查看: 3912|回復: 0
STM32學習之一 - 計頻器設計原理
ID:51025 發表于 2014-8-29 17:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
檢測外部脈沖信號頻率方法有三種:
(1)  TIM3 is configured in Input Capture Mode: the external signal is connected to
TIM3 Channel2 used as input pin.
To measure the frequency we use the TIM3 CC2 interrupt request,
so In the TIM3_IRQHandler routine, the frequency of the external signal is computed.
The "TIM3Freq" variable contains the external signal frequency:
TIM3Freq = TIM3 counter clock / Capture in Hz,
where the Capture is the difference between two consecutive TIM3 captures.
For Low-density, Medium-density, High-density and Connectivity line devices,
the minimum frequency value to measure is 1100 Hz.
For Low-Density Value line, Medium-Density and High-Density Value line devices,
the minimum frequency value to measure is 366 Hz.
(2)  TIM3 is configured in PWM Input Mode: the external signal is connected to
To measure the frequency and the duty cycle we use the TIM3 CC2 interrupt request,
so In the TIM3_IRQHandler routine, the frequency and the duty cycle of the external
signal are computed.
The "Frequency" variable contains the external signal frequency:
Frequency = TIM3 counter clock / TIM3_CCR2 in Hz,
The "DutyCycle" variable contains the external signal duty cycle:
DutyCycle = (TIM3_CCR1*100)/(TIM3_CCR2) in %.
For Low-Density Value line and Medium-Density Value line devices, the minimum
3)對于High-density devices(大容量型)如果檢測脈沖的頻率小于1100Hz,我們可以采用外部中斷邊沿的觸發方式來計算脈沖的個數,通過定時器準確定時1s所測得的脈沖個數即為脈沖信號周期。
主站蜘蛛池模板: 超碰在线免费播放 | 9l视频自拍九色9l视频成人 | 黄色一级视频免费看 | 无套内谢的新婚少妇国语播放 | 日韩欧美一区二区三区 | 亚洲黄色在线视频 | 久操视频在线观看 | 一区二区三区四区在线视频 | 精品一区二区三区av | 国产女人高潮毛片 | 神马影院午夜伦理片 | 一区二区在线免费观看 | 亚洲黄色成人 | 亚洲人精品 | 我要操网站 | 亚洲精品二区 | 在线日韩一区 | www.四虎影视 | 免费看毛片的网站 | 久久精品久久久精品美女 | 不卡av网站 | 黄色av毛片 | 中国av在线播放 | 久久机热这里只有精品 | 黄色成人毛片 | 国产人妖在线 | 久久免费小视频 | 日韩精品一区在线 | 国产成人精品一区二区三区福利 | 国产在线观看一区 | 福利小视频在线观看 | 国产精品毛片va一区二区三区 | 天天操夜夜操 | 在线视频福利 | 中文字幕亚洲欧美 | 久久综合激情 | 可以免费看的av | 黄色国产视频 | 少妇高潮露脸国语对白 | 久久亚洲成人 | 国内精品偷拍 |
