查看: 19480|回復: 7
stm32模擬IIC驅動RX8025時鐘芯片C語言參考程序
ID:59583 發(fā)表于 2014-3-21 13:57 | 顯示全部樓層 |閱讀模式
/* Includes--------------------------------------------------------------*/
//#include        "sysconfig.h"
#include "stm32f10x.h"
//#include        "bsp_SIIC.h"
#include "bsp_RX8025.h"
Private define-----------------------------------------------------------------------------*/
// 設備讀寫地址
#define        RX8025_ADDR_READ                0x65
#define        RX8025_ADDR_WRITE                0x64
// 設備寄存器地址
#define        RX8025_ADDR_SECONDS                0x00
#define        RX8025_ADDR_WEEK                0x30
#define        RX8025_ADDR_DATES                0x40
#define        RX8025_ADDR_MONTH                0x50
#define        RX8025_ADDR_MINUTES                0x80
#define        RX8025_ADDR_CONTROL1        0xE0
#define        RX8025_ADDR_CONTROL2        0xF0
// 設備操作模式
#define        RX8025_WRITE_MODE                0xF0
#define        RX8025_READ_MODE                0xF0
#define        RX8025_SIMP_READ_MODE        0x04
#define u8BAND(addr, u8num) ((addr & 0xF0000000)+0x2000000+((addr &0xFFFFF)<<5)+(u8num<<2))
#define MEM_ADDR(addr)  *((volatile unsigned long  *)(addr))
#define u8_ADDR(addr, u8num)   MEM_ADDR(u8BAND(addr, u8num))
//IO口地址映射
#define GPIOA_ODR_Addr    (GPIOA_BASE+12) //0x4001080C
#define GPIOB_ODR_Addr    (GPIOB_BASE+12) //0x40010C0C
#define GPIOC_ODR_Addr    (GPIOC_BASE+12) //0x4001100C
#define GPIOD_ODR_Addr    (GPIOD_BASE+12) //0x4001140C
#define GPIOE_ODR_Addr    (GPIOE_BASE+12) //0x4001180C
#define GPIOF_ODR_Addr    (GPIOF_BASE+12) //0x40011A0C
#define GPIOG_ODR_Addr    (GPIOG_BASE+12) //0x40011E0C
#define GPIOA_IDR_Addr    (GPIOA_BASE+8) //0x40010808
#define GPIOB_IDR_Addr    (GPIOB_BASE+8) //0x40010C08
#define GPIOC_IDR_Addr    (GPIOC_BASE+8) //0x40011008
#define GPIOD_IDR_Addr    (GPIOD_BASE+8) //0x40011408
#define GPIOE_IDR_Addr    (GPIOE_BASE+8) //0x40011808
#define GPIOF_IDR_Addr    (GPIOF_BASE+8) //0x40011A08
#define GPIOG_IDR_Addr    (GPIOG_BASE+8) //0x40011E08
//IO口操作,只對單一的IO口!
//確保n的值小于16!
#define PAout(n)   u8_ADDR(GPIOA_ODR_Addr,n)  //輸出
#define PAin(n)    u8_ADDR(GPIOA_IDR_Addr,n)  //輸入
#define PBout(n)   u8_ADDR(GPIOB_ODR_Addr,n)  //輸出
#define PBin(n)    u8_ADDR(GPIOB_IDR_Addr,n)  //輸入
#define PCout(n)   u8_ADDR(GPIOC_ODR_Addr,n)  //輸出
#define PCin(n)    u8_ADDR(GPIOC_IDR_Addr,n)  //輸入
#define PDout(n)   u8_ADDR(GPIOD_ODR_Addr,n)  //輸出
#define PDin(n)    u8_ADDR(GPIOD_IDR_Addr,n)  //輸入
#define PEout(n)   u8_ADDR(GPIOE_ODR_Addr,n)  //輸出
#define PEin(n)    u8_ADDR(GPIOE_IDR_Addr,n)  //輸入
#define PFout(n)   u8_ADDR(GPIOF_ODR_Addr,n)  //輸出
#define PFin(n)    u8_ADDR(GPIOF_IDR_Addr,n)  //輸入
#define PGout(n)   u8_ADDR(GPIOG_ODR_Addr,n)  //輸出
#define PGin(n)    u8_ADDR(GPIOG_IDR_Addr,n)  //輸入
//Ex_NVIC_Config專用定義
#define GPIO_A 0
#define GPIO_B 1
#define GPIO_C 2
#define GPIO_D 3
#define GPIO_E 4
#define GPIO_F 5
#define GPIO_G 6
//IO操作函數(shù)
#define IIC_SCL PBout(15) //SCL
#define IIC_SDA PBout(14) //SDA
#define READ_SDA PBin(14) //輸入SDA
void I2C_Configuration(void);
/* Private typedef----------------------------------------------------------------------------*/
// 寄存器結構
// CONTROL1,結構定義
typedef struct
        u8 CT:3;
        u8 TEST:1;
        u8 nCLEN2:1;
        u8 HOUR24:1;
        u8 DALE:1;
        u8 WALE:1;
}_RX8025_REG_CONTROL1_BITS;
typedef union
        u8 byte;
        _RX8025_REG_CONTROL1_BITS bits;
}_RX8025_REG_CONTROL1;
/* Private macro------------------------------------------------------------------------------*/
/* Private variables--------------------------------------------------------------------------*/
/* Private function prototypes----------------------------------------------------------------*/
/* Private functions--------------------------------------------------------------------------*/
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO ,ENABLE);
        /* Configure I2C2 pins: PB15 -> SCL and PB14 -> SDA */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_14 | GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
void SDA_IN(void) //sda線輸入 ,PA11
        GPIO_InitTypeDef GPIO_InitStructure;//聲明GPIO初始化結構體
        // Configure I2C1 pins:SDA
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_14;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
void SDA_OUT(void) //sda線輸出
//   延時總時間=cnt*16+24us
void delay(u16 cnt)
        u8 i;
for(;cnt>0;cnt--)
        for(i=0;i<100;i++);
//產(chǎn)生IIC起始信號
void IIC_Start(void)
        SDA_OUT(); //sda線輸出
        IIC_SDA=1;
        IIC_SCL=1;
        delay(4);
        IIC_SDA=0;//START:when CLK is high,DATA change form high to low
        delay(4);
        IIC_SCL=0;//鉗住I2C總線,準備發(fā)送或接收數(shù)據(jù)
//產(chǎn)生IIC停止信號
void IIC_Stop(void)
        SDA_OUT();//sda線輸出
        IIC_SCL=0;
        IIC_SDA=0;//STOP:when CLK is high DATA change form low to high
        delay(4);
        IIC_SCL=1;
        IIC_SDA=1;//發(fā)送I2C總線結束信號
        delay(4);
//等待應答信號到來
//返回值:1,接收應答失敗
// 0,接收應答成功
u8 IIC_Wait_Ack(void)
        u8 ucErrTime=0;
        SDA_IN(); //SDA設置為輸入
        IIC_SDA=1;delay(1);
        IIC_SCL=1;delay(1);
        while(READ_SDA)
                ucErrTime++;
                if(ucErrTime>250)
                        IIC_Stop();
                        return 1;
        IIC_SCL=0;//時鐘輸出0
        return 0;
//產(chǎn)生ACK應答
void IIC_ACK(void)
        IIC_SCL=0;
        SDA_OUT();
        IIC_SDA=0;
        delay(2);
        IIC_SCL=1;
        delay(2);
        IIC_SCL=0;
//不產(chǎn)生ACK應答
void IIC_NAck(void)
        IIC_SCL=0;
        SDA_OUT();
        IIC_SDA=1;
        delay(2);
        IIC_SCL=1;
        delay(2);
        IIC_SCL=0;
//IIC發(fā)送一個字節(jié)
//返回從機有無應答
//1,有應答
//0,無應答
u8 IIC_Send_Byte(u8 txd)
        u8 t;
        SDA_OUT();
        IIC_SCL=0;//拉低時鐘開始數(shù)據(jù)傳輸
        for(t=0;t<8;t++)
                IIC_SDA=(txd&0x80)>>7;
                txd<<=1;
                delay(2); //對TEA5767這三個延時都是必須的
                IIC_SCL=1;
                delay(2);
                IIC_SCL=0;
                delay(2);
        t=IIC_Wait_Ack();
        return (t);
//讀1個字節(jié),ack=1時,發(fā)送ACK,ack=0,發(fā)送nACK
u8 IIC_Read_Byte(u8 ack)
        u8 i,receive=0;
        SDA_IN();//SDA設置為輸入
        for(i=0;i<8;i++ )
                IIC_SCL=0;
                delay(2);
                IIC_SCL=1;
                receive<<=1;
                if(READ_SDA)receive++;
                delay(1);
        if (!ack)
        IIC_NAck();//發(fā)送nACK
        IIC_ACK(); //發(fā)送ACK
        return receive;
void RX8025Write(u8 addr,u8 *pData,u8 len)
        u8 i;
        IIC_Start();
        if(IIC_Send_Byte(RX8025_ADDR_WRITE)==1)
                IIC_Stop();
                return;
        if(IIC_Send_Byte(addr)==1)
                IIC_Stop();
                return;
        for(i=0;i<len;i++)
                if(IIC_Send_Byte(pData)==1)
                        IIC_Stop();
                        return;
        IIC_Stop();
void RX8025Read(u8 addr,u8 *pData,u8 len)
        u8 i;
        IIC_Start();
                IIC_Stop();
                return;
                IIC_Stop();
                return;
        IIC_Start();
        if(IIC_Send_Byte(RX8025_ADDR_READ)==1)
                IIC_Stop();
                return;
        for(i=0;i<len-1;i++)
                pData = IIC_Read_Byte(1);
//                IIC_ACK();
        pData = IIC_Read_Byte(0);
//        IIC_NAck();
        IIC_Stop();
* Function                : BSP_RX8025Write
* Description        : 向時鐘芯片寫數(shù)據(jù)
* Input                        :
* Output                :
* Note(s)                :
* Contributor        : 081218        andydriver
void BSP_RX8025Write(u8 *pData,u8 len)
        RX8025Write((RX8025_ADDR_SECONDS&RX8025_WRITE_MODE),pData,len);
* Function                : BSP_RX8025Read
* Description        : 從時鐘芯片讀取數(shù)據(jù)
* Input                        :
* Output                :
* Note(s)                :
void BSP_RX8025Read(u8 *pData,u8 len)
        RX8025Read((RX8025_ADDR_SECONDS&RX8025_READ_MODE),pData,len);
* Function                : BSP_RX8025ControlINTA
* Description        : 控制芯片的INTA腳狀態(tài)
* Input                        : state:狀態(tài)(_BSPRX8025_INTAOUT)
                                        BSPRX8025_INTAOUT_HIZ:高阻
                                        BSPRX8025_INTAOUT_LOW:輸出低
                                        BSPRX8025_INTAOUT_2HZ:輸出2Hz(50%)的脈沖
                                        BSPRX8025_INTAOUT_1HZ:輸出1Hz(50%)的脈沖
                                        BSPRX8025_INTAOUT_SEC:每秒的第0秒翻轉?還是脈沖?
                                        BSPRX8025_INTAOUT_MIN:每分的第0秒翻轉?還是脈沖?
                                        BSPRX8025_INTAOUT_HOUR:每時的第0秒翻轉?還是脈沖?
                                        BSPRX8025_INTAOUT_MONTH:每月的第0秒翻轉?還是脈沖?
* Output                :
* Note(s)                :
//void BSP_RX8025ControlINTA(_BSPRX8025_INTAOUT state)
//        _RX8025_REG_CONTROL1 data;
//        RX8025Read((RX8025_ADDR_CONTROL1&RX8025_READ_MODE),(u8 *)(&data),1);
//        data.bits.CT = state;                                                        // INTA輸出1Hz方波
//        RX8025Write((RX8025_ADDR_CONTROL1&RX8025_WRITE_MODE),(u8 *)(&data),1);
* Function                : BSP_RX8025Init
* Description        : RX8025初始化
* Input                        :
* Output                :
* Note(s)                :
* Contributor        : 081210        andydriver
void BSP_RX8025Init(void)
    u8 buf[16];
        u8 i;
//        iic_init();
        RX8025Read((RX8025_ADDR_SECONDS&RX8025_READ_MODE),buf,8);
        buf[0] = 0x20;
        RX8025Write((RX8025_ADDR_CONTROL1&RX8025_WRITE_MODE),buf,1);        //24小時制
        RX8025Read((RX8025_ADDR_SECONDS&RX8025_READ_MODE),buf,16);
        i++;
ID:12816 發(fā)表于 2017-8-19 12:41 | 顯示全部樓層
這是RX8025AC的吧
ID:142977 發(fā)表于 2017-8-22 15:20 | 顯示全部樓層
RX8025T和AC在在時序上有區(qū)別嗎,最近也是在調試,希望解惑,總是讀出00來
ID:12816 發(fā)表于 2017-9-3 21:29 | 顯示全部樓層
小二郎666 發(fā)表于 2017-8-22 15:20
基本一樣就是幾個寄存器不同
ID:437042 發(fā)表于 2018-12-1 11:54 | 顯示全部樓層
你好,我想問一下設備讀寫地址和寄存器地址是怎么定義的啊?
ID:55591 發(fā)表于 2019-1-31 07:18 | 顯示全部樓層
有沒有 RX8025T的??
ID:581992 發(fā)表于 2020-11-12 22:54 | 顯示全部樓層
RX8025T我也是一直沒有找到例程
主站蜘蛛池模板: 狠狠操av| 黄色片久久 | 免费理论片 | 欧美爱爱网 | 五月婷婷六月激情 | 成人激情视频网 | 影音先锋在线视频 | 五月婷婷综合网 | 亚洲二区在线 | 久久免费视频网站 | 欧美精品一区二区三区四区 | 免费中文字幕日韩欧美 | 天天爱天天色 | 欧洲精品| 国内精品一区二区三区 | 精品日韩在线观看 | 日韩免费 | 国产一区二区免费看 | 久久久久久九九九九 | 午夜看片 | 91免费看 | 激情五月婷婷综合 | 国产精品福利视频 | 波多野结衣黄色 | 亚洲免费视频观看 | 国产欧美日韩在线观看 | 色一情一乱一伦一区二区三区 | 成年免费视频黄网站在线观看 | 狼人色 | 一区二区三区四区av | 亚洲一级二级 | 青青草手机在线视频 | 一区二区三区视频在线 | 国产无精乱码一区二区三区 | 亚洲一级免费视频 | 欧美成人午夜 | 欧美偷拍精品 | 亚洲精品日韩丝袜精品 | 精品乱子伦一区二区三区 | 亚洲人天堂 | 97国产在线观看 |
