查看: 3289|回復: 0
凌陽061a芯片C頭文件
ID:26188 發表于 2015-2-18 01:22 | 顯示全部樓層 |閱讀模式
// 端口地址常量
#define Port_IOA_Data           (volatile unsigned int *)0x7000   //讀/寫寫入數據到數據寄存器里,讀出IOA管腳上的電平狀態
#define Port_IOA_Buffer         (volatile unsigned int *)0x7001   //讀/寫寫入數據到數據寄存器里,讀出數據寄存器里的數據
#define Port_IOA_Dir            (volatile unsigned int *)0x7002   //讀/寫  I/O A口的方向向量
#define Port_IOA_Attrib         (volatile unsigned int *)0x7003   //讀/寫  I/O A口的屬性向量
#define Port_IOA_Latc           (volatile unsigned int *)0x7004   //讀     進入睡眠前鎖存I/O A口的數據,為睡眠后觸鍵引起喚醒準備
#define Port_IOB_Data           (volatile unsigned int *)0x7005   //讀/寫寫入數據到數據寄存器里,讀出I/O B口管腳上的電平狀態
#define Port_IOB_Buffer         (volatile unsigned int *)0x7006   //讀/寫寫入數據到數據寄存器里,讀出數據寄存器里的數據
#define Port_IOB_Dir            (volatile unsigned int *)0x7007   //讀/寫  I/O B口的方向向量
#define Port_IOB_Attrib         (volatile unsigned int *)0x7008   //讀/寫  I/O B口的屬性向量
#define Port_FeedBack           (volatile unsigned int *)0x7009   //寫     通過反饋電路將外部RC振蕩源引入
#define Port_TimerA_Data        (volatile unsigned int *)0x700A   //讀/寫  I/O A口的數據口
#define Port_TimerA_Ctrl        (volatile unsigned int *)0x700B   //寫     I/O A口的控制單元
#define Port_TimerB_Data        (volatile unsigned int *)0x700C   //讀/寫  I/O B口的數據口
#define Port_TimerB_Ctrl        (volatile unsigned int *)0x700D   //寫     I/O B口的控制單元
#define Port_Timebase_Setup     (volatile unsigned int *)0x700E   //寫     時基發生器的選頻設置單元
#define Port_Timebase_Clear     (volatile unsigned int *)0x700F   //寫     時基計數器復位單元
#define Port_INT_Ctrl           (volatile unsigned int *)0x7010   //讀/寫  中斷源的控制單元
#define Port_INT_Clear          (volatile unsigned int *)0x7011   //寫     中斷源中斷請求清除單元
#define Port_Watchdog_Clear     (volatile unsigned int *)0x7012   //寫     清除看門狗
#define Port_SystemClock        (volatile unsigned int *)0x7013   //寫     系統時鐘選頻單元(包括系統進入睡眠狀態的時鐘頻率選擇)
#define Port_ADC                (volatile unsigned int *)0x7014   //讀/寫  ADC的數據口
#define Port_ADC_Ctrl           (volatile unsigned int *)0x7015   //讀/寫  ADC的控制單元
#define Port_DAC2               (volatile unsigned int *)0x7016   //讀/寫  DAC2 的數據口
#define Port_DAC1               (volatile unsigned int *)0x7017   //讀/寫  DAC1 的數據口
#define Port_IR_Ctrl            (volatile unsigned int *)0x7018   //讀/寫  紅外通訊的控制單元
#define Port_LVD_Ctrl           (volatile unsigned int *)0x7019   //讀/寫  低電壓監測的控制單元
#define Port_SIO_Data           (volatile unsigned int *)0x701A   //讀/寫  串行設備接口SIO的數據口
#define Port_SIO_Addr_Low       (volatile unsigned int *)0x701B   //讀/寫  SIO的低字節地址單元
#define Port_SIO_Addr_Mid       (volatile unsigned int *)0x701C   //讀/寫  SIO的中字節地址單元
#define Port_SIO_Addr_Hig       (volatile unsigned int *)0x701D   //讀/寫  SIO的高字節地址單元
#define Port_SIO_Ctrl           (volatile unsigned int *)0x701E   //讀/寫  SIO的控制單元
#define Port_SIO_Start          (volatile unsigned int *)0x701F   //讀/寫  SIO數據傳輸的啟動單元
#define Port_SIO_Stop           (volatile unsigned int *)0x7020   //寫     SIO數據傳輸的結束單元
#define Port_UART_Command1      (volatile unsigned int *)0x7021   //寫     通用異步串行I/O口UART的控制單元
#define Port_UART_Command2      (volatile unsigned int *)0x7022   //讀/寫  UART接收/發送功能的開通/關斷控制單元
#define Port_UART_Data          (volatile unsigned int *)0x7023   //讀/寫  UART的數據口
#define Port_UART_BaudScalarLow (volatile unsigned int *)0x7024   //讀/寫  UART 波特率設定控制字的低字節
#define Port_UART_BaudScalarHig (volatile unsigned int *)0x7025   //讀/寫  UART 波特率設定控制字的高字節
#define Port_DAC_Ctrl           (volatile unsigned int *)0x702A   //讀/寫  音頻輸出方式及雙DAC通道和PWM驅動通道的控制單元
#define Port_ADC_MUX_Ctrl       (volatile unsigned int *)0x702B   //讀/寫  ADC多通道控制
#define Port_ADC_MUX_Data       (volatile unsigned int *)0x702C   //讀   讀出多通道10 位ADC轉換的數字數據
#define Port_INT_Ctrl_New       (volatile unsigned int *)0x702D   //讀/寫  激活和屏蔽中斷
//系統時間P_SystemClock(寫)($7013H)單元設置
//鎖相環頻率(fosc)設置,p5-p7口
#define CPU_PLL_24m          0x0000   //24.576MHz
#define CPU_PLL_20m          0x0020   //20.48MHz
#define CPU_PLL_32m          0x0040   //32.768MHz
#define CPU_PLL_40m          0x0060   //40.96MHz
#define CPU_PLL_49m          0x0080   //49.152MHz
//CPU時鐘選擇,p0-p2口
#define CPU_CLK_all          0x0000   //(fosc)全速
#define CPU_CLK_2            0x0001   //(fosc)/2速
#define CPU_CLK_4            0x0002   //(fosc)/4速
#define CPU_CLK_8            0x0003   //(fosc)/8速(默認)
#define CPU_CLK_16           0x0004   //(fosc)/16速
#define CPU_CLK_32           0x0005   //(fosc)/32速
#define CPU_CLK_64           0x0006   //(fosc)/64速
#define CPU_CLK_stop         0x0007   //睡眠停止
//晶振狀態,p3-p4口
#define XO_Full_Speed        0x0008   //p3口=1 晶振全速
#define Bed_XO_Slow_Speed    0x0000   //p3口=0 晶振自動轉弱振(默認)
#define Bed_XO_Always        0x0010   //p4口=1 睡眠時晶振一直全速(默認)
#define Bed_XO_Close         0x0000   //p4口=0 睡眠時晶振關閉
//時基信號發生器P_Timebase_Setup(寫)($700EH)單元設置
//選頻邏輯TMB1設置,p0-p1口
#define Timebase_TMB1_8Hz    0x0000   //(默認)
#define Timebase_TMB1_16Hz   0x0001;
#define Timebase_TMB1_32Hz   0x0002;
#define Timebase_TMB1_64Hz   0x0003;
//選頻邏輯TMB2設置,p2-p3口
#define Timebase_TMB2_128Hz  0x0000   //(默認)
#define Timebase_TMB2_256Hz  0x0004;
#define Timebase_TMB2_512Hz  0x0008;
#define Timebase_TMB2_1024Hz 0x000c;
//定時器TimerA、B P_Timer*_Ctrl(寫) TimerA($700BH)、TimerA($700DH)單元設置
//定時器A使用時鐘源A、B,
//默認未使用定時器A,需使用時鐘源B時,時鐘源A須設置為TimeAB_SourceAC_1
//定時器B使用時鐘源C
//定時器A、B使用時鐘源A、C設置,p0-p2口
#define TimeAB_SourceAC_F2   0x0000   //Fosc/2
#define TimeAB_SourceAC_F256 0x0001   //Fosc/256
#define TimeAB_SourceAC_XO   0x0002   //32768Hz
#define TimeAB_SourceAC_8K   0x0003   //8192Hz
#define TimeAB_SourceAC_4K   0x0004   //4096Hz
#define TimeAB_SourceAC_1    0x0005   //使用時鐘源B時,必選
#define TimeAB_SourceAC_0    0x0006   //(默認)未開
#define TimeAB_SourceAC_EXT1 0x0007   //
//定時器A使用時鐘源B設置,p3-p5口
#define TimeA_SourceB_2048   0x0000;
#define TimeA_SourceB_1024   0x0008;
#define TimeA_SourceB_256    0x0010;
#define TimeA_SourceB_TMB1   0x0018;
#define TimeA_SourceB_4Hz    0x0020;
#define TimeA_SourceB_2Hz    0x0028;
#define TimeA_SourceB_1      0x0030  //(默認)
#define TimeA_SourceB_EXT2   0x0038;
//定時器脈沖占空比設置,p6-p9口
#define TimeAB_APWMO_Off     0x0000;
#define TimeAB_APWMO_1_16    0x0040;
#define TimeAB_APWMO_2_16    0x0080;
#define TimeAB_APWMO_3_16    0x00c0;
#define TimeAB_APWMO_4_16    0x0100;
#define TimeAB_APWMO_5_16    0x0140;
#define TimeAB_APWMO_6_16    0x0180;
#define TimeAB_APWMO_7_16    0x01c0;
#define TimeAB_APWMO_8_16    0x0200;
#define TimeAB_APWMO_9_16    0x0240;
#define TimeAB_APWMO_10_16   0x0280;
#define TimeAB_APWMO_11_16   0x02c0;
#define TimeAB_APWMO_12_16   0x0300;
#define TimeAB_APWMO_13_16   0x0340;
#define TimeAB_APWMO_14_16   0x0380;
#define TimeAB_APWMO_TAOut   0x03c0  //受TimerA、B的溢出信號控制,占空比為50%
//中斷控制單元P_INT_Ctrl(讀/寫)(7010H)
//下列排序從到下排列,對應中斷等級按從高到低排列
//IRQ0-6只有查詢先后區別,不能嵌套
#define FIQ_F_1024    0x8000   //中斷源 音頻輸出, 快速中斷
#define IRQ0_F_1024   0x4000   //中斷源 音頻輸出,     中斷0
#define FIQ_TMA       0x2000   //中斷源 定時器A,  快速中斷
#define IRQ1_TMA      0x1000   //中斷源 定時器A,      中斷1
#define FIQ_TMB       0x0800   //中斷源 定時器B,  快速中斷
#define IRQ2_TMB      0x0400   //中斷源 定時器B,      中斷2
#define IRQ3_EXT2     0x0200   //中斷源 外部時鐘2,    中斷3
#define IRQ3_EXT1     0x0100   //中斷源 外部時鐘1,    中斷3
#define IRQ3_KEY      0x0080   //中斷源 觸鍵喚醒,     中斷3
#define IRQ4_4KHz     0x0040   //中斷源 4096Hz時基,   中斷4
#define IRQ4_2KHz     0x0020   //中斷源 2048Hz時基,   中斷4
#define IRQ4_1KHz     0x0010   //中斷源 1024Hz時基,   中斷4
#define IRQ5_4Hz      0x0008   //中斷源 4Hz時基,      中斷5
#define IRQ5_2Hz      0x0004   //中斷源 2Hz時基,      中斷5
#define IRQ6_TMB1     0x0002   //中斷源 選頻邏輯TMB1, 中斷6
#define IRQ6_TMB2     0x0001   //中斷源 選頻邏輯TMB1, 中斷6
主站蜘蛛池模板: 91福利网 | 亚洲日本国产 | 一区二区三区四区免费视频 | 日韩免费大片 | 日韩高清在线 | 亚洲精品www久久久久久广东 | 午夜在线小视频 | 日韩一区二区免费视频 | 一级片aa | 午夜视频免费看 | 狠狠干婷婷 | 伊人免费视频 | 天堂成人av | 国产精品久久一区 | 一区二区三区高清 | 伊人亚洲综合 | 9l视频自拍九色9l视频成人 | 91久久久久久久久 | 日日夜夜天天干 | 久久黄视频 | 美女福利网站 | 天天射天天操天天干 | 69av在线| 艳妇臀荡乳欲伦交换h漫 | 天天爽夜夜操 | 久久综合五月天 | 免费三级网站 | 91精品久久久久久久久 | 亚洲天堂免费视频 | 欧美一区二区在线 | 97国产视频 | 国产美女一区二区 | 欧美激情中文字幕 | 成人免费网站黄 | 欧美三级韩国三级日本三斤在线观看 | 日韩中文字幕视频 | 欧美日韩一区在线观看 | 国产小视频在线观看 | 午夜精品久久久久 | 日本亚洲欧美 | 高潮毛片又色又爽免费 |
