用ICC-AVR模數(shù)轉換的問題,數(shù)據(jù)顯示不正常,AD輸入接PA7,四位數(shù)碼管位選接PA0~PA3,段選接Pc口,參考電壓選擇2,56v基準電壓,實際測定的電壓是1.49v,預期數(shù)碼管應該顯示的是596,但結果卻顯示1023,而且改變他的電壓數(shù)據(jù)會變化,但結果還是不變,望哪位大神指教下,謝謝!以下是程序:
#include <iom16v.h>
#include <macros.h>
#define uchar unsigned char
#define uint unsigned int
unsigned char smg_du[]={0xee,0x28,0xb6,0xba,0x78,0xda,0xde,0xa8,0xfe,0xfa};
unsigned char smg_we[]={0x01,0x02,0x04,0x08};
uchar table[8]={0,0,0,0,0,0,0,0};
void init (void)
DDRA=0x0f;
PORTA=0;
DDRC=0xff; //01111000
PORTC=0;
void delay(void)
uint a;
for(a=0;a<300;a++);
void display(uchar *p)
uchar i;
for(i=0;i<4;i++)
PORTA=smg_we[i];
PORTC=smg_du[table[i]];
delay();
adc_init(void)
DDRA&=~BIT(7);
PORTA&=~BIT(7);
ADMUX=0xc7;
ADCSRA=0xe8;
SFIOR=0x00;
SREG|=BIT(7);
void data_pro(uint temp_1,uint temp_h)
uint i,temp1,temp2;
temp1=temp_h*256;
temp2=temp1+temp_1;
table[0]=temp2/1000;
temp1=temp2%1000;
table[1]=temp1/100;
temp2=temp1%100;
table[2]=temp2/10;
table[3]=temp2%10;
for(i=0;i<4;i++)
PORTA=smg_we[i];
delay();
void main(void)
init();
adc_init();
while(1);
#pragma interrupt_handler adc_isr:15
void adc_isr(void)
uint adc_1,adc_h;
if(ADCSRA=0xe8)
adc_1=ADCL;
adc_h=ADCH;
data_pro(adc_1,adc_h);
