在Keil MDK 開發(fā)環(huán)境里,比如一個 無符號32位整形數(shù)據(jù)會有很多種表示方法:1,unsigned int 32 (C語言標準表達方法) 2,uint32_t ; 3 ,u32; 這三種方式都是在表達同一個意思,可為什么ST的開發(fā)人員要搞的這么亂呢? 還有其他好多你可能看起來很陌生 ,很不好理解的表達方式,如:_IO int32_t 他等同于vs32(這個你同樣很陌生),不過他還等同于 volatile int32_t, 還等同于 volatile signed int 32;最后這種表達方式才是C語言的標準表達方式,夠亂吧,能把初學(xué)者弄的暈頭轉(zhuǎn)向。
其實ST 搞這么多花樣,無非是想開發(fā)人員在寫代碼時定義數(shù)據(jù)類型能少寫幾個符號,然后又因為前后版本升級,為了兼容舊版本(主要是V2.0)才會出現(xiàn)這么多表示方法。不管他怎么換,都是基于標準C來的,看清楚以下幾個文件你就OK了:core_cm3.h ;stm32f10x.h; stdint.h; 其中每個文件大概作用如下:
stdint.h 這里放著C語言的標準表達方式
//第36行開始
typedef signed char int8_t; // 標準表達方式 signed char 被等同于 int8_t;
typedef signed short int int16_t;
typedef signed int int32_t;//在32位環(huán)境里,int代表4個字節(jié)32位!!
typedef signed __int64 int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned __int64 uint64_t;
typedef signed char int_least8_t;
typedef signed short int int_least16_t;
typedef signed int int_least32_t;
typedef signed __int64 int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned __int64 uint_least64_t;
typedef signed int int_fast8_t;
typedef signed int int_fast16_t;
typedef signed int int_fast32_t;
typedef signed __int64 int_fast64_t;
typedef unsigned int uint_fast8_t;
typedef unsigned int uint_fast16_t;
typedef unsigned int uint_fast32_t;
typedef unsigned __int64 uint_fast64_t;
typedef signed int intptr_t;
typedef unsigned int uintptr_t;
typedef signed __int64 intmax_t;
typedef unsigned __int64 uintmax_t;
core_cm3.h 文件主要針對動態(tài) 靜態(tài) 變量修飾符做出類型擴展
#ifdef __cplusplus
#define __I volatile
#else
#define __I volatile const
#endif
#define __O volatile
#define __IO volatile
stm32f10x.h 這個文件主要是為了兼容舊版本吧
typedef int32_t s32;
typedef int16_t s16;
typedef int8_t s8;
typedef const int32_t sc32;
typedef const int16_t sc16;
typedef const int8_t sc8;
typedef __IO int32_t vs32;
typedef __IO int16_t vs16;
typedef __IO int8_t vs8;
typedef __I int32_t vsc32;
typedef __I int16_t vsc16;
typedef __I int8_t vsc8;
typedef uint32_t u32;
typedef uint16_t u16;
typedef uint8_t u8;
typedef const uint32_t uc32;
typedef const uint16_t uc16;
typedef const uint8_t uc8;
typedef __IO uint32_t vu32;
typedef __IO uint16_t vu16;
typedef __IO uint8_t vu8;
typedef __I uint32_t vuc32;
typedef __I uint16_t vuc16;
typedef __I uint8_t vuc8;
