查看: 11124|回復: 11
51單片機最小系統板 12864液晶無法顯示 求解決
ID:66729 發表于 2014-10-3 22:12 | 顯示全部樓層 |閱讀模式
51單片機最小系統板 如圖,寫入程序后12864液晶無法顯示,已經試過多次了。。唉。。
   付上程序,看看哪時不行了??
#include "reg52.h"
#include "intrins.h"
sbit io_LCD12864_RS = P2^3 ;
sbit io_LCD12864_RW = P2^4 ;
sbit io_LCD12864_EN = P2^5 ;
#define io_LCD12864_DATAPORT P0
#define SET_DATA    io_LCD12864_RS = 1 ;
#define SET_INC      io_LCD12864_RS = 0 ;
#define SET_READ   io_LCD12864_RW = 1 ;
#define SET_WRITE io_LCD12864_RW = 0 ;
#define SET_EN       io_LCD12864_EN = 1 ;
#define CLR_EN       io_LCD12864_EN = 0 ;
void v_Lcd12864CheckBusy_f( void )      //忙檢測函數
        unsigned int nTimeOut = 0 ;
  SET_INC
  SET_READ
  CLR_EN
  SET_EN
  while( ( io_LCD12864_DATAPORT & 0x80 ) && ( ++nTimeOut != 0 ) ) ;
  CLR_EN
  SET_INC
  SET_READ
void v_Lcd12864SendCmd_f( unsigned char byCmd )     //發送命令
  v_Lcd12864CheckBusy_f() ;
        SET_INC
  SET_WRITE
  CLR_EN
  io_LCD12864_DATAPORT = byCmd ;
  _nop_();
  _nop_();
  SET_EN
  _nop_();
  _nop_();
  CLR_EN
  SET_READ
  SET_INC
void v_Lcd12864SendData_f( unsigned char byData ) //發送數據
        SET_DATA
  SET_WRITE
  CLR_EN
  io_LCD12864_DATAPORT = byData ;
  _nop_();
  _nop_();
  SET_EN
  _nop_();
  _nop_();
  CLR_EN
  SET_READ
  SET_INC
void v_DelayMs_f( unsigned int nDelay )          //延時
  unsigned int i ;
        for( ; nDelay > 0 ; nDelay-- )
          for( i = 125 ; i > 0 ; i-- ) ;
void v_Lcd12864Init_f( void )              //初始化
  v_Lcd12864SendCmd_f( 0x30 ) ;           //基本指令集
  v_DelayMs_f( 50 ) ;
  v_Lcd12864SendCmd_f( 0x01 ) ;           //清屏
  v_DelayMs_f( 50 ) ;
  v_Lcd12864SendCmd_f( 0x06 ) ;           //光標右移
  v_DelayMs_f( 50 ) ;
  v_Lcd12864SendCmd_f( 0x0c ) ;            //開顯示
void v_Lcd12864SetAddress_f( unsigned char x, y )    //地址轉換
  unsigned char byAddress ;
  switch( y )
    case 0 :  byAddress = 0x80 + x ;
      break;
    case 1 :  byAddress = 0x90 + x ;
      break ;
    case 2 :  byAddress = 0x88 + x ;
      break ;
    case 3 :       byAddress = 0x98 + x ;
      break ;
    default :
      break ;
  v_Lcd12864SendCmd_f( byAddress ) ;
void v_Lcd12864PutString_f( unsigned char x, unsigned char y, unsigned char *pData )
  v_Lcd12864SetAddress_f( x, y ) ;
  while( *pData != '\0' )
    v_Lcd12864SendData_f( *pData++ ) ;
void main( void )
  v_Lcd12864Init_f() ;
  v_Lcd12864PutString_f( 0,0, "快樂隨行") ;
  v_Lcd12864PutString_f( 2,1, "分都不給") ;
  v_Lcd12864PutString_f( 0,2, "*LCD12864ST7920*") ;
  v_Lcd12864PutString_f( 0,3, "辛苦回答了半天") ;
  while( 1 ) ;
板子接口說明
板子接口說明
12864接口說明
12864接口說明
ID:63094 發表于 2014-10-9 16:19 | 顯示全部樓層
剛試了你的程序 也沒顯示出來 ,我也剛學 沒法幫你改呵呵,簡單的會改
ID:66729 發表于 2014-10-9 21:03 | 顯示全部樓層
vohang 發表于 2014-10-9 16:19
我換了其他的程序,,改了接口,現在可以顯示了,,,唉開始以為LCD是壞的。。呵呵
ID:44262 發表于 2014-10-10 11:37 來自觸屏版 | 顯示全部樓層
能共享一下可用的程序嗎?
ID:66729 發表于 2014-10-10 22:01 | 顯示全部樓層
這個是我的板子上能正常顯示的程序,你也可以改一下接口或者顯示的字體。
//頭文件:
#include <reg52.h>
/********IO引腳定義***********************************************************/
sbit LCD_RS=P2^3;//定義引腳
sbit LCD_RW=P2^4;
sbit LCD_E=P2^5;
sbit PSB =P2^6;                //PSB腳為12864-12系列的串、并通訊功能切換,使用8位并行接口,PSB=1
/********宏定義***********************************************************/
#define LCD_Data P0
#define Busy    0x80 //用于檢測LCD狀態字中的Busy標識
/********函數聲明*************************************************************/
void WriteDataLCD(unsigned char WDLCD);
void WriteCommandLCD(unsigned char WCLCD,BuysC);
unsigned char ReadDataLCD(void);
unsigned char ReadStatusLCD(void);
void LCDInit(void);
void LCDClear(void);
void LCDFlash(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
/********數據定義*************************************************************/
code unsigned char  uctech[] = {"5 1 單片機實驗板"};
code unsigned char  net[] = {"lydz8.taobao.com"};
code unsigned char  mcu[] = {"自學單片機的首選"};
code unsigned char  qq[] = {"  QQ: 52927029  "};
/***********主函數開始********************************************************/
void main(void)
        Delay400Ms();         //啟動等待,等LCD講入工作狀態
        LCDInit();                 //LCM初始化
        Delay5Ms();         //延時片刻(可不要)
        while(1){
                LCDClear();
                DisplayListChar(0,1,uctech);        //顯示字庫中的中文數字
                DisplayListChar(0,2,net);                //顯示字庫中的中文數字
                DisplayListChar(0,3,mcu);                //顯示字庫中的中文
                DisplayListChar(0,4,qq);                //顯示字庫中的中文數字
                Delay400Ms();
                Delay400Ms();
                Delay400Ms();
                Delay400Ms();
                LCDFlash();                                                //閃爍效果
/***********寫數據********************************************************/
        ReadStatusLCD(); //檢測忙
        LCD_RS = 1;
        LCD_RW = 0;
        LCD_Data = WDLCD;
        LCD_E = 1;
        LCD_E = 1;
        LCD_E = 0;
/***********寫指令********************************************************/
void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC為0時忽略忙檢測
        if (BuysC) ReadStatusLCD(); //根據需要檢測忙
        LCD_RS = 0;
        LCD_RW = 0;
        LCD_Data = WCLCD;
        LCD_E = 1;
        LCD_E = 1;
        LCD_E = 0;
/***********讀數據********************************************************/
        unsigned char LCDDA;
        LCD_RS = 1;
        LCD_RW = 1;
        LCD_E = 1;
        LCD_E = 1;
        LCDDA=LCD_Data;
        LCD_E = 0;
        return(LCDDA);
/***********讀狀態*******************************************************/
        LCD_Data = 0xFF;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_E = 1;
        LCD_E = 1;
        while (LCD_Data & Busy); //檢測忙信號
        LCD_E = 0;
        return(1);
/***********初始化********************************************************/
void LCDInit(void)
        WriteCommandLCD(0x30,1); //顯示模式設置,開始要求每次檢測忙信號
        WriteCommandLCD(0x01,1); //顯示清屏
        WriteCommandLCD(0x06,1); // 顯示光標移動設置
        WriteCommandLCD(0x0C,1); // 顯示開及光標設置
/***********清屏********************************************************/
void LCDClear(void)
        WriteCommandLCD(0x34,1); // 顯示光標移動設置
        WriteCommandLCD(0x30,1); // 顯示開及光標設置
/***********閃爍效果********************************************************/
void LCDFlash(void)
        WriteCommandLCD(0x08,1); //顯示清屏
        Delay400Ms();
        WriteCommandLCD(0x0c,1); // 顯示開及光標設置
        Delay400Ms();
        Delay400Ms();
        Delay400Ms();
        Delay400Ms();
/***********按指定位置顯示一個字符*******************************************/
        if(Y<1)
                Y=1;
        if(Y>4)
                Y=4;
        X &= 0x0F;                         //限制X不能大于16,Y不能大于1
        switch(Y){
        case 1:X|=0X80;break;
        case 2:X|=0X90;break;
        case 3:X|=0X88;break;
        case 4:X|=0X98;break;
        WriteCommandLCD(X, 0); //這里不檢測忙信號,發送地址碼
        WriteDataLCD(DData);
/***********按指定位置顯示一串字符*****************************************/
        unsigned char ListLength,X2;
        ListLength = 0;
        X2=X;
        if(Y<1)
                Y=1;
        if(Y>4)
                Y=4;
        X &= 0x0F;                                 //限制X不能大于16,Y在1-4之內
        switch(Y){
        case 1:X2|=0X80;break;        //根據行數來選擇相應地址
        case 2:X2|=0X90;break;
        case 3:X2|=0X88;break;
        case 4:X2|=0X98;break;
        WriteCommandLCD(X2, 1);         //發送地址碼
          while (DData[ListLength]>=0x20){ //若到達字串尾則退出
                   if (X <= 0x0F){                         //X坐標應小于0xF
                     WriteDataLCD(DData[ListLength]);
                     ListLength++;
                         X++;
                         Delay5Ms();
/***********短延時********************************************************/
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
/***********長延時********************************************************/
        unsigned char TempCycA = 5;
        unsigned int TempCycB;
        while(TempCycA--){
                  TempCycB=7269;
                  while(TempCycB--);
ID:66729 發表于 2014-10-10 22:03 | 顯示全部樓層
HEX文件
參與人數 1威望 +50 黑幣 +50 收起 理由
admin + 50 + 50 共享資料的積分獎勵!
ID:67992 發表于 2014-11-5 22:57 | 顯示全部樓層
程序一點問題都沒有,只改了3根控制線,正常顯示。
參與人數 1威望 +50 收起 理由
admin + 50
ID:66840 發表于 2014-11-6 08:35 | 顯示全部樓層
程序里由很多沒加分號
ID:68253 發表于 2014-11-8 21:26 | 顯示全部樓層
是你接口沒整清楚吧
ID:66729 發表于 2014-11-15 19:38 | 顯示全部樓層
wyy450y 發表于 2014-11-8 21:26
是你接口沒整清楚吧
已經正常,換個程序就好了。。呵呵
ID:109647 發表于 2016-3-19 10:39 | 顯示全部樓層
dgahz 發表于 2014-11-5 22:57
你好  我也是這個程序  出的問題  請問您改了哪三根控制線?
ID:147415 發表于 2017-9-7 16:16 | 顯示全部樓層
rst沒有強制復位一次
主站蜘蛛池模板: 福利片国产 | 日韩视频免费大全中文字幕 | 国产成人精品一区二区三区在线观看 | 亚洲天堂视频在线 | www一区 | 国产在线视频一区二区 | 97国产精品| 日韩免费一区 | 欧美精品福利 | 日韩午夜精品 | 亚洲精品三级 | 天堂av影院 | 一区二区视频在线 | 欧美日韩国产精品 | 国产精品久久久久久久久久久久久久 | 在线免费观看黄 | 国产精品免费一区 | 国内精品一区二区三区 | 欧美一区二区在线 | 自拍偷拍亚洲 | 黄色网免费 | 久久久综合视频 | 亚洲成人一区二区三区 | 男女久久久 | 国产欧美精品一区二区 | 三级黄色网址 | 亚洲国产欧美日韩在线 | 成人午夜小视频 | 成人精品免费 | 四虎久久久 | av在线免费观看网站 | h视频在线播放 | 久久视频在线 | 国产探花在线精品一区二区 | 日韩欧美在线视频观看 | 精品一区av | 亚洲欧美一区二区三区在线 | 91女人18毛片水多国产 | 久久精品福利视频 | 国产主播99 | 韩国av在线|
