查看: 3693|回復: 0
__builtin_expect詳解
ID:72519 發表于 2015-1-23 19:25 | 顯示全部樓層 |閱讀模式
在GTK+2.0源碼中有很多這樣的宏:G_LIKELY和G_UNLIKELY。比如下面這段代碼:
if (G_LIKELY (acat == 1))       /* allocate through magazine layer */
        ThreadMemory *tmem = thread_memory_from_self();
        guint ix = SLAB_INDEX (allocator, chunk_size);
        if (G_UNLIKELY (thread_memory_magazine1_is_empty (tmem, ix)))
            thread_memory_swap_magazines (tmem, ix);
              thread_memory_magazine1_reload (tmem, ix);
        mem = thread_memory_magazine1_alloc (tmem, ix);
      }在源碼中,宏G_LIKELY和G_UNLIKELY 是這么定義的:
#define G_LIKELY(expr) (__builtin_expect (_G_BOOLEAN_EXPR(expr), 1))
  #define G_UNLIKELY(expr) (__builtin_expect (_G_BOOLEAN_EXPR(expr), 0))宏_G_BOOLEAN_EXPR的作用是把expr轉換為0和1,即真假兩種。要理解宏G_LIKELY和G_UNLIKELY ,很明顯必須理解__builtin_expect。__builtin_expect是GCC(version>=2.9)引進的宏,其作用就是幫助編譯器判斷條件跳轉的預期值,避免跳轉造成時間亂費。拿上面的代碼來說:
if (G_LIKELY (acat == 1))      //表示大多數情況下if里面是真,程序大多數直接執行if里面的程序
if (G_UNLIKELY (thread_memory_magazine1_is_empty (tmem, ix)))//表示大多數情況if里面為假,程序大多數直接執行else里面的程序
可能大家看到還是一頭霧水,看下面一段就會明白其中的樂趣啦;
//test_builtin_expect.c
#define LIKELY(x) __builtin_expect(!!(x), 1)
#define UNLIKELY(x) __builtin_expect(!!(x), 0)
int test_likely(int x)
if(LIKELY(x))
    x = 5;
    x = 6;
return x;
int test_unlikely(int x)
if(UNLIKELY(x))
    x = 5;
    x = 6;
return x;
}[lammy@localhost test_builtin_expect]$ gcc -fprofile-arcs -O2 -c test_builtin_expect.c
[lammy@localhost test_builtin_expect]$ objdump -d test_builtin_expect.otest_builtin_expect.o:       file format elf32-i386
Disassembly of section .text:00000000 <test_likely>:
     0: 55                      push     %ebp
     1: 89 e5                   mov      %esp,%ebp
     3: 8b 45 08                mov      0x8(%ebp),%eax
     6: 83 05 38 00 00 00 01  addl     $0x1,0x38
     d: 83 15 3c 00 00 00 00  adcl     $0x0,0x3c
  14: 85 c0                   test     %eax,%eax
  16: 74 15                   je       2d <test_likely+0x2d>//主要看這里
  18: 83 05 40 00 00 00 01  addl     $0x1,0x40
  1f: b8 05 00 00 00          mov      $0x5,%eax
  24: 83 15 44 00 00 00 00  adcl     $0x0,0x44
  2b: 5d                      pop      %ebp
  2c: c3                      ret
  2d: 83 05 48 00 00 00 01  addl     $0x1,0x48
  34: b8 06 00 00 00          mov      $0x6,%eax
  39: 83 15 4c 00 00 00 00  adcl     $0x0,0x4c
  40: 5d                      pop      %ebp
  41: c3                      ret
  42: 8d b4 26 00 00 00 00  lea      0x0(%esi,%eiz,1),%esi
  49: 8d bc 27 00 00 00 00  lea      0x0(%edi,%eiz,1),%edi00000050 <test_unlikely>:
  50: 55                      push     %ebp
  51: 89 e5                   mov      %esp,%ebp
  53: 8b 55 08                mov      0x8(%ebp),%edx
  56: 83 05 20 00 00 00 01  addl     $0x1,0x20
  5d: 83 15 24 00 00 00 00  adcl     $0x0,0x24
  64: 85 d2                   test     %edx,%edx
  66: 75 15                   jne      7d <test_unlikely+0x2d>//主要看這里
  68: 83 05 30 00 00 00 01  addl     $0x1,0x30
  6f: b8 06 00 00 00          mov      $0x6,%eax
  74: 83 15 34 00 00 00 00  adcl     $0x0,0x34
  7b: 5d                      pop      %ebp
  7c: c3                      ret
  7d: 83 05 28 00 00 00 01  addl     $0x1,0x28
  84: b8 05 00 00 00          mov      $0x5,%eax
  89: 83 15 2c 00 00 00 00  adcl     $0x0,0x2c
  90: 5d                      pop      %ebp
  91: c3                      ret
  92: 8d b4 26 00 00 00 00  lea      0x0(%esi,%eiz,1),%esi
  99: 8d bc 27 00 00 00 00  lea      0x0(%edi,%eiz,1),%edi000000a0 <_GLOBAL__I_65535_0_test_likely>:
  a0: 55                      push     %ebp
  a1: 89 e5                   mov      %esp,%ebp
  a3: 83 ec 08                sub      $0x8,%esp
  a6: c7 04 24 00 00 00 00  movl     $0x0,(%esp)
  ad: e8 fc ff ff ff          call     ae <_GLOBAL__I_65535_0_test_likely+0xe>
  b2: c9                      leave
  b3: c3                      ret
[lammy@localhost test_builtin_expect]$兩個函數編譯生成的匯編語句所使用到的跳轉指令不一樣,仔細分析下會發現__builtin_expect實際上是為了滿足在大多數情況不執行跳轉指令,所以__builtin_expect僅僅是告訴編譯器優化,并沒有改變其對真值的判斷。
這種用法在linux內核中也經常用到,國外也有一篇相關的文章,大家不妨看看:http://kernelnewbies.org/FAQ/LikelyUnlikely
不知大家注意到沒有,我在生產匯編時用的是gcc -fprofile-arcs -O2 -c test_builtin_expect.c,而不是gcc -O2 -c test_builtin_expect.c,具體可以參考http://gcc.gnu.org/onlinedocs/gcc/Other-Builtins.html
主站蜘蛛池模板: av网站观看 | 欧美级毛片 | 亚洲天堂一区二区三区 | 欧美日韩在线观看一区二区 | 精品久久网站 | 日韩精品视频免费播放 | 成人午夜视频在线观看 | 国产福利91| 99久久久 | 免费a在线 | 九九视频这里只有精品 | 日日干日日射 | 精品一区二区三区视频 | 日韩视频在线观看免费 | 日韩中文字幕在线 | 黄色特级毛片 | 国产精品久久 | 美女视频一区二区 | 欧美资源在线 | 亚洲天堂国产 | 亚洲色综合 | 中文字幕亚洲精品 | 精品一区二区在线视频 | 激情五月综合 | 成人av播放 | 天天操天天操天天 | 成人国产精品视频 | 黄免费视频 | 99国产免费 | 国产va在线观看 | 欧美一级特黄视频 | 黄色aaa| 香蕉视频免费看 | 国产一级生活片 | 狠狠综合网 | 久久久精品影院 | 免费黄色一级视频 | 亚洲精品91天天久久人人 | 我要看一级片 | 亚洲看片| 一区二区三区四区在线 |
