查看: 3306|回復(fù): 0
C51單片機(jī)學(xué)習(xí)板 18B20+1602LCD溫度實(shí)驗(yàn)
ID:75263 發(fā)表于 2015-3-25 00:02 | 顯示全部樓層 |閱讀模式
#include < reg51.h >
#include < intrins.h >
#define uchar unsigned char
#define uint  unsigned int
sbit DQ = P3^3 ;  //定義DS18B20端口DQ
sbit BEEP=P2^1  ; //蜂鳴器驅(qū)動(dòng)線
bit presence  ;
sbit LCD_RS = P1^0 ;
sbit LCD_RW = P1^1 ;
sbit LCD_EN = P1^2 ;
uchar code  cdis1[ ] = {" WWW*RICHMCU*COM "} ;
uchar code  cdis2[ ] = {" WENDU:    .  C "} ;
uchar code  cdis3[ ] = {" DS18B20  ERR0R "} ;
uchar code  cdis4[ ] = {"  PLEASE CHECK  "} ;
unsigned char data  temp_data[2] = {0x00,0x00} ;
unsigned char data  display[5] =   {0x00,0x00,0x00,0x00,0x00} ;
unsigned char code  ditab[16] =    {0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x04,
                                                        0x05,0x06,0x06,0x07,0x08,0x08,0x09,0x09} ;
void beep() ;
unsigned char code  mytab[8] = {0x0C,0x12,0x12,0x0C,0x00,0x00,0x00,0x00} ;
#define delayNOP() ; {_nop_() ;_nop_() ;_nop_() ;_nop_() ;} ;
void delay1(int ms)
unsigned char y ;
  while(ms--)
  for(y = 0 ; y<250 ; y++)
   _nop_() ;
   _nop_() ;
   _nop_() ;
   _nop_() ;
/*檢查L(zhǎng)CD忙狀態(tài)                                                   */
/*lcd_busy為1時(shí),忙,等待。lcd-busy為0時(shí),閑,可寫(xiě)指令與數(shù)據(jù)。   */
bit lcd_busy()
    bit result ;
    LCD_RS = 0 ;
    LCD_RW = 1 ;
    LCD_EN = 1 ;
    delayNOP() ;
    result = (bit)(P2&0x80) ;
    LCD_EN = 0 ;
    return(result) ;
/*寫(xiě)指令數(shù)據(jù)到LCD                                                  */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。          */
void lcd_wcmd(uchar cmd)
   while(lcd_busy()) ;
    LCD_RS = 0 ;
    LCD_RW = 0 ;
    LCD_EN = 0 ;
    _nop_() ;
    _nop_() ;
    P2= cmd ;
    delayNOP() ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
/*寫(xiě)顯示數(shù)據(jù)到LCD                            */
/*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。       */
void lcd_wdat(uchar dat)
   while(lcd_busy()) ;
    LCD_RS = 1 ;
    LCD_RW = 0 ;
    LCD_EN = 0 ;
    P2 = dat ;
    delayNOP() ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
/*  LCD初始化設(shè)定                                                  */
void lcd_init()
    delay1(15) ;
    lcd_wcmd(0x01) ;      //清除LCD的顯示內(nèi)容
    lcd_wcmd(0x38) ;      //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
    delay1(5) ;
    lcd_wcmd(0x38) ;
    delay1(5) ;
    lcd_wcmd(0x38) ;
    delay1(5) ;
    lcd_wcmd(0x0c) ;      //顯示開(kāi),關(guān)光標(biāo)
    delay1(5) ;
    lcd_wcmd(0x06) ;      //移動(dòng)光標(biāo)
    delay1(5) ;
    delay1(5) ;
/*  設(shè)定顯示位置                                    */
void lcd_pos(uchar pos)
  lcd_wcmd(pos | 0x80) ;  //數(shù)據(jù)指針=80+地址變量
/*自定義字符寫(xiě)入CGRAM                                   */
void  writetab()
    unsigned char i ;
    lcd_wcmd(0x40) ;            //寫(xiě)CGRAM
    for (i = 0 ; i< 8 ; i++)
    lcd_wdat(mytab[ i ]) ;
/*us級(jí)延時(shí)函數(shù)                                        */
void Delay(unsigned int num)
  while( --num ) ;
/*初始化ds1820                                      */
Init_DS18B20(void)
     DQ = 1 ;      //DQ復(fù)位
     Delay(8) ;    //稍做延時(shí)
     DQ = 0 ;      //單片機(jī)將DQ拉低
     Delay(90) ;   //精確延時(shí) 大于 480us
     DQ = 1 ;       //拉高總線
     Delay(8) ;
     presence = DQ ;    //如果=0則初始化成功 =1則初始化失敗
     Delay(100) ;
     DQ = 1 ;
     return(presence) ; //返回信號(hào),0=presence,1= no presence
/* 讀一個(gè)字節(jié)                     */
ReadOneChar(void)
unsigned char i = 0 ;
unsigned char dat = 0 ;
for (i = 8 ; i > 0 ; i--)
    DQ = 0 ; // 給脈沖信號(hào)
    dat >>= 1 ;
    DQ = 1 ; // 給脈沖信號(hào)
    if(DQ)
     dat |= 0x80 ;
    Delay(4) ;
    return (dat) ;
/* 寫(xiě)一個(gè)字節(jié)                                         */
WriteOneChar(unsigned char dat)
    DQ = 0 ;
    DQ = dat&0x01 ;
    Delay(5) ;
    DQ = 1 ;
    dat>>=1 ;
/* 讀取溫度                            */
Read_Temperature(void)
     Init_DS18B20() ;
     WriteOneChar(0xCC) ;  // 跳過(guò)讀序號(hào)列號(hào)的操作
     WriteOneChar(0x44) ;  // 啟動(dòng)溫度轉(zhuǎn)換
     Init_DS18B20() ;
     WriteOneChar(0xCC) ;  //跳過(guò)讀序號(hào)列號(hào)的操作
     WriteOneChar(0xBE) ;  //讀取溫度寄存器
     temp_data[0] = ReadOneChar() ;   //溫度低8位
     temp_data[1] = ReadOneChar() ;   //溫度高8位
/* 數(shù)據(jù)轉(zhuǎn)換與溫度顯示                                              */
Disp_Temperature()
  display[4]=temp_data[0]&0x0f ;
  display[0]=ditab[display[4]]+0x30 ;     //查表得小數(shù)位的值
  display[4]=((temp_data[0]&0xf0)>>4)|((temp_data[1]&0x0f)<<4) ;
  display[3]=display[4]/100+0x30 ;
  display[1]=display[4]%100 ;
  display[2]=display[1]/10+0x30 ;
  display[1]=display[1]%10+0x30 ;
    if(display[3]==0x30)        //高位為0,不顯示
     display[3]=0x20 ;
     if(display[2]==0x30)      //次高位為0,不顯示
     display[2]=0x20 ;
     lcd_pos(0x48) ;
     lcd_wdat(display[3]) ;        //百位數(shù)顯示
     lcd_pos(0x49) ;
     lcd_wdat(display[2]) ;        //十位數(shù)顯示
  lcd_pos(0x4a) ;
     lcd_wdat(display[1]) ;        //個(gè)位數(shù)顯示
  lcd_pos(0x4c) ;
     lcd_wdat(display[0]) ;        //小數(shù)位數(shù)顯示
/* 蜂鳴器響一聲                 */
void beep()
    unsigned char y ;
    for (y=0 ;y<100 ;y++)
      Delay(60) ;
      BEEP=!BEEP ;                //BEEP取反
    BEEP=1 ;                      //關(guān)閉蜂鳴器
Delay(40000) ;
/* DS18B20 OK 顯示菜單                                             */
void  Ok_Menu ()
    uchar  m ;
    lcd_init() ;                //初始化LCD
    lcd_pos(0) ;                //設(shè)置顯示位置為第一行的第1個(gè)字符
     m = 0 ;
    while(cdis1[m] != '\0')
     {                         //顯示字符
       lcd_wdat(cdis1[m]) ;
       m++ ;
    lcd_pos(0x40) ;             //設(shè)置顯示位置為第二行第1個(gè)字符
     m = 0 ;
    while(cdis2[m] != '\0')
       lcd_wdat(cdis2[m]) ;      //顯示字符
       m++ ;
     writetab() ;               //自定義字符寫(xiě)入CGRAM
     delay1(5) ;
     lcd_pos(0x4d) ;
     lcd_wdat(0x00) ;          //顯示自定義字符
/* DS18B20 ERROR 顯示菜單                             */
void  Error_Menu ()
     uchar  m ;
     m = 0 ;
     while(cdis3[m] != '\0')
     {                         //顯示字符
       lcd_wdat(cdis3[m]) ;
       m++ ;
     m = 0 ;
     while(cdis4[m] != '\0')
       lcd_wdat(cdis4[m]) ;      //顯示字符
       m++ ;
/* 主函數(shù)     */
     Ok_Menu () ;
do
      Read_Temperature() ;
   Disp_Temperature() ;
    while(!presence)  ;
     Error_Menu () ;
do
    Init_DS18B20() ;
    beep() ;
while(presence) ;
主站蜘蛛池模板: 天天综合视频 | 亚洲欧美国产毛片在线 | 国产成人综合在线 | 夜夜操网站 | 欧美三级精品 | 久久精品99久久久久久 | 成人午夜在线视频 | 九九九精品视频 | 日本久久视频 | 99热精品在线 | 在线免费看黄网站 | 天堂网在线资源 | 在线免费看a | 国产精品成人一区二区 | 黄色国产 | 伊人国产女 | 成年人午夜视频 | 精品www | 欧美又大又硬又粗bbbbb | 99视频免费在线观看 | 欧美日本精品 | 日韩手机看片 | 欧美日本一区二区三区 | 91手机看片| 亚洲精品一区在线观看 | 成人国产在线 | 在线免费观看日韩av | 国产区视频在线 | 国产精品高潮呻吟久久 | 欧美在线免费观看视频 | 中文字幕精品一区久久久久 | 成人精品国产 | 激情综合久久 | 黄色一级大片在线免费看产 | 九九在线精品 | 国产黄色大片 | 亚洲一区二区三区四区在线 | 国产理论在线观看 | 日韩成人免费 | 精品国产乱码一区二区三 | 特黄aaaaaaaaa真人毛片 |
