查看: 9167|回復: 1
system_stm32f10x.c時鐘系統的設置
ID:72519 發表于 2015-1-23 03:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. /**
  2.   ******************************************************************************
  3.   * @file    GPIO/IOToggle/system_stm32f10x.c
  4.   * @author  MCD Application Team
  5.   * @version V3.4.0
  6.   * @date    10/15/2010
  7.   * @brief   CMSIS Cortex-M3 Device Peripheral Access Layer System Source File.
  8.   ******************************************************************************
  9.   *
  10.   * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  11.   * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  12.   * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  13.   * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  14.   * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  15.   * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  16.   *
  17.   * <h2><center>© COPYRIGHT 2010 STMicroelectronics</center></h2>
  18.   ******************************************************************************
  19.   */
  20. /** @addtogroup CMSIS
  21.   * @{
  22.   */
  23. /** @addtogroup stm32f10x_system
  24.   * @{
  25.   */
  26. /** @addtogroup STM32F10x_System_Private_Includes
  27.   * @{
  28.   */
  29. #include "stm32f10x.h"
  30. /**
  31.   * @}
  32.   */
  33. /** @addtogroup STM32F10x_System_Private_TypesDefinitions
  34.   * @{
  35.   */
  36. /**
  37.   * @}
  38.   */
  39. /** @addtogroup STM32F10x_System_Private_Defines
  40.   * @{
  41.   */
  42. /*!< Uncomment the line corresponding to the desired System clock (SYSCLK)
  43.    frequency (after reset the HSI is used as SYSCLK source)
  44.
  45.    IMPORTANT NOTE:
  46.    ==============
  47.    1. After each device reset the HSI is used as System clock source.
  48.    2. Please make sure that the selected System clock doesn't exceed your device's
  49.       maximum frequency.
  50.
  51.    3. If none of the define below is enabled, the HSI is used as System clock
  52.     source.
  53.    4. The System clock configuration functions provided within this file assume that:
  54.         - For Low, Medium and High density Value line devices an external 8MHz
  55.           crystal is used to drive the System clock.
  56.         - For Low, Medium and High density devices an external 8MHz crystal is
  57.           used to drive the System clock.
  58.         - For Connectivity line devices an external 25MHz crystal is used to drive
  59.           the System clock.
  60.      If you are using different crystal you have to adapt those functions accordingly.
  61.     */
  62.
  63. #if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)//如果定義了這些系統時鐘將設為24M,如果沒有定義則為72M
  64. /* #define SYSCLK_FREQ_HSE    HSE_VALUE */
  65. #define SYSCLK_FREQ_24MHz  24000000
  66. #else
  67. /* #define SYSCLK_FREQ_HSE    HSE_VALUE */
  68. /* #define SYSCLK_FREQ_24MHz  24000000 */
  69. /* #define SYSCLK_FREQ_36MHz  36000000 */
  70. /* #define SYSCLK_FREQ_48MHz  48000000 */
  71. /* #define SYSCLK_FREQ_56MHz  56000000 */
  72. #define SYSCLK_FREQ_72MHz  72000000      //系統時鐘默認值的定義 ,如果沒有定義外部高速時鐘則用內部高速時鐘,為8000000
  73. #endif
  74. /*!< Uncomment the following line if you need to use external SRAM mounted
  75.      on STM3210E-EVAL board (STM32 High density and XL-density devices) or on
  76.      STM32100E-EVAL board (STM32 High-density value line devices) as data memory */
  77. #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)//內外部SRAM選擇
  78. /* #define DATA_IN_ExtSRAM */
  79. #endif
  80. /*!< Uncomment the following line if you need to relocate your vector Table in
  81.      Internal SRAM. */
  82. /* #define VECT_TAB_SRAM */
  83. #define VECT_TAB_OFFSET  0x0 /*!< Vector Table base offset field. //向量表的基址偏移量
  84.                                   This value must be a multiple of 0x100. */
  85. /**
  86.   * @}
  87.   */
  88. /** @addtogroup STM32F10x_System_Private_Macros
  89.   * @{
  90.   */
  91. /**
  92.   * @}
  93.   */
  94. /** @addtogroup STM32F10x_System_Private_Variables
  95.   * @{
  96.   */
  97. /*******************************************************************************
  98. *  Clock Definitions;以下為把系統時鐘的定義值傳給系統內核時鐘變量,如果沒有定義外部高速時鐘則用內部高速時鐘,為8M
  99. *******************************************************************************/
  100. #ifdef SYSCLK_FREQ_HSE
  101.   uint32_t SystemCoreClock         = SYSCLK_FREQ_HSE;        /*!< System Clock Frequency (Core Clock) */
  102. #elif defined SYSCLK_FREQ_24MHz
  103.   uint32_t SystemCoreClock         = SYSCLK_FREQ_24MHz;        /*!< System Clock Frequency (Core Clock) */
  104. #elif defined SYSCLK_FREQ_36MHz
  105.   uint32_t SystemCoreClock         = SYSCLK_FREQ_36MHz;        /*!< System Clock Frequency (Core Clock) */
  106. #elif defined SYSCLK_FREQ_48MHz
  107.   uint32_t SystemCoreClock         = SYSCLK_FREQ_48MHz;        /*!< System Clock Frequency (Core Clock) */
  108. #elif defined SYSCLK_FREQ_56MHz
  109.   uint32_t SystemCoreClock         = SYSCLK_FREQ_56MHz;        /*!< System Clock Frequency (Core Clock) */
  110. #elif defined SYSCLK_FREQ_72MHz
  111.   uint32_t SystemCoreClock         = SYSCLK_FREQ_72MHz;        /*!< System Clock Frequency (Core Clock) */
  112. #else /*!< HSI Selected as System Clock source */
  113.   uint32_t SystemCoreClock         = HSI_VALUE;        /*!< System Clock Frequency (Core Clock) 如果沒有定義外部高速時鐘則用內部高速時鐘,為8000000*/
  114. #endif
  115. __I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};//AHB配方表
  116. /**
  117.   * @}
  118.   */
  119. /** @addtogroup STM32F10x_System_Private_FunctionPrototypes
  120.   * @{
  121.   */
  122. /*********************************************************************************
  123.                以下為函數聲明
  124. *********************************************************************************/
  125. static void SetSysClock(void); //設置系統時鐘的函數聲明
  126. //以下為根據不同的系統時鐘的定義來聲明用到的相應的函數,為后面的函數調用做好準備
  127. #ifdef SYSCLK_FREQ_HSE
  128.   static void SetSysClockToHSE(void);
  129. #elif defined SYSCLK_FREQ_24MHz
  130.   static void SetSysClockTo24(void);
  131. #elif defined SYSCLK_FREQ_36MHz
  132.   static void SetSysClockTo36(void);
  133. #elif defined SYSCLK_FREQ_48MHz
  134.   static void SetSysClockTo48(void);
  135. #elif defined SYSCLK_FREQ_56MHz
  136.   static void SetSysClockTo56(void);
  137. #elif defined SYSCLK_FREQ_72MHz
  138.   static void SetSysClockTo72(void);
  139. #endif
  140. #ifdef DATA_IN_ExtSRAM //外部SRAM選擇后的初始化函數聲明
  141.   static void SystemInit_ExtMemCtl(void);
  142. #endif /* DATA_IN_ExtSRAM */
  143. /**
  144.   * @}
  145.   */
  146. /** @addtogroup STM32F10x_System_Private_Functions
  147.   * @{
  148.   */
  149. /**
  150.   * @brief  Setup the microcontroller system
  151.   *         Initialize the Embedded Flash Interface, the PLL and update the
  152.   *         SystemCoreClock variable.
  153.   * @note   This function should be used only after reset.
  154.   * @param  None
  155.   * @retval None
  156.   */
  157. void SystemInit (void)//系統初始化函數,設置系統的時鐘及時鐘中斷(在startup_stm32f10x_md.s中調用)(復位RCC時鐘配置為默認狀態,直到設置時鐘函數)
  158. {
  159.   /* Reset the RCC clock configuration to the default reset state(for debug purpose) */
  160.   /* Set HSION bit */
  161.   RCC->CR |= (uint32_t)0x00000001; //內部高速時鐘使能,內部8MHz時鐘開啟
  162.   /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
  163. #ifndef STM32F10X_CL
  164.   RCC->CFGR &= (uint32_t)0xF8FF0000;//MCO微控制器沒有時鐘輸出(對外部引腳),ADC預分頻PCLK2 2分頻后作為ADC時鐘,APB預分頻HCLK不分頻,AHB預分頻SYSCLK不分頻,HSI作為系統時鐘
  165.                                     //HSI作為系統時鐘輸出(已輸出),SYSCLK=PCLK=PCLK1=PCLK2=8M,ADCCLK=1/2(PCLK2)=4M
  166. #else
  167.   RCC->CFGR &= (uint32_t)0xF0FF0000;//同上;RCC->CFGR的27位為保留位始終為0 ,HSI作為系統時鐘輸出(未輸出原因為未編譯)
  168. #endif /* STM32F10X_CL */
  169.   /* Reset HSEON, CSSON and PLLON bits */
  170.   RCC->CR &= (uint32_t)0xFEF6FFFF;//時鐘監測器關閉,HSE振蕩器關閉
  171.   /* Reset HSEBYP bit */
  172.   RCC->CR &= (uint32_t)0xFFFBFFFF;//外部4-25MHz振蕩器沒有旁路
  173.   /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */
  174.   RCC->CFGR &= (uint32_t)0xFF80FFFF; //PLL時鐘1.5倍分頻作為USB時鐘,PLL 2倍頻輸出,HSE不分頻,HSI時鐘2分頻后作為PLL輸入時鐘
  175.                                      //PLLCLK=HSICLK=8M(還未輸出),HSECLK=HSEOSC,USBCLK=PLLCLK/1.5 ,除PLL外其他分頻系數都為0
  176. #ifdef STM32F10X_CL
  177.   /* Reset PLL2ON and PLL3ON bits */
  178.   RCC->CR &= (uint32_t)0xEBFFFFFF;//CR中的26和28位置0
  179.   /* Disable all interrupts and clear pending bits  */
  180.   RCC->CIR = 0x00FF0000;//清除中斷標志,關閉一些中斷
  181.   /* Reset CFGR2 register */
  182.   RCC->CFGR2 = 0x00000000; //沒有此寄存器
  183. #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  184.   /* Disable all interrupts and clear pending bits  */
  185.   RCC->CIR = 0x009F0000;//清除中斷標志,關閉一些中斷
  186.   /* Reset CFGR2 register */
  187.   RCC->CFGR2 = 0x00000000; //沒有此寄存器
  188. #else
  189.   /* Disable all interrupts and clear pending bits  */
  190.   RCC->CIR = 0x009F0000; //清除中斷標志,關閉一些中斷
  191. #endif /* STM32F10X_CL */
  192.
  193. #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
  194.   #ifdef DATA_IN_ExtSRAM
  195.     SystemInit_ExtMemCtl();//如果宏定義了外部SRAM則對其初始化控制
  196.   #endif /* DATA_IN_ExtSRAM */
  197. #endif
  198.   /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
  199.   /* Configure the Flash Latency cycles and enable prefetch buffer */
  200.   SetSysClock();//設置系統時鐘
  201. #ifdef VECT_TAB_SRAM
  202.   SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. 向量表放在內部SRAM中*/
  203. #else
  204.   SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. 向量表放在內部flash中*/
  205. #endif
  206. }
  207. /**
  208.   * @brief  Update SystemCoreClock according to Clock Register Values
  209.   * @note   None
  210.   * @param  None
  211.   * @retval None
  212.   */
  213. void SystemCoreClockUpdate (void)
  214. {
  215.   uint32_t tmp = 0, pllmull = 0, pllsource = 0;
  216. #ifdef  STM32F10X_CL
  217.   uint32_t prediv1source = 0, prediv1factor = 0, prediv2factor = 0, pll2mull = 0;
  218. #endif /* STM32F10X_CL */
  219. #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  220.   uint32_t prediv1factor = 0;
  221. #endif /* STM32F10X_LD_VL or STM32F10X_MD_VL or STM32F10X_HD_VL */
  222.
  223.   /* Get SYSCLK source -------------------------------------------------------*/
  224.   tmp = RCC->CFGR & RCC_CFGR_SWS;
  225.   switch (tmp)
  226.   {
  227.     case 0x00:  /* HSI used as system clock */
  228.       SystemCoreClock = HSI_VALUE;
  229.       break;
  230.     case 0x04:  /* HSE used as system clock */
  231.       SystemCoreClock = HSE_VALUE;
  232.       break;
  233.     case 0x08:  /* PLL used as system clock */
  234.       /* Get PLL clock source and multiplication factor ----------------------*/
  235.       pllmull = RCC->CFGR & RCC_CFGR_PLLMULL;
  236.       pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
  237.
  238. #ifndef STM32F10X_CL
  239.       pllmull = ( pllmull >> 18) + 2;
  240.
  241.       if (pllsource == 0x00)
  242.       {
  243.         /* HSI oscillator clock divided by 2 selected as PLL clock entry */
  244.         SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
  245.       }
  246.       else
  247.       {
  248. #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  249.        prediv1factor = (RCC->CFGR2 & RCC_CFGR2_PREDIV1) + 1;
  250.        /* HSE oscillator clock selected as PREDIV1 clock entry */
  251.        SystemCoreClock = (HSE_VALUE / prediv1factor) * pllmull;
  252. #else
  253.         /* HSE selected as PLL clock entry */
  254.         if ((RCC->CFGR & RCC_CFGR_PLLXTPRE) != (uint32_t)RESET)
  255.         {/* HSE oscillator clock divided by 2 */
  256.           SystemCoreClock = (HSE_VALUE >> 1) * pllmull;
  257.         }
  258.         else
  259.         {
  260.           SystemCoreClock = HSE_VALUE * pllmull;
  261.         }
  262. #endif
  263.       }
  264. #else
  265.       pllmull = pllmull >> 18;
  266.
  267.       if (pllmull != 0x0D)
  268.       {
  269.          pllmull += 2;
  270.       }
  271.       else
  272.       { /* PLL multiplication factor = PLL input clock * 6.5 */
  273.         pllmull = 13 / 2;
  274.       }
  275.
  276.       if (pllsource == 0x00)
  277.       {
  278.         /* HSI oscillator clock divided by 2 selected as PLL clock entry */
  279.         SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
  280.       }
  281.       else
  282.       {/* PREDIV1 selected as PLL clock entry */
  283.
  284.         /* Get PREDIV1 clock source and division factor */
  285.         prediv1source = RCC->CFGR2 & RCC_CFGR2_PREDIV1SRC;
  286.         prediv1factor = (RCC->CFGR2 & RCC_CFGR2_PREDIV1) + 1;
  287.
  288.         if (prediv1source == 0)
  289.         {
  290.           /* HSE oscillator clock selected as PREDIV1 clock entry */
  291.           SystemCoreClock = (HSE_VALUE / prediv1factor) * pllmull;
  292.         }
  293.         else
  294.         {/* PLL2 clock selected as PREDIV1 clock entry */
  295.
  296.           /* Get PREDIV2 division factor and PLL2 multiplication factor */
  297.           prediv2factor = ((RCC->CFGR2 & RCC_CFGR2_PREDIV2) >> 4) + 1;
  298.           pll2mull = ((RCC->CFGR2 & RCC_CFGR2_PLL2MUL) >> 8 ) + 2;
  299.           SystemCoreClock = (((HSE_VALUE / prediv2factor) * pll2mull) / prediv1factor) * pllmull;
  300.         }
  301.       }
  302. #endif /* STM32F10X_CL */
  303.       break;
  304.     default:
  305.       SystemCoreClock = HSI_VALUE;
  306.       break;
  307.   }
  308.   /* Compute HCLK clock frequency ----------------*/
  309.   /* Get HCLK prescaler */
  310.   tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
  311.   /* HCLK clock frequency */
  312.   SystemCoreClock >>= tmp;
  313. }
  314. /**
  315.   * @brief  Configures the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers.
  316.   * @param  None
  317.   * @retval None
  318.   */
  319. static void SetSysClock(void)//根據不同的宏定義,設置不同的系統時鐘
  320. {
  321. #ifdef SYSCLK_FREQ_HSE
  322.   SetSysClockToHSE();
  323. #elif defined SYSCLK_FREQ_24MHz
  324.   SetSysClockTo24();
  325. #elif defined SYSCLK_FREQ_36MHz
  326.   SetSysClockTo36();
  327. #elif defined SYSCLK_FREQ_48MHz
  328.   SetSysClockTo48();
  329. #elif defined SYSCLK_FREQ_56MHz
  330.   SetSysClockTo56();
  331. #elif defined SYSCLK_FREQ_72MHz
  332.   SetSysClockTo72();
  333. #endif
  334. /* If none of the define above is enabled, the HSI is used as System clock
  335.     source (default after reset) */
  336. }
  337. /**
  338.   * @brief  Setup the external memory controller. Called in startup_stm32f10x.s
  339.   *          before jump to __main
  340.   * @param  None
  341.   * @retval None
  342.   */
  343. #ifdef DATA_IN_ExtSRAM
  344. /**
  345.   * @brief  Setup the external memory controller.
  346.   *         Called in startup_stm32f10x_xx.s/.c before jump to main.
  347.   *        This function configures the external SRAM mounted on STM3210E-EVAL
  348.   *         board (STM32 High density devices). This SRAM will be used as program
  349.   *         data memory (including heap and stack).
  350.   * @param  None
  351.   * @retval None
  352.   */
  353. void SystemInit_ExtMemCtl(void)
  354. {
  355. /*!< FSMC Bank1 NOR/SRAM3 is used for the STM3210E-EVAL, if another Bank is
  356.   required, then adjust the Register Addresses */
  357.   /* Enable FSMC clock */
  358.   RCC->AHBENR = 0x00000114;
  359.   /* Enable GPIOD, GPIOE, GPIOF and GPIOG clocks */
  360.   RCC->APB2ENR = 0x000001E0;
  361. /* ---------------  SRAM Data lines, NOE and NWE configuration ---------------*/
  362. /*----------------  SRAM Address lines configuration -------------------------*/
  363. /*----------------  NOE and NWE configuration --------------------------------*/
  364. /*----------------  NE3 configuration ----------------------------------------*/
  365. /*----------------  NBL0, NBL1 configuration ---------------------------------*/
  366.   GPIOD->CRL = 0x44BB44BB;
  367.   GPIOD->CRH = 0xBBBBBBBB;
  368.   GPIOE->CRL = 0xB44444BB;
  369.   GPIOE->CRH = 0xBBBBBBBB;
  370.   GPIOF->CRL = 0x44BBBBBB;
  371.   GPIOF->CRH = 0xBBBB4444;
  372.   GPIOG->CRL = 0x44BBBBBB;
  373.   GPIOG->CRH = 0x44444B44;
  374.
  375. /*----------------  FSMC Configuration ---------------------------------------*/
  376. /*----------------  Enable FSMC Bank1_SRAM Bank ------------------------------*/
  377.   FSMC_Bank1->BTCR[4] = 0x00001011;
  378.   FSMC_Bank1->BTCR[5] = 0x00000200;
  379. }
  380. #endif /* DATA_IN_ExtSRAM */
  381. #ifdef SYSCLK_FREQ_HSE
  382. /**
  383.   * @brief  Selects HSE as System clock source and configure HCLK, PCLK2
  384.   *          and PCLK1 prescalers.
  385.   * @note   This function should be used only after reset.
  386.   * @param  None
  387.   * @retval None
  388.   */
  389. static void SetSysClockToHSE(void)
  390. {
  391.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  392.   /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  393.   /* Enable HSE */
  394.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  395.   /* Wait till HSE is ready and if Time out is reached exit */
  396.   do
  397.   {
  398.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  399.     StartUpCounter++;
  400.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  401.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  402.   {
  403.     HSEStatus = (uint32_t)0x01;
  404.   }
  405.   else
  406.   {
  407.     HSEStatus = (uint32_t)0x00;
  408.   }
  409.   if (HSEStatus == (uint32_t)0x01)
  410.   {
  411. #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL && !defined STM32F10X_HD_VL
  412.     /* Enable Prefetch Buffer */
  413.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  414.     /* Flash 0 wait state */
  415.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  416. #ifndef STM32F10X_CL
  417.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
  418. #else
  419.     if (HSE_VALUE <= 24000000)
  420. {
  421.       FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
  422. }
  423. else
  424. {
  425.       FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
  426. }
  427. #endif /* STM32F10X_CL */
  428. #endif
  429.     /* HCLK = SYSCLK */
  430.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  431.
  432.     /* PCLK2 = HCLK */
  433.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  434.
  435.     /* PCLK1 = HCLK */
  436.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
  437.
  438.     /* Select HSE as system clock source */
  439.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  440.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_HSE;
  441.     /* Wait till HSE is used as system clock source */
  442.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x04)
  443.     {
  444.     }
  445.   }
  446.   else
  447.   { /* If HSE fails to start-up, the application will have wrong clock
  448.          configuration. User can add here some code to deal with this error */
  449.   }
  450. }
  451. #elif defined SYSCLK_FREQ_24MHz
  452. /**
  453.   * @brief  Sets System clock frequency to 24MHz and configure HCLK, PCLK2
  454.   *          and PCLK1 prescalers.
  455.   * @note   This function should be used only after reset.
  456.   * @param  None
  457.   * @retval None
  458.   */
  459. static void SetSysClockTo24(void)//系統時鐘設置為24M:SYSCLK=24M,HCLK=24M,PCLK1=24M(最高36M),PCLK2=24M,ADCCLK=12M,
  460. {
  461.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  462.   /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  463.   /* Enable HSE */
  464.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  465.   /* Wait till HSE is ready and if Time out is reached exit */
  466.   do
  467.   {
  468.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  469.     StartUpCounter++;
  470.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  471.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  472.   {
  473.     HSEStatus = (uint32_t)0x01;
  474.   }
  475.   else
  476.   {
  477.     HSEStatus = (uint32_t)0x00;
  478.   }
  479.   if (HSEStatus == (uint32_t)0x01)
  480.   {
  481. #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL && !defined STM32F10X_HD_VL
  482.     /* Enable Prefetch Buffer */
  483.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  484.     /* Flash 0 wait state */
  485.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  486.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
  487. #endif
  488.     /* HCLK = SYSCLK */
  489.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  490.
  491.     /* PCLK2 = HCLK */
  492.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  493.
  494.     /* PCLK1 = HCLK */
  495.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
  496.
  497. #ifdef STM32F10X_CL
  498.     /* Configure PLLs ------------------------------------------------------*/
  499.     /* PLL configuration: PLLCLK = PREDIV1 * 6 = 24 MHz */
  500.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  501.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  502.                             RCC_CFGR_PLLMULL6);
  503.     /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
  504.     /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 10 = 4 MHz */
  505.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  506.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  507.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  508.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV10);
  509.     /* Enable PLL2 */
  510.     RCC->CR |= RCC_CR_PLL2ON;
  511.     /* Wait till PLL2 is ready */
  512.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  513.     {
  514.     }
  515. #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  516.     /*  PLL configuration:  = (HSE / 2) * 6 = 24 MHz */
  517.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  518.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1_Div2 | RCC_CFGR_PLLMULL6);
  519. #else
  520.     /*  PLL configuration:  = (HSE / 2) * 6 = 24 MHz */
  521.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  522.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL6);
  523. #endif /* STM32F10X_CL */
  524.     /* Enable PLL */
  525.     RCC->CR |= RCC_CR_PLLON;
  526.     /* Wait till PLL is ready */
  527.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  528.     {
  529.     }
  530.     /* Select PLL as system clock source */
  531.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  532.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  533.     /* Wait till PLL is used as system clock source */
  534.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  535.     {
  536.     }
  537.   }
  538.   else
  539.   { /* If HSE fails to start-up, the application will have wrong clock
  540.          configuration. User can add here some code to deal with this error */
  541.   }
  542. }
  543. #elif defined SYSCLK_FREQ_36MHz
  544. /**
  545.   * @brief  Sets System clock frequency to 36MHz and configure HCLK, PCLK2
  546.   *          and PCLK1 prescalers.
  547.   * @note   This function should be used only after reset.
  548.   * @param  None
  549.   * @retval None
  550.   */
  551. static void SetSysClockTo36(void)//系統時鐘設置為36M:SYSCLK=36M,HCLK=36M,PCLK1=36M(最高36M),PCLK2=36M,ADCCLK=18M,
  552. {
  553.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  554.   /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  555.   /* Enable HSE */
  556.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  557.   /* Wait till HSE is ready and if Time out is reached exit */
  558.   do
  559.   {
  560.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  561.     StartUpCounter++;
  562.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  563.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  564.   {
  565.     HSEStatus = (uint32_t)0x01;
  566.   }
  567.   else
  568.   {
  569.     HSEStatus = (uint32_t)0x00;
  570.   }
  571.   if (HSEStatus == (uint32_t)0x01)
  572.   {
  573.     /* Enable Prefetch Buffer */
  574.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  575.     /* Flash 1 wait state */
  576.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  577.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
  578.     /* HCLK = SYSCLK */
  579.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  580.
  581.     /* PCLK2 = HCLK */
  582.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  583.
  584.     /* PCLK1 = HCLK */
  585.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
  586.
  587. #ifdef STM32F10X_CL
  588.     /* Configure PLLs ------------------------------------------------------*/
  589.
  590.     /* PLL configuration: PLLCLK = PREDIV1 * 9 = 36 MHz */
  591.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  592.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  593.                             RCC_CFGR_PLLMULL9);
  594. /*!< PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
  595.     /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 10 = 4 MHz */
  596.
  597.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  598.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  599.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  600.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV10);
  601.     /* Enable PLL2 */
  602.     RCC->CR |= RCC_CR_PLL2ON;
  603.     /* Wait till PLL2 is ready */
  604.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  605.     {
  606.     }
  607.
  608. #else
  609.     /*  PLL configuration: PLLCLK = (HSE / 2) * 9 = 36 MHz */
  610.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  611.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL9);
  612. #endif /* STM32F10X_CL */
  613.     /* Enable PLL */
  614.     RCC->CR |= RCC_CR_PLLON;
  615.     /* Wait till PLL is ready */
  616.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  617.     {
  618.     }
  619.     /* Select PLL as system clock source */
  620.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  621.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  622.     /* Wait till PLL is used as system clock source */
  623.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  624.     {
  625.     }
  626.   }
  627.   else
  628.   { /* If HSE fails to start-up, the application will have wrong clock
  629.          configuration. User can add here some code to deal with this error */
  630.   }
  631. }
  632. #elif defined SYSCLK_FREQ_48MHz
  633. /**
  634.   * @brief  Sets System clock frequency to 48MHz and configure HCLK, PCLK2
  635.   *          and PCLK1 prescalers.
  636.   * @note   This function should be used only after reset.
  637.   * @param  None
  638.   * @retval None
  639.   */
  640. static void SetSysClockTo48(void)//系統時鐘設置為48M:SYSCLK=48M,HCLK=48M,PCLK1=24M(最高36M),PCLK2=48M,ADCCLK=24M,
  641. {
  642.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  643.   /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  644.   /* Enable HSE */
  645.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  646.   /* Wait till HSE is ready and if Time out is reached exit */
  647.   do
  648.   {
  649.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  650.     StartUpCounter++;
  651.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  652.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  653.   {
  654.     HSEStatus = (uint32_t)0x01;
  655.   }
  656.   else
  657.   {
  658.     HSEStatus = (uint32_t)0x00;
  659.   }
  660.   if (HSEStatus == (uint32_t)0x01)
  661.   {
  662.     /* Enable Prefetch Buffer */
  663.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  664.     /* Flash 1 wait state */
  665.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  666.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
  667.     /* HCLK = SYSCLK */
  668.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  669.
  670.     /* PCLK2 = HCLK */
  671.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  672.
  673.     /* PCLK1 = HCLK/2 */
  674.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
  675.
  676. #ifdef STM32F10X_CL
  677.     /* Configure PLLs ------------------------------------------------------*/
  678.     /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
  679.     /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
  680.
  681.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  682.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  683.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  684.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  685.     /* Enable PLL2 */
  686.     RCC->CR |= RCC_CR_PLL2ON;
  687.     /* Wait till PLL2 is ready */
  688.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  689.     {
  690.     }
  691.
  692.
  693.     /* PLL configuration: PLLCLK = PREDIV1 * 6 = 48 MHz */
  694.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  695.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  696.                             RCC_CFGR_PLLMULL6);
  697. #else
  698.     /*  PLL configuration: PLLCLK = HSE * 6 = 48 MHz */
  699.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  700.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
  701. #endif /* STM32F10X_CL */
  702.     /* Enable PLL */
  703.     RCC->CR |= RCC_CR_PLLON;
  704.     /* Wait till PLL is ready */
  705.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  706.     {
  707.     }
  708.     /* Select PLL as system clock source */
  709.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  710.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  711.     /* Wait till PLL is used as system clock source */
  712.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  713.     {
  714.     }
  715.   }
  716.   else
  717.   { /* If HSE fails to start-up, the application will have wrong clock
  718.          configuration. User can add here some code to deal with this error */
  719.   }
  720. }
  721. #elif defined SYSCLK_FREQ_56MHz
  722. /**
  723.   * @brief  Sets System clock frequency to 56MHz and configure HCLK, PCLK2
  724.   *          and PCLK1 prescalers.
  725.   * @note   This function should be used only after reset.
  726.   * @param  None
  727.   * @retval None
  728.   */
  729. static void SetSysClockTo56(void)//系統時鐘設置為56M:SYSCLK=56M,HCLK=56M,PCLK1=28M(最高36M),PCLK2=56M,ADCCLK=28M,
  730. {
  731.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  732.   /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  733.   /* Enable HSE */
  734.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  735.   /* Wait till HSE is ready and if Time out is reached exit */
  736.   do
  737.   {
  738.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  739.     StartUpCounter++;
  740.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  741.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  742.   {
  743.     HSEStatus = (uint32_t)0x01;
  744.   }
  745.   else
  746.   {
  747.     HSEStatus = (uint32_t)0x00;
  748.   }
  749.   if (HSEStatus == (uint32_t)0x01)
  750.   {
  751.     /* Enable Prefetch Buffer */
  752.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  753.     /* Flash 2 wait state */
  754.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  755.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
  756.     /* HCLK = SYSCLK */
  757.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  758.
  759.     /* PCLK2 = HCLK */
  760.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  761.
  762.     /* PCLK1 = HCLK/2 */
  763.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
  764. #ifdef STM32F10X_CL
  765.     /* Configure PLLs ------------------------------------------------------*/
  766.     /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
  767.     /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
  768.
  769.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  770.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  771.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  772.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  773.     /* Enable PLL2 */
  774.     RCC->CR |= RCC_CR_PLL2ON;
  775.     /* Wait till PLL2 is ready */
  776.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  777.     {
  778.     }
  779.
  780.
  781.     /* PLL configuration: PLLCLK = PREDIV1 * 7 = 56 MHz */
  782.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  783.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  784.                             RCC_CFGR_PLLMULL7);
  785. #else
  786.     /* PLL configuration: PLLCLK = HSE * 7 = 56 MHz */
  787.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  788.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL7);
  789. #endif /* STM32F10X_CL */
  790.     /* Enable PLL */
  791.     RCC->CR |= RCC_CR_PLLON;
  792.     /* Wait till PLL is ready */
  793.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  794.     {
  795.     }
  796.     /* Select PLL as system clock source */
  797.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  798.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  799.     /* Wait till PLL is used as system clock source */
  800.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  801.     {
  802.     }
  803.   }
  804.   else
  805.   { /* If HSE fails to start-up, the application will have wrong clock
  806.          configuration. User can add here some code to deal with this error */
  807.   }
  808. }
  809. #elif defined SYSCLK_FREQ_72MHz
  810. /**
  811.   * @brief  Sets System clock frequency to 72MHz and configure HCLK, PCLK2
  812.   *          and PCLK1 prescalers.
  813.   * @note   This function should be used only after reset.
  814.   * @param  None
  815.   * @retval None
  816.   */
  817. static void SetSysClockTo72(void)//系統時鐘設置為72M:SYSCLK=72M,HCLK=72M,PCLK1=36M(最高36M),PCLK2=72M,ADCCLK=36M,
  818. {
  819.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;//啟動計數,HSE狀態
  820.   /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  821.   /* Enable HSE */
  822.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);//HSE使能
  823.   /* Wait till HSE is ready and if Time out is reached exit */
  824.   do //循環,直到HSE使能成功或者超時
  825.   {
  826.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  827.     StartUpCounter++;
  828.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  829.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  830.   {
  831.     HSEStatus = (uint32_t)0x01;//HSE使能成功
  832.   }
  833.   else
  834.   {
  835.     HSEStatus = (uint32_t)0x00;//HSE使能不成功
  836.   }
  837.   if (HSEStatus == (uint32_t)0x01)//HSE使能成功
  838.   {
  839.     /* Enable Prefetch Buffer */
  840.     FLASH->ACR |= FLASH_ACR_PRFTBE;//flash緩存使能
  841.     /* Flash 2 wait state */
  842.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);//
  843.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;//
  844.     /* HCLK = SYSCLK */
  845.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;//RCC_CFGR_HPRE_DIV1=0,CFGR中的值不變
  846.
  847.     /* PCLK2 = HCLK */
  848.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;//RCC_CFGR_PPRE2_DIV1=0,CFGR中的值不變
  849.
  850.     /* PCLK1 = HCLK/2 */
  851.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;//低速APB預分頻把HCLK 2分頻,APB1CLK=HCLK/2
  852. #ifdef STM32F10X_CL
  853.     /* Configure PLLs ------------------------------------------------------*/
  854.     /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
  855.     /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
  856.
  857.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  858.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  859.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  860.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  861.     /* Enable PLL2 */
  862.     RCC->CR |= RCC_CR_PLL2ON;
  863.     /* Wait till PLL2 is ready */
  864.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  865.     {
  866.     }
  867.
  868.
  869.     /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
  870.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  871.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  872.                             RCC_CFGR_PLLMULL9);
  873. #else
  874.     /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
  875.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |  //PLL輸入時鐘源HSI時鐘2分頻后作為PLL輸入時鐘,HSE分頻器作為PLL輸入HSE不分頻
  876.                                         RCC_CFGR_PLLMULL)); //PLL倍頻系數PLL 2倍頻輸出(為了清零其他位)
  877.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);//PLL輸入時鐘源HSE時鐘作為PLL輸入時鐘,PLL倍頻系數PLL 9倍頻輸出
  878. #endif /* STM32F10X_CL */
  879.     /* Enable PLL */
  880.     RCC->CR |= RCC_CR_PLLON; //PLL使能
  881.     /* Wait till PLL is ready */
  882.     while((RCC->CR & RCC_CR_PLLRDY) == 0)//等待PLL使能成功
  883.     {
  884.     }
  885.
  886.     /* Select PLL as system clock source */
  887.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));//HSI作為系統時鐘(為了清零其他位)
  888.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL; //PLL輸出作為系統時鐘
  889.     /* Wait till PLL is used as system clock source */
  890.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)//等待直到PLL成功用作系統時鐘源
  891.     {
  892.     }
  893.   }
  894.   else
  895.   { /* If HSE fails to start-up, the application will have wrong clock
  896.          configuration. User can add here some code to deal with this error */
  897.   }
  898. }
  899. #endif
  900. /**
  901.   * @}
  902.   */
  903. /**
  904.   * @}
  905.   */
  906. /**
  907.   * @}
  908.   */
  909. /******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
ID:21482 發表于 2015-2-12 09:43 | 只看該作者
很詳細,知道了不少東西
主站蜘蛛池模板: 国产毛片视频 | 国产精品国产成人国产三级 | 日韩一区三区 | 久操福利视频 | 欧美一级黄色片 | 日韩资源 | 欧美久久久久久久久 | 久久激情综合 | 国产日本在线观看 | 久草视频网站 | 黄色网址在线视频 | 欧美在线免费 | 一区视频在线 | 日皮视频免费看 | av看片 | 免费观看黄色av | 亚洲视频一区二区三区 | 超碰在线99 | 久久久亚洲一区 | 日本在线看片 | 日韩激情网站 | 欧美日韩第一页 | 蜜桃久久久 | 午夜爽爽影院 | 国产激情视频在线 | 黄色免费大片 | 高清一区二区 | 免费黄色小视频 | 日韩欧美精品在线 | 四虎在线观看视频 | 一级片免费网站 | 欧美一区二区三区在线 | 狠狠插狠狠操 | 欧美激情在线观看 | 麻豆av在线免费观看 | 色播久久 | 九九99久久| 黄色一级片免费看 | av一区二区在线观看 | 日韩免费一区二区三区 | 亚洲毛片在线 |
