查看: 3799|回復(fù): 0
剛寫(xiě)的簡(jiǎn)單GUI畫(huà)圖程序
ID:51090 發(fā)表于 2014-9-17 23:07 | 顯示全部樓層 |閱讀模式
#include<iom16v.h>
#include<macros.h>
#include<math.h>
#define uchar unsigned char
#define uint unsigned int
#define P2 PORTA
#define background 0x2202
#define E_clear PORTB&=~BIT(2)
#define E_set PORTB|=BIT(2)
#define RW_clear PORTB&=~BIT(1)
#define RW_set PORTB|=BIT(1)
#define RS_clear PORTB&=~BIT(0)
#define RS_set PORTB|=BIT(0)
void delay(uint z_temp)
while(z_temp--);
void delay_ms(uint z_temp)
uint x_temp,y_temp;
for(x_temp=z_temp;x_temp>0;x_temp--)
for(y_temp=120;y_temp>0;y_temp--);
void delay_us(uint z_temp)
uint x_temp,y_temp;
for(y_temp=1;y_temp>0;y_temp--);
void write_com(uchar com)
E_clear;
RS_clear;
RW_clear;
PORTA=com;
E_set;
E_clear;
void write_dat(uchar dat)
E_clear;
RS_set;
RW_clear;
PORTA=dat;
E_set;
E_clear;
void init()
uint i,j;
uchar background_h,background_l;
background_h=background/0xff;
background_l=background%0xff;
DDRA=0XFF;
DDRB=0XFF;
/*for(j=0;j<240;j++)
write_com(0);
write_com(0);
write_com(j);
write_com(0);
for(i=0;i<320;i++)
write_dat(background_h);
write_dat(background_l);
void draw_pin(uint xp,uint yp,uint colorp)
/*xp=坐標(biāo)橫軸,yp=坐標(biāo)縱軸*/
write_com(xp%256);
write_com(xp/256);
write_com(yp);
write_com(0);
write_dat(colorp%256);
write_dat(colorp/256);
void draw_line(uint xl,uint yl,uint lonl,uint colorl,uchar genre)
/*xl=坐標(biāo)橫軸,yl=坐標(biāo)縱軸,genre=坐標(biāo)*/
uint col;uchar i,o,m;
uchar color_h=colorl/256;
uchar color_l=colorl%256;
if(genre==0)
while(lonl--)
draw_pin(xl++,yl,colorl);
if(genre==90)
while(lonl--)
draw_pin(xl,yl++,colorl);
if(genre==45)
while(lonl--)
draw_pin(xl++,yl--,colorl);
if(genre==175)
while(lonl--)
draw_pin(xl--,yl--,colorl);
void draw_box(uint xb,uint yb,uint with,uint high,uint colorb)
while(high--)
draw_line(xb,yb++,with,colorb,0);
void draw_round(uint xr,uint yr,uint rr,uint colorr)
int bx,by;
double an=3.1415926,pang;
pang=3.00/rr;
while(an>-3.1415926)
an=an-pang;
bx=(uint)(sin(an)*rr+xr);
by=(uint)(cos(an)*rr+yr);
draw_pin(bx,by,colorr);
void draw_rbox(uint xrb,uint yrb,uint rrb,uint colorrb)
while(rrb--)
draw_round(xrb,yrb,rrb,colorrb);
void draw_roundbox(uint xrb,uint yrb,uint rrb,uint clororrb)
init();
draw_pin(55,33,0xf452);
draw_line(99,88,123,0xf0ff,0);
draw_line(77,66,55,0xaabb,90);
draw_line(77,66,55,0x00f3,45);
draw_line(77,66,55,0x00bb,175);
draw_box(224,446,55,33,0x7777);
draw_round(99,93,66,0x9999);
draw_round(55,88,44,0x4444);
draw_rbox(100,100,33,0xf8b2);
主站蜘蛛池模板: 自拍偷拍第五页 | 又黄又爽又色视频 | 午夜久久久久久久 | 国产不卡视频在线观看 | 欧美日韩免费看 | 免费看黄色一级片 | 一区二区影院 | 亚洲毛片在线 | 成人在线a| 国产女人18毛片水18精品 | 欧美色综合天天久久综合精品 | 欧美日本国产 | 成人福利片 | 欧美香蕉视频 | av观看免费 | 欧美一级做性受免费大片免费 | 欧美午夜精品久久久久免费视 | 日日夜夜精品免费 | 99久久久| 午夜精品久久久久 | 日韩一区二区在线观看视频 | 免费在线观看黄 | www.成人在线| 成人在线视频播放 | 国产免费小视频 | 黄色一级片网站 | 日本黄色免费看 | 免费在线小视频 | 亚洲欧美另类在线 | 四虎在线免费视频 | 久草网在线观看 | www..com黄 | 国产综合亚洲精品一区二 | 三上悠亚激情av一区二区三区 | 亚洲欧美日韩国产 | 黄色三级视频在线观看 | 国产精品免费一区 | 亚洲精品一区二三区不卡 | 日韩精品一区二区三区免费视频 | 天堂网亚洲 | 伊人影院综合 |
