查看: 8295|回復: 1
51單片機小車制作 STEP2.3 直流電機PWM按鍵調速
ID:65608 發表于 2014-9-12 01:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 daliu 于 2014-9-12 01:49 編輯
上面的如果播放不了,可以去這個地址看http://www.tudou.com/programs/view/Yk844_HjfJ0/
思路什么的,貼吧有http://tieba.baidu.com/p/2807615491?pn=3
#include
sbit PWM_OUT1P=P0^5;
sbit PWM_OUT2P=P0^6;
sbit PWM_OUT3P=P0^7;
sbit key1=P0^0;
sbit key2=P0^1;
bit PWM_OUTDAT1;
bit PWM_OUTDAT2;
bit PWM_OUTDAT3;
bit delaybit1=0; //延時開關
bit delaybit2=0;
unsigned int PWM_t1=0;
unsigned int PWM_t2=0;
unsigned int PWM_t3=0;
unsigned int delaytime_res1=0;//延時長度計數
unsigned int delaytime_res2=0;
unsigned int keybit=0; //按鍵計數
PWM_OUT1(unsigned int Cycle1,unsigned int PWM_on1);
PWM_OUT2(unsigned int Cycle2,unsigned int PWM_on2);
PWM_OUT3(unsigned int Cycle3,unsigned int PWM_on3);
TMOD=0x01;
TH0=(65536-100)/256;
TL0=(65536-100)%6;
IE=0x82;
TR0=1;
key1=1;
key2=1;
keybit=0;
if(key1==0)
delaybit1=1;
if(delaytime_res1==2)
if(key1==0)
if(keybit<7)
keybit++;
  delaytime_res1=0;
delaybit1=0;
if(key2==0)
delaybit2=1;
if(delaytime_res2==2)
if(key2==0)
if(keybit>0)
keybit--;
delaybit2=0;
delaytime_res2=0;
switch(keybit)
case 1:
PWM_OUT1P=PWM_OUT1(1000,900);
PWM_OUT2P=PWM_OUT2(1000,900);
break;
case 2:
PWM_OUT1P=PWM_OUT1(1000,700);
PWM_OUT2P=PWM_OUT2(1000,700);
break;
case 3:
PWM_OUT1P=PWM_OUT1(1000,500);
PWM_OUT2P=PWM_OUT2(1000,500);
break;
case 4:
PWM_OUT1P=PWM_OUT1(1000,300);
PWM_OUT2P=PWM_OUT2(1000,300);
break;
case 5:
PWM_OUT1P=PWM_OUT1(1000,100);
PWM_OUT2P=PWM_OUT2(1000,100);
break;
case 6:
PWM_OUT1P=PWM_OUT1(1000,0);
PWM_OUT2P=PWM_OUT2(1000,0);
break;
void Time_r() interrupt 1
TL0=(65536-100)%6;
PWM_t1++;
PWM_t2++;
PWM_t3++;
if(delaybit1==1)
delaytime_res1++;
if(delaybit2==1)
delaytime_res2++;
if(PWM_t1==PWM_on1)
PWM_OUTDAT1=0;
else if(PWM_t1==Cycle1)
PWM_t1=0;
if(PWM_on1!=0)
PWM_OUTDAT1=1;
return PWM_OUTDAT1;
if(PWM_t2==PWM_on2)
PWM_OUTDAT2=0;
else if(PWM_t2==Cycle2)
PWM_t2=0;
if(PWM_on2!=0)
PWM_OUTDAT2=1;
return PWM_OUTDAT2;
收藏收藏3 分享淘帖 頂 踩
ID:74784 發表于 2015-3-19 11:14 | 只看該作者
單片機與電機之間應該加入驅動電路
主站蜘蛛池模板: 久久激情网 | 三级黄网站| 亚洲欧美日韩色图 | 精品免费在线 | 欧美成人精品一区二区三区 | 亚洲一区国产精品 | 亚洲成人久久久 | 成人a视频 | 免费不卡视频 | 2018天天操 | 亚洲永久免费视频 | 一区二区三区国产精品 | 午夜黄色影院 | www.com黄色 | 成人9ⅰ免费影视网站 | 91丨九色丨国产在线 | 欧美日韩精品一区 | a级片免费在线观看 | 国产福利网站 | 亚洲视频免费观看 | 亚洲精品蜜桃 | 免费黄网站在线观看 | 日韩精品综合 | 成人欧美一区二区三区白人 | 国产精品高清在线观看 | 婷婷丁香激情 | 亚洲精品乱码久久久久久蜜桃91 | 狠狠干狠狠操 | 性做久久久 | 黄av在线 | 日日夜夜精品免费 | 欧美精品乱码99久久蜜桃 | 成人免费视频网址 | 性爱免费视频 | 国产黄a三级 | 欧美大片18 | 免费特级毛片 | 欧美精品一区二区三区四区 | 午夜网站在线观看 | 久久av资源| 性猛交xxxx富婆老太婆 |
