ATmega32的有三個定時器,T0和T2是8位的,T1是16位的,各自提供了很多功能 都是以前用studio寫的,那時還沒用iar
//定時器0溢出中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
#include <avr/interrupt.h>
int main(void)
DDRC |= (1 << 7);//PC7置為輸出
TIMSK |= 1<<TOIE0;//不屏蔽T0溢出中斷
TCCR0 |= (1 << CS02) |(0 << CS01) | (1 << CS00);//1024分頻
sei();//使能全局中斷
while(1);
SIGNAL(SIG_OVERFLOW0)//TIMER0 溢出中斷服務程序
PORTC ^= 1<<7;//PC7取反
//定時器0普通匹配模式中斷
//CPU:mega32
//編譯器:winavr #include <avr/io.h>
#include <avr/interrupt.h> int main(void)
TIMSK |= 1<<OCIE0;//不屏蔽T0匹配中斷
OCR0 = 0X10;//匹配值
sei();//使能全局中斷
while(1);
SIGNAL(SIG_OUTPUT_COMPARE0)//TIMER0 匹配中斷服務程序
TCNT0 = 0;//計數值清0
//定時器0匹配時清零模式(CTC)中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
int main(void)
DDRB |= (1 << 3);//PC7置為輸出 TIMSK |= 1<<OCIE0;//不屏蔽T0匹配中斷
OCR0 = 0X10;//匹配值
TCCR0 |= (1 << WGM01) | (0 << WGM00) | (1 << CS02) | (0 << CS01) | (1 << CS00);//CTC模式,1024分頻
sei();//使能全局中斷
while(1);
} SIGNAL(SIG_OUTPUT_COMPARE0)//TIMER0 匹配中斷服務程序
//定時器0輸出正弦波
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
const char sindata[128] = {128,134,140,147,153,159,165,171,177,182,188,
193,199,204,209,213, 218,222,226,230,234,237,240,243,245,248,250,251,253,254,
254,255, 255,255,254,254,253,251,250,248,245,243,240,237,234,230,226,222, 218,
213,209,204,199,193,188,182,177,171,165,159,153,147,140,134, 128,122,116,109,
103,97,91,85,79,74,68,63,57,52,47,43, 38,34,30,26,22,19,16,13,11,8,6,5,3,2,2,1,
1,1,2,2,3,5,6,8,11,13,16,19,22,26,30,34, 38,43,47,52,57,63,68,74,79,85,91,97,
103,109,116,122}; unsigned char x=0; int main(void)
DDRB |= (1 << 3);//PB3 (OC0) 置為輸出 TIMSK |= 1<<OCIE0;//不屏蔽T0匹配中斷
TCCR0 |= (1 << WGM01) | (1 << WGM00) | (1 << COM01) | (0 << COM00) |(0 << CS02) | (0 << CS01) | (1 << CS00);//CTC模式,“高低”占空比,不分頻
sei();//使能全局中斷
while(1);
OCR0 = sindata[x];
if( ++x > 127 ) x=0;
//定時器1捕捉中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
TIMSK |= 1<<TICIE1;//不屏蔽T1捕捉中斷
TCCR1A |= (0<<WGM11) | (0<<WGM10);
TCCR1B |= (0<<WGM13) | (0<<WGM12) | (0 << CS12) |(1 << CS11) | (0 << CS10);//普通模式,不分頻
sei();//使能全局中斷
while(1);
} SIGNAL(SIG_INPUT_CAPTURE1)//TIMER1 捕捉中斷服務程序
//定時器1溢出中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
TIMSK |= 1<<TOIE1;//不屏蔽T1溢出中斷
sei();//使能全局中斷
while(1);
SIGNAL(SIG_OVERFLOW1)//TIMER1 溢出中斷服務程序
TCNT1H = 0X99;//先寫高位,后寫低位
TCNT1L = 0X88;
//定時器測頻率
//定時器1計數,定時器2定時
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
#define F 1000000 int main(void)
DDRC |= (1 << 7);//PC7置為輸出 TIMSK |= 1<<OCIE2;//不屏蔽T2匹配中斷
OCR2 = 0.1 *F/1024;//定時0.1s
TCCR2 |= (1 << WGM01) | (0 << WGM00) | (1 << CS02) | (1 << CS01) | (1 << CS00);//CTC模式,1024分頻
sei();//使能全局中斷 TCCR1A |= (0<<WGM11) | (0<<WGM10);
TCCR1B |= (0<<WGM13) | (0<<WGM12) | (1 << CS12) |(1 << CS11) | (0 << CS10);//普通模式,T1下降沿計數
while(1);
} SIGNAL(SIG_OUTPUT_COMPARE2)//TIMER2 匹配中斷服務程序
TCNT1H = 0;
TCNT1L = 0;
//定時器測1捕捉中斷
//可以測周期用
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
sei();//使能全局中斷
while(1);
TCNT1H = 0;
TCNT1L = 0;
