查看: 4802|回復: 0
java簡易DVD租售系統
ID:72008 發表于 2015-1-11 23:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1.     16天搞定JAVA。初學六天,寫了一段代碼練手。通過這個小項目,對類和方法更加理解了。
  2.     對java的感受是:比C簡單,更加智能化,傻瓜式開發。就像亞男說的,干java能多活幾年。
  3. package dvd;
  4. import java.text.SimpleDateFormat;
  5. import java.util.Date;
  6. importjava.util.Scanner;
  7. public class DvdTest {
  8.   public static void main(String[] args) {
  9.      int count = 0,count2 = 0;//count2-編號,count-一共有多少個DVD
  10.      Dvd [] arr=new Dvd[100];
  11.      View view = new View();
  12.      view.welcome();
  13.      while(true){
  14.        view.login();
  15.        Scanner chose1 = new Scanner(System.in);
  16.        int chose = chose1.nextInt();
  17.        switch(chose){
  18.          case 1:
  19.             count2 += 1;
  20.             Add add=new Add();
  21.             arr[count]=add.add(count2);
  22.             count++;
  23.             break;
  24.          case 2:
  25.             Look look=new Look();
  26.             look.look(arr,count);
  27.             break;
  28.          case 3:
  29.             Del del=new Del();
  30.             count=del.del(arr,count,count2);
  31.             break;
  32.          case 4:
  33.             Borrow borrow = new Borrow();
  34.             borrow.borrow(arr,count,count2);
  35.             break;
  36.          case 5:
  37.             System.exit(0);
  38.             break;
  39.          default:
  40.             System.out.println("input errno");
  41.        }
  42.      }
  43.   }
  44. }
  45. package dvd;
  46. public class Dvd {
  47.   private int num;
  48.   private String name;
  49.   private String state;
  50.   private String time;
  51.   public Dvd() {}
  52.   public int getNum() {
  53.      return num;
  54.   }
  55.   public void setNum(int num) {
  56.      this.num = num;
  57.   }
  58.   public String getName() {
  59.      return name;
  60.   }
  61.   public void setName(String name) {
  62.      this.name = name;
  63.   }
  64.   public String getState() {
  65.      return state;
  66.   }
  67.   public void setState(String state) {
  68.      this.state = state;
  69.   }
  70.   public String getTime() {
  71.      return time;
  72.   }
  73.   public void setTime(String time) {
  74.      this.time = time;
  75.   }
  76. }
  77. package dvd;
  78. importjava.util.Scanner;
  79. public class Add {
  80.   public Add() {}
  81.   //添加DVD
  82.   public Dvd add(int count2) {
  83.      Dvd arr=new Dvd();
  84.      arr.setNum(count2);
  85.      System.out.println("請輸入DVD名字:");
  86.      Scanner arr1 = new Scanner(System.in);
  87.      String arr2 = arr1.nextLine();
  88.      arr.setName(arr2);
  89.      arr.setState("未借出");
  90.      arr.setTime("\0");
  91.      System.out.println("DVD"+"("+arr2+")"+"添加成功");
  92.      return arr;
  93.   }
  94. }
  95. package dvd;
  96. importjava.text.SimpleDateFormat;
  97. importjava.util.Date;
  98. importjava.util.Scanner;
  99. public class Borrow {
  100.   public Borrow() {}
  101.   //借出
  102.   public void borrow(Dvd[] arr,int count,int count2) {
  103.      int flag1 = 0,flag2 = 0;
  104.
  105.      System.out.println("請輸入DVD編號:");
  106.      Scanner num1 = new Scanner(System.in);
  107.      int num2 = num1.nextInt();
  108.      if(num2 > count2){
  109.        System.out.println("輸入DVD編號不存在");
  110.        return;
  111.      }
  112.      for(int i=0;i<count;i++){
  113.        if(num2 == arr[i].getNum()){
  114.          flag1=1;
  115.          if((arr[i].getState()).equals("未借出")){
  116.             flag2 = 1;
  117.             arr[i].setState("已租借");
  118.             SimpleDateFormat df = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss");//設置日期格式
  119.             arr[i].setTime(df.format(new Date()));;// new Date()為獲取當前系統時間
  120.             System.out.println("DVD編號"+"("+num2+")"+"租借成功");
  121.             break;
  122.          }
  123.        }
  124.      }
  125.      if(flag1 == 0){
  126.        System.out.println("輸入DVD編號不存在");
  127.        return;
  128.      }
  129.      if(flag2 == 0)
  130.        System.out.println("DVD已借出");
  131.   }
  132. }
  133. package dvd;
  134. importjava.util.Scanner;
  135. public class Del{
  136.   public Del(){}
  137.   //刪除DVD
  138.   public int del(Dvd[] arr,int count,int count2) {
  139.      int flag1 = 0,flag2 = 0;
  140.      System.out.println("請輸入DVD編號:");
  141.      Scanner num1 = new Scanner(System.in);
  142.      int num2 = num1.nextInt();
  143.      if(num2 > count2){
  144.        System.out.println("輸入DVD編號不存在");
  145.        return count;
  146.      }
  147.      for(int i=0;i<count;i++){
  148.        if(num2 == arr[i].getNum()){
  149.          flag1 = 1;
  150.          if((arr[i].getState()).equals("未借出")){
  151.             flag2 = 1;
  152.             for(int j=i;j<count-1;j++){
  153.               arr[j].setNum(arr[j+1].getNum());
  154.               arr[j].setName(arr[j+1].getName());
  155.               arr[j].setState(arr[j+1].getState());
  156.               arr[j].setTime(arr[j+1].getTime());
  157.            }
  158.             System.out.println("DVD編號"+"("+num2+")"+"刪除成功");
  159.             count--;
  160.             break;
  161.          }
  162.        }
  163.      }
  164.      if(flag1 == 0){
  165.        System.out.println("輸入DVD編號不存在");
  166.        return count;
  167.      }
  168.      if(flag2 == 0)
  169.        System.out.println("刪除失敗,DVD已借出");
  170.      return count;
  171.   }
  172. }
  173. package dvd;
  174. public class Look {
  175.   public Look() {}
  176.   //查看DVD
  177.   public void look(Dvd[] arr,int count) {
  178.      System.out.println("編號"+"\t"+"DVD名字"+"\t"+"租借狀態"+"\t"+"租借時間"+"\t");
  179.      for(int i=0;i<count;i++){
  180.        System.out.println(arr[i].getNum()+"\t"+arr[i].getName()+"\t"
  181.             +arr[i].getState()+"\t"+arr[i].getTime()+"\t");
  182.      }
  183.   }
  184. }
  185. package dvd;
  186. public class View {
  187.   public View() {}
  188.   //歡迎界面
  189.   public void welcome() {
  190.      System.out.println("*******************"+"\n"
  191.          +"    DVD租售系統"+"\n"
  192.          +"*******************");
  193.   }
  194.   //進入系統界面
  195.   public void login() {
  196.      System.out.println("*******************"+"\n"
  197.                 +"    1.添加DVD"+"\n"
  198.                 +"    2.查詢DVD"+"\n"
  199.                 +"    3.刪除DVD"+"\n"
  200.                 +"    4.租借DVD"+"\n"
  201.                 +"    5.退出系統"+"\n"
  202.                 +"*******************");
  203.   }
  204. }
主站蜘蛛池模板: 伊人亚洲综合 | 成人午夜小视频 | 亚洲欧美天堂 | 欧美精品三区 | 亚洲免费看片 | 久久av一区 | 亚洲一级大片 | 日本在线视频一区二区 | 中文字幕麻豆 | 国产一级片在线播放 | 免费一级片 | 久久免费视频网站 | 亚洲成人精品一区 | 99视频网站 | 日本黄色免费看 | 欧美国产日韩精品 | 丰满少妇高潮在线观看 | 精品色 | 天天草天天射 | 三级av网站| 国产成人99久久亚洲综合精品 | 黄色在线免费看 | 国产一区免费视频 | 亚洲视频在线视频 | 伊人久久中文字幕 | 国产小视频在线播放 | 国产精品国产成人国产三级 | 日韩精品视频免费在线观看 | 亚洲免费婷婷 | 天天操操操操 | 国产欧美在线 | 九九精品九九 | 国产视频在线观看视频 | 国产成人亚洲精品自产在线 | 日韩欧美在线免费观看 | 九九热在线视频观看 | 99re在线观看视频 | wwwav在线| 婷婷六月综合 | 黄色影视| 国产伦精品一区二区三区免费视频 |
