keynum=17; //VOL-
if(Ir_Buf[2]==0x09)  keynum=18; //VOL+
if(Ir_Buf[2]==0x19)  keynum=19; //RPT
if(Ir_Buf[2]==0x0D)  keynum=20; //U/SD
  //  beep();        //蜂鳴器響一聲 提示解碼成功
//******************8redPC838.h文件
#ifndef _redPC838_
#define _redPC838_
#define uchar unsigned char
#define uint  unsigned int
void PC838();
extern int keynum;
#endif
收藏收藏3 分享淘帖 頂 踩
ID:45963 發表于 2015-6-19 17:49 | 只看該作者
牛牛牛
ID:201936 發表于 2017-7-9 14:10 | 只看該作者
謝謝了,保存下來
ID:558624 發表于 2019-7-28 15:19 | 只看該作者
謝謝分享,下載了
ID:33548 發表于 2019-10-22 20:37 | 只看該作者
謝謝分享,下載了
主站蜘蛛池模板: 欧美色图一区 | 91久久精品日日躁夜夜躁欧美 | 在线播放亚洲 | 精品一区二区三区免费看 | 日韩一级黄色片 | 97国产精品人人爽人人做 | 日韩亚洲一区二区 | 秋霞午夜鲁丝一区二区老狼 | 国产精品久久一区二区三区 | 精品久久国产 | 欧美久久久 | 国产91清纯白嫩初高中在线观看 | 欧美日韩国产三级 | 免费国产精品视频 | 999在线视频| 国产欧美精品 | 黄色三级视频网站 | 成人免费看片在线观看 | 免费在线观看黄色片 | 欧美色图在线视频 | 久久久久97 | 亚洲欧美日本在线 | 天天爽天天 | 欧美日本在线观看 | 黄a视频 | cao在线 | 国产亚洲一区二区三区 | 日韩不卡av | 免费亚洲视频 | 中文字幕在线观看网址 | 亚洲影院一区 | 日韩在线不卡视频 | 日本加勒比在线 | 欧美视频精品 | 亚洲国产中文字幕 | 久久伊人热 | 中文字幕在线免费观看 | 在线免费毛片 | 亚洲第一网站 | a在线免费观看 | 欧美一二区 |
