查看: 5016|回復(fù): 2
MSP430 IIC 協(xié)議
ID:51024 發(fā)表于 2014-8-14 14:39 | 顯示全部樓層 |閱讀模式
坐在電腦前寫了一整個(gè)下午加一個(gè)晚上,終于在430上完成了 IIC 協(xié)議,在此附上 代碼吧,留個(gè)紀(jì)念,睡覺去,晚安!
#ifndef __IIC_h
#define __IIC_h
#include "basic.h"
//宏定義
#define IIC_OUT P1OUT
#define IIC_DIR P1DIR
#define IIC_SEL P1SEL
#define IIC_IN  P1IN
#define IIC_SDA_IN   IIC_IN&0X01//取SDA讀取的值,根據(jù)接的高地位不同,與上不同的BIT
#define SDA_OUT IIC_DIR|=BIT0
#define SDA_IN  IIC_DIR&=~BIT0
#define SET_SDA IIC_OUT|=BIT0
#define SET_SCL IIC_OUT|=BIT1
#define SET_IIC_EN IIC_OUT|=BIT2
#define CLE_SDA IIC_OUT&=~BIT0
#define CLE_SCL IIC_OUT&=~BIT1
#define CLE_IIC_EN IIC_OUT&=~BIT2
uchar ERROR_BIT=0;//應(yīng)答錯(cuò)誤標(biāo)志,1錯(cuò)誤,0為正確
//IO配置
void IIC_INIT()
  IIC_SEL=0X00;
  IIC_DIR|=(BIT0+BIT1+BIT2+BIT3);//設(shè)定三個(gè)位輸出
//IIC_START
void IIC_START()
  SDA_OUT;//設(shè)定SDA輸出
  SET_SCL;
  delay();
  SET_SDA;
  delay();
  CLE_SDA;
  delay();
  CLE_SCL;
  delay();
//IIC_STOP
void IIC_STOP()
  SET_SCL;
  delay();
  CLE_SDA;
  delay();
  SET_SDA;
  delay();
  CLE_SCL;
  delay();
//應(yīng)答信號(hào)
void IIC_ACK()//IIC總線應(yīng)答////////SCL為高電平時(shí),SDA為低電平,(主機(jī)對(duì)從機(jī))
  CLE_SDA;
  delay();
  SET_SCL;
  delay();
  CLE_SCL;
  delay();
//無應(yīng)答信號(hào)
void NO_ACK()//(主機(jī)對(duì)從機(jī))
  SET_SDA;
  delay();
  SET_SCL;
  delay();
  CLE_SCL;
  delay();
uchar TEST_ACK()//應(yīng)答錯(cuò)誤檢測(cè),1錯(cuò)誤,0為正確
  SDA_IN;
  SET_SCL;
  delay();
  if(IIC_SDA_IN&0x01)
    ERROR_BIT=1;
    ERROR_BIT=0;
  delay();
  CLE_SCL;
  delay();
  return ERROR_BIT;
//IIC寫字節(jié)
void IIC_WRITE_DATA(uchar data)
  uchar i;
  for(i=0;i<8;i++)
    SDA_OUT;
    if(data&0x80)
      SET_SDA;//判斷發(fā)送位,送數(shù)據(jù)到數(shù)據(jù)線上
      delay();
      CLE_SDA;
      delay();
    data = data<<1;
    SET_SCL;//置時(shí)鐘信號(hào)為高電平,使數(shù)據(jù)有效
    delay();
    CLE_SCL;
    delay();
  CLE_SCL;
  delay();
//IIC讀一個(gè)字節(jié)
unsigned char IIC_READ_DATA(void)
  SDA_IN;//置數(shù)據(jù)線為輸入方向
  unsigned char i,q0;
  unsigned char byte=0;
  for(i=0;i<8;i++)
    SET_SCL; //置時(shí)鐘為高電平,使數(shù)據(jù)線數(shù)據(jù)有效
    delay();
    byte=byte<<1;
    SDA_IN;
    q0=(P1IN & 0X01);
    if(q0==0X01) byte=(byte|0x01); //將數(shù)據(jù)存入byte
    delay();
    CLE_SCL;
    delay();
  return(byte);
/*uchar IIC_READ_DATA()
  uchar temp=0;
  uchar i;
  SDA_IN;//設(shè)定SDA輸入
  for(i=0;i<8;i++)
    SDA_IN;
    SET_SCL;
    delay();
    temp=temp<<1;
    if(IIC_SDA_IN ==1)
      temp++;
    delay();
    CLE_SCL;
    delay();
  CLE_SCL;
  delay();
  return temp;
#endif
下面這部分是AT24C02的操作程序
#ifndef __EEPROM_H
#define __EEPROM_H
#include "basic.h"
#include "IIC.H"
//宏定義
#define READ_MODE 0XA1
#define WRITE_MODE 0XA0
//在一個(gè)地址寫一個(gè)數(shù)據(jù)
uchar AT24C02_W_BYTE(uchar ADD,uchar DATA)
  IIC_START();//啟動(dòng)IIC
  IIC_WRITE_DATA(WRITE_MODE);//寫入模式
  //delay();
  if(TEST_ACK())
    return 1;
  IIC_WRITE_DATA(ADD);//寫入數(shù)據(jù)存儲(chǔ)地址
  //delay();
  if(TEST_ACK())
    return 1;
  IIC_WRITE_DATA(DATA);//寫入數(shù)據(jù)
  //delay();
  if(TEST_ACK())
    return 1;
  IIC_STOP();//停止IIC
  return 0;
//讀一個(gè)地址的數(shù)據(jù)
uchar AT24C02_R_BYTE(uchar ADD)
  uchar temp=0;
  IIC_WRITE_DATA(WRITE_MODE);//偽寫模式
  if(TEST_ACK())
    return 1;
  IIC_WRITE_DATA(ADD);//寫入讀取地址
  if(TEST_ACK())
    return 1;
  IIC_START();//重新啟動(dòng)IIC
  IIC_WRITE_DATA(READ_MODE);//讀取模式
  if(TEST_ACK())
    return 1;
  temp=IIC_READ_DATA();//讀取數(shù)據(jù)
  NO_ACK();
  IIC_STOP();
  return temp;
//頁寫
uchar AT24C02_W_PAGE(uchar *p,uchar ADD,uchar lengh)
  uchar i;
  IIC_WRITE_DATA(WRITE_MODE);//寫模式
  //delay();
  if(TEST_ACK())
    return 1;
  IIC_WRITE_DATA(ADD);//寫入起始地址
  //delay();
  if(TEST_ACK())
    return 1;
  for(i=0;i<lengh;i++)//寫入數(shù)據(jù)
    IIC_WRITE_DATA(*p);
    //delay();
    if(TEST_ACK())//來自EEPROM的應(yīng)答
      return 1;
    p++;
  IIC_STOP();//停止IIC
  delayms(25);//延時(shí)讓IIC進(jìn)行擦除,
              //延時(shí)時(shí)間很重要,
              //如果出現(xiàn)寫入數(shù)據(jù)錯(cuò)誤,
              //則試試延長(zhǎng)時(shí)間
  return 0;
//連續(xù)讀數(shù)據(jù)
uchar AT24C02_R_PAGE(uchar *p,uchar ADD,uchar lengh)//*p為要存儲(chǔ)數(shù)據(jù)的數(shù)組,
                                                    //ADD為讀取的起始地址,
                                                    //lengh是要讀取的長(zhǎng)度,一般小于7
  uchar i;
  if(TEST_ACK())
    return 1;
  if(TEST_ACK())
    return 1;
  IIC_WRITE_DATA(READ_MODE);//讀模式
  if(TEST_ACK())
    return 1;
  for(i=0;i<(lengh-1);i++)//讀取數(shù)據(jù)并存儲(chǔ)
    *p=IIC_READ_DATA();
    IIC_ACK();//來自主機(jī)的應(yīng)答
    p++;
  *p=IIC_READ_DATA();
  NO_ACK();  //停止時(shí)主機(jī)無應(yīng)答
  delay();
  IIC_STOP();//停止IIC
  delayms(15);
  return 0;
#endif
評(píng)分
參與人數(shù) 1黑幣 +5 收起 理由
ssfc + 5 贊一個(gè)!
查看全部評(píng)分
ID:77610 發(fā)表于 2015-4-28 13:02 | 顯示全部樓層
430單片機(jī)的IIC可以不用這么寫  你這么相當(dāng)于沒用到IIC模塊本身啊
ID:72995 發(fā)表于 2015-8-10 13:16 | 顯示全部樓層
430的好多板子沒有IIC的
主站蜘蛛池模板: 性猛交xxxx富婆老太婆 | 欧美久久精品 | 瑟瑟视频在线观看 | 成人在线国产 | 中文在线字幕观看 | www.九色| 成人国产精品免费观看 | 夜夜夜夜操 | 免费看成人片 | 亚洲成肉网 | 亚洲视频免费看 | 午夜在线视频 | 国产一级特黄 | 亚洲欧美日韩国产精品 | 黄色在线免费网站 | 麻豆精品一区 | 亚洲成人一区 | 亚洲欧洲在线观看 | 久久一级视频 | 久久精视频| 欧美综合一区二区三区 | 天天操夜夜爽 | 国产精品福利一区 | 99免费视频 | 久久91视频| 欧美狠狠干 | 国产日韩精品在线 | 激情婷婷综合 | 国产区在线 | 亚洲视频在线免费观看 | 黄大色黄大片女爽一次 | 免费性爱视频 | 国产又色又爽又黄又免费 | 精品一区二区三区在线观看 | 欧美日韩国产中文 | 欧美日韩在线一区 | 久久久精品免费 | 天天综合精品 | 国产成人综合网 | 免费视频一区 | 亚洲精品一区二三区 |
